Question about The Toys
I need battery cover and screws for the smaller Butterscotch show pony.52914. Reg.#PA-282. Where can I get one?
SOURCE: i need to replace an ear on my Butterscotch pony
Were you ever able to locate an ear for this horse? Hasbro doesn't sell them anymore... I need one too, so if you found a source, PLEASE SHARE!!! Best of luck!!
Posted on Dec 16, 2009
  • 8 Answers
SOURCE: The tail broke on my butterscotch pony and I would
Had the same problem and the fix is easy. Hopefully, the tail snapped off at the base of the plastic plate on the tail. If so, go to a hardware store and buy 1 ft. of plastic tubing with 1/4" inner diameter and 3/8" outer. Cut off a piece about 1 1/2". Now, look at the base of the tail and you should see a small screw that holds in what remains of the stub that broke. Unscrew the screw and remove what is left of the stub. KEEP THE SCREW. Now drill a small hole thru the plastic tube about 1/8" from the end. This will later be inserted into the tail and the screw will go through the hole. Next, take a hair dryer and heat the undrilled end of the tube to soften it and push it on to what is left of the broken stub inside the pony. It will be a tight fit which is what you want. The end of the tube with the hole should be just visible. Now slide the tail over the end of the tube and insert the screw. I just did it today and it works good as new! If the tail is too far away from the body of the pony, carefully remove the tube and shorten it. Since you bought a 1 ft. tube, you can have several trys to get it right! Total cost for the tube was 21 cents. Good luck! Kip V. Tryon, NC
Posted on Jul 23, 2010
  • 8 Answers
SOURCE: Looking to repair the tail on Butterscotch pony
Had the same problem and the fix is easy. Hopefully, the tail snapped off at the base of the plastic plate on the tail. If so, go to a hardware store and buy 1 ft. of CLEAR plastic tubing with 3/16" inner diameter and 5/16" outer. Cut off a piece about 1 1/2". Now, look at the base of the tail and you should see a small screw that holds in what remains of the stub that broke. Unscrew the screw and remove what is left of the stub. KEEP THE SCREW. Now drill a small hole thru the plastic tube about 1/8" from the end. This will later be inserted into the tail and the screw will go through the holes. Next, take a hair dryer and heat the undrilled end of the tube to soften it and push it on to what is left of the broken stub inside the pony. It will be a tight fit which is what you want. You will probably need to twist the tube gently while applying firm pressure on it to make it slide over the stub. The end of the tube with the holes should be about even with the outside top of the white plastic hole and the tube holes should be level, looking at it from side to side. This makes the alignment of the screw hole to the tail correct. Now slide the tail over the end of the tube and insert the screw. I just did it today and it works good as new! If the tail is too far away from the body of the pony, carefully twist and remove the tube and shorten it. Since you bought a 1 ft. tube, you can have several trys to get it right if you cut it too short! Total cost for the tube was 21 cents. Good luck! Kip V. Tryon, NC
SOURCE: My butterscotch pony's head doesn't look to its
We have the same problem only we were able to remove the zipper (with screwdriver and cursing). Still cannot get it to turn its head other way and consistently go into ride mode. Did you find anything to help?
Posted on Dec 25, 2010
  • 6 Answers
SOURCE: where can i get replacement parts for
I have had similar problems with toys myself. Seems as if when I am sure that my boys are done with a toy and it is long forgotten- it resurfaces needing some tlc... Here is a link to get the battery pack and cover. I would also suggest checking auction sites, as I have been able to find elusive little plastic parts of helicopters there too :-) Best of luck, and looking at Butterscotch; I would love her too!
http://www.hasbro.com/customer-service/orderform.cfm?sku=76471
Posted on Mar 24, 2011
Butterscotch pony head not working
First, calling poor Grace at Hasbro will provide fruitless. Hasbro does not make any parts for the full size FurReal Ponies, they have nothing in stock and cannot help you. I, however, can. I am going to post a link to a distressing site that turns the normal FurReal Pony into a fire breathing demon. However, in the process, you can see the diagram of the skeleton of the pony and head. You can search for other links but this is pretty comprehensive. Just don't open when kids are around.
Lisa
http://www.instructables.com/id/Make-a-Fire-Breathing-Animetronic-Pony-from-FurRea/
Dec 08, 2013 | Hasbro Furreal Friends Butterscotch Pony
Where can i get replacement parts for butterscotch? bought at sam's 3 years ago Kids now really into horses and of course our pony needs a few things. battery pack, tail, brush, and carrot any help?
Mar 24, 2011 | Hasbro Furreal Friends Butterscotch Pony
My butterscotch pony's head doesn't look to its right, only left, won't go into ride mode, and I pressed the button on the zipper to release it so I could take off the head cover but it won't release.
Dec 18, 2010 | Hasbro Furreal Friends Butterscotch Pony
Dec 01, 2009 | Hasbro Furreal Friends Butterscotch Pony
I need to replace an ear on my Butterscotch pony
Sep 06, 2009 | Hasbro Furreal Friends Butterscotch Pony
Computer novice--hasbro battery
Once you backout the retaining screw, put your fingers in the gap between the battery compartment and the switch. Push the battery compartment to the rear of the pony then you can remove it.
Jan 15, 2009 | Hasbro Fur Real Friends Smores Pony
Toys Logo
Top The Toys Experts
Jennifer Rock
Jennifer Rock
David Payne
David Payne
Are you a The Toy Expert? Answer questions, earn points and help others
