IMAGISTIC 3512 error code F2-00 - Audio Players & Recorders
How print sideways hp 3512 ?
If you are using annotative text, it may be one of the settings with your text style. Type STYLE and select the style that you are using.
There is a check box for annotative text (it shoudl be checked) and directly under it is another one that aligns or rotate the text with the viewport. Uncheck this option. otherwise reinstall the driver. HP Deskjet 3512 Printer Driver Download For Windows 78 1XP
Jul 21, 2014 | HP Deskjet 3512 Inkjet Multifunction...
New Dell 3512 giving error of hard disc not found..
If your laptop is less than 12 months old then I recommend you take it back to where you purchased it and have it repaired or replaced as it would be still under warranty. If you try to repair it you most likely void your warranty.
Mar 10, 2013 | Computers & Internet
IMAGISTICS 2620 Error code C0500
How to reset malfunction code C0500 of a imagistic
Feb 03, 2009 | Konica Minolta DiALTA Di200 Copier
Df-3035 copier
Hello flyersgirl68,
I truly wish I could help you. But , you would not believe how helpful it would be if I knew what brand copier you have. Canon makes a 3035 copier but they have no error codes that start with f. Mita "MADE" a copier (1986) that had an "f" in their error codes that indicated the feeder had a problem. I guess we might want to narrow it down a tad. Is your machine a,olivetti,mita,ricoh,savin,oce,kodak,xerox,minolta,konica,nashua,pitney bose,danka,savin,gestetner,monroe,ibm,imagistic,panasonic,toshiba,lanier,brother,riso,......etc....
Apr 18, 2008 | Office Equipment & Supplies
Delstar DS-3512 (512 MB) MP3 Player format error
these players are notorious for this sort of problem
this site should solve ur problem
i recommend you upgrade the firmware.
Dec 31, 2007 | Delstar DS-3512 MP3 Player
