Question about Dryers
I have a unimac ut035 gas dryer and it keeps shuting off can you tell me whats going on with it and what i can do to fix it
    Genius:
  • 2,494 Answers
Check the switch on the door has not come loose ,do not over load it as it could be getting hot or the motor could be on the way out.
Posted on Dec 12, 2016
  • dennis schultz
    dennis schultz Dec 12, 2016
    Thanks for you advise I checked all of that can cleaned out the vent pipe but still same thing I noticed the door where I get access to the filter is going in and out as its running to e it now seems like the motor is whats going bad on it
Unimac. Why is it displaying E FL and won't spin?
Unimac Washer Product Support ' ManualsOnline.com
laundry.manualsonline.com/support/unimac/washer/
Unimac Washer uw60b20u80001. 0 Solutions ... on start up unlock door light stays on.display sa. Unimac ... washer has falt code E FL what does this mean and.
E fl error code on industrial uni Mac washer. What's it mean ...
www.fixya.com/support/t20744713-e_fl_error_code_industrial_uni_mac
Jan 07, 2016 | Washing Machines
Unimac front loader washer with the error code OF not sure what it means. This is a stackable unit.
[PDF]Operation/Maintenance for Drying Tumblers - Alliance ...
docs.alliancelaundry.com/tech_pdf/Production/70283501en.pdf
NFPA 54 "National Fuel Gas Code" and Standard ANSI/NFPA 70 "National Electric Code." In Canada ..... NOTE: If display shows an error code, refer to.
Oct 15, 2013 - I've had this issue three times. On the first case, I found my external drain hose ( the hose from your washing machine to the drain in your wall) was ...
65 lb Capacity UWN065T4V - UniMac
unimac.com/products/unimac-washer.../high.../65-lb-capacity.aspx
A description for this result is not available because of this site's robots.txt - learn more.
e OP error - YouTube
Dec 15, 2015 | Washing Machines
On a unimac dryer what does the code AF/-2 mean?
Air Flow switch failed to close after cycle started
Nov 04, 2015 | Dryers
Unimac dryer is now dead. Before it died a load crackeling noise was coming from the definite purpose contacter. Then the dryer died. Replaced contacter and bus fuse and dryer is still dead. Any...
Check to see if you have power to the coil on the contactor is what I would do. Might be a bad coil on the contactor also if power is going to that coil.
Dec 09, 2013 | Dryers
Unimac washing machine is displaying FULL & cant open the door
Try unplugging the machine for a few hours to rest the code on the board.
Oct 14, 2013 | Unimac Parts Unimac 1300757 Washer HOSE,...
Need AC Drive for UniMac washing machine
Contact Laundry Systems of Nevada. They are a Unimac dealer.
Aug 07, 2013 | Unimac Parts Unimac G581P3 Washer KIT,...
Saturn pumping gas problems
try pulling the filler out of the neck a bit
Mar 10, 2012 | 2001 Saturn L-Series
The dryer keeps shuting off and saying check filter
Check the rear exhaust vent at the bottom back of the dryer. If it is clogged it can cause the dryer to "overheat", that is ... if the vent is clogged with lint and debris a fire could start if there was enough heat.
Please rate this answer for me. Thank you
Mar 26, 2010 | LG DLE5977 Electric Dryer
KEEPS SHUTING DOWN AFTERYOU START IT
check the igniter, maybe it is not hot enough anymore. it needs to glow white not orange. if it is orange change it.
Oct 24, 2009 | General Electric DWSR463GGWW Gas Dryer
Open Questions:
Dryers Logo
32 people viewed this question
Top Dryers Experts
