Question about Kenmore Washing Machines
I have a Kenmore 110 44932 200 washing machine. When the drum spins it sounds like there is something caught between the walls. At a high speed it make a loud noise. How do you get between the walls
  • Kenmore Master
  • 5,323 Answers
I have a Kenmore 110 44932 200 washing machine. Wh - 26396266-mnt2j1hw3gokxjshdcwwfxa2-1-0.jpg
26396266-mnt2j1hw3gokxjshdcwwfxa2-1-2.jpg I have a Kenmore 110 44932 200 washing machine. Wh - 26396266-mnt2j1hw3gokxjshdcwwfxa2-1-5.jpgt/uploads/images/26396266-mnt2j1hw3gokxjshdcwwfxa2-1-5.jpg" alt="26396266I have a Kenmore 110 44932 200 washing machine. Wh - 26396266-mnt2j1hw3gokxjshdcwwfxa2-1-9.jpg"h_mi" />
  • 19 Answers
SOURCE: washing machine will not spin makes loud humming noise
motor coupling needs to be replaced
Posted on Nov 05, 2007
SOURCE: Three day old Indesit washing machine
Is it a maytag? My maytag front load washing machine had 2 long bolts with plastic braces on them, to keep the drum still during shipping. Mine would bang and shake all over. I got the book out before I finally figured it out. I had to take the back cover off and remove the bolts and plastic braces over them. They look like they' 8 inches long or so. It works great now.
Posted on Jul 15, 2008
  • 2651 Answers
SOURCE: Rattling noise during high speed spin
sounds as if you might have a bad rear bearing, real obnoxious almost painful to listen too kinda sounds. big job, but might have some part warrentee depending on age of unit
Posted on Oct 21, 2008
SOURCE: Kenmore Oasis Washing machine makes noise during Spin cycle
with the machine empty see if you can lift up only the tub and see if it drops down.check to make sure there is nothing between the tub and outer tub have you gotten an f-51 error?
Posted on Nov 11, 2008
  • 11896 Answers
SOURCE: Very Noisy Operation
you will have to access the bottom of the agitator from the back of the machine. Either you have loose bolts or else you agitator bearings are shot
Posted on Jan 28, 2009
My Kenmore Elite Quiet pak 2 # 11045872402 HE3 washer doesn't go through the complete Cycle it stops when drain and spin,or doesn't Tumble through the cycle? could I have confused it by trying to keep
Spinning is prevented when the cover is open. Possibly a broken "door closed" switch is or its wires are broken. Lift the lid platform and check the switch. May be just debris preventing it from engaging. Remember, the lid and the close switch must be engaged before the control circuit will allow the high speed spin from happening. This is an essential safety feature and should never be circumvented. A high speed drum can literally pull an arm from its socket if caught so make sure it's working properly
Feb 16, 2017 | Kenmore Washing Machines
On spin cycle sounds like change or rocks spinning around in drum.
Could be a bad bearing or something loose on the drum that doesn't rattle until you get up to spin speed. Look for something like pins, nails or screws stuck in the holes of the drum, or possibly under the protuberances (fins) inside the drum. Does the sound occur all through the spin cycle or only at top speed?
Jul 08, 2015 | Washing Machines
It drains very slowly and it makes a high pitch sound when it does spin...sometimes you hear something tapping or slapping, likesomething is stuck.
To me it sounds like you have something stuck in your pump. I would check that first. I had the high pitched sound during the spin cycle on my machine and it turned out to be the drum bearings. That part used to be covered by a 10 year warranty but not anymore. My machine was less than ten years old and it cost me around 300.00 to fix it. I have paid for my machine 3 times over in repairs. My next washer will NOT be HE and probably an old school Speed Queen
Apr 08, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
If your bearings are bad, the drum will not get up enough speed to drain the water adequately. Friction from bad bearings slows down the drum. Replace bearings. DW
Mar 10, 2014 | Kenmore Washing Machines
Final high speed spin very noisey
Something is causing the drum to be way out of balance. Does it bang and make noise when it's spinning empty? Probably not. Is something stuck on the side (inside of course) of the drum, causing it to shake when spinning? If not, a spring or shock absorber (connecting drum to sides, bottom or top of machine) has broken or come loose.
Nov 23, 2013 | Malber WD1000 Front Load Washer/Dryer
I have a Kenmore 417.44102300 front load washer. Yesterday as it approached final spin the drum was spinning at top speed as it usually does and all of a sudden it was like something let go and it started...
Possibly a broken bracket we see this happen frequently, with this type of model the parts are kinda high for this repair, look at picture in bubble.could be the shocks I don't think so.fgonzalez278.png
Mar 10, 2011 | Kenmore 44102 Front Load Washer
Hotpoint aquaries wf321 is making a loud clicking/knocking noise when its in the spin cycle, to me sounds like a poss bearing gone or maybe something is caught up?
From the front of the washer, spin the drum by hand, if it feels rough or is noisy or rumbling, then the drum bearings have failed.
It is possible that there is something caught between the inner and outer drum.
Nov 30, 2010 | Hotpoint Washing Machines
Kenmore mod. #417.44092500 high speed spin doesn't
replace speed control board located right rear base of unit
Sep 12, 2009 | Kenmore Washing Machines
Something rattling under the drum
Strangely enough, I found the problem to be in the motor. If the noise becomes pronounced during the high speed spin cycle, then that is the problem. I had a repairman out for mine and they wanted to replace the drum, however when I took off the back and removed the belt, I could turn the drum separate from the motor and could hear that the problem was in the motor bearing, not the drum. Hope this helps.
Nov 18, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
Sal De
 Brian Main
Brian Main
