Question about Garden
Sears snowblower without side skid plates hard to push . Why
2 Suggested Answers
  • 51307 Answers
SOURCE: Fix the skid on my Toro snowblower
if there is a nut and bolt to loosen , it is probably rusted up
heating the bolt ( if possible and then spraying wd-40 or other rust penetrate will beak the rust seal and allow the nut to come loose
take it to a mower shop for the fix
Posted on Oct 26, 2016
Oct 26, 2016 | Refrigerators
Model # 627804x79a. Spirit snowthrower. How much oil does it take?
what does the manual tell you about engine oil
Nov 24, 2015 | Garden
Troybilt snow thrower wheels lock up cannot push or pull. Model 5524. Whats up?
Sounds like friction disk is not retracting for pressure plate. Flip snowblower up on front end and take out 4 or 6 bolt out of cover plate. wheels will be in the air so try to turn wheels and look. Your fiction disk is the rubber wheel that moves with you gear shift lever. It should not be touching round metal plate unless your handle on bars is push down to in gage drive. Most snowblowers have a spring to pull metal plate back your probably broke or rusted off.
Feb 24, 2015 | Garden
How do I change auger drive belt
First remove the spark plug wire, then either drain the gas, or put some plastic over the gas tank opening, and put the cap over it. This should prevent gas from coming out of the vent when you tip the machine. Then follow these steps:
1. Remove the cover that goes over the belts on top of the machine just behind the sheet metal auger housing.
2. Tip the snowblower forward so that it rests on the front of the machine. This will allow you to remove the bottom skid plate.
3.Remove the skid plate.
4. There should be a spring that holds the belt-tensioner against the belts. remove one end of that spring so that the belt-tensioner can move out of the way easily.
5. Now it should be possible to remove and replace the belts. Put them on the bottom pulleys first, then you should be able to get them onto the engine pulleys.
From there, replace the tensioner spring and skid plate. Put the snowblower back on it's wheels and check the operation of the auger handle to make sure the tensioner is operating properly. Once you are happy with everything, replace the top cover. Be sure to remove the plastic from under the gas cap, refill your gas tank, and put the spark plug wire back on.
Feb 13, 2015 | Garden
How to remove skid plates on2012 hyundai genesis
each push-pin type has two parts. If you pull the center portion of the fastener out of the outer portion and then gently pry the entire fastener from the hole in the frame. and of course use the appropriate size socket and ratchet for the remaining bolts, then you're styling. Good luck
Aug 10, 2012 | 2012 Hyundai Genesis
Amana washer mod # nav2335aww hums when operated. By turning the agitator I can Kick start the spin cycle. When I stop it and try to restart it it just hums.
Hi and welcome to FixYa, I am Kelly.
I am pretty sure that the skid plate the motor sits on is sticking in place vs sliding / being spring loaded with tension. If the skid plate is causing the motor not to float you will have the symptom you describe. I am talking about item 29 this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174283
Additionally any broken parts (item 6 - 13) can also cause the symptom.
A skid plate sticks in place from corrosion or debris build up between the machine base and the motor skid place clean things up as best you can and make sure the motor floats / glides. It should work properly after that.
You may just be able to squeeze the belt to cause the motor mount to glide and float without taking anything apart. If you can... lubricate the skid plate area from the bottom before opening the front panel.
Thanks for choosing FixYa,
Kelly
Jun 17, 2011 | Washing Machines
My 9hp sears snowblower doesnt through snow anymore and the belts are fine. I have tried tightening the cable for the auger lever with no success. Is there a friction plate to change ??
Usually on the bottom of those there is a scraper plate on the bottom behind the auger this is made to wear out check to see if needs replacing.
Mar 09, 2011 | Craftsman Garden
Where can I get an owners manual for a Sears snowblower Model C459.52832? I have tried Sears Direct with no luck.
Is this a canadian model? If it is a U.S. model the model number will look like 123.123456. Please look at you name plate again.
Jan 16, 2011 | Craftsman Garden
Screws on my Sears track drive snowblower unthread themselves.
Back wheels have a gear that connects to the drive chain. on each side. those spin.
The front ones which are Idlers do not spin as the idler wheel as a bushing in it that allows free motion on the shaft without resistance. Use a nylock nut with Locktight for starters. The try that.
Hope this helps. -Jeff anchorage small engine repair.
Feb 02, 2009 | Craftsman 16" High Garden Tractor Snow and...
Replace sheerpin on snowblower
Go to sears and ask tell the salesman whats wrong. he will tell how to fix it, sounds like you need a shear pin.
Jan 19, 2009 | The Learning Company Black & Decker...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
