Sony Handycam CCD-TR5 stopped responding suddenly. I bought new tapes for the camera and it recorded a short amount of footage before the Caution light flashed and the footage stopped.
The camera was in perfect working order. Playback worked and I could see through the viewfinder. But as soon as I put in a new tape, the camera recorded for 4 seconds and the caution light blinked and the footage glitched and shut off. Now the camera won't respond when plugged in to the DC cable or with a battery. The battery has been tested and it's good and my camera is in Standby mode. It shows blinking zeros on the screen by the power buttons but will not start playback or record. I also cannot see through the viewfinder. It also will not eject the new 8mm tape.
Though 8mm filming was and still is the best safest way to make movies Sony have stopped producing 8mm tapes, I use the brand new Digital 8 tapes on my brand new Sony camera, would never dream of going over to Hard drive/SD card/DVD recording cameras as the image will not last as long as it will on 8mm tape. Also the 8mm cameras are much better made than anything since 2006. If you type 8mm movie tapes in your search engine you will find 100's of firms still selling your tapes, they will help you choose the right one ok?
no that u must remove ur camera and try to clean all strip that connect with board and mechanisum and all connectors legs solder then it will work .any doubt call u.a.e no 00971503853766
i just read about this c:31:22 problem while looking for a solution to another problem I am having. Someone suggested removing the battery, switching the camera to the "camera" setting, and then turn it off, put the batter back in and it should work. Good luck.
You will have download your analog video to the computer by accessing the utility on the computer programs. Make sure you select the NTSC format on the computer then upload the video to DVD recording. If our camera has S-video output, use this for better resolution
There may be several reasons for this, - the unit may not be pulling the tape through the transport mechanism because of tape binding in the cassette. Or there could be excessive oxides built up on the captstan. If you can, remove old tape and try a new one. In either case, you should get unit cleaned and checked by a qualified tech.
Look for the output jacks on your camera, hook them to your computer's audio/video input. Try accessing the recording utility on the computer then upload footage through NTSC format. You can then edit the footage. If your camera and computer utilize S-video, use them for best resolution
Head alignment (re-aligning the tracks) is not something we as owners can undertake - it has to be done professionally.
You can however quite safely clean the heads by using one of the dry cleaning tapes sold for the purpose. I have used an 8mm/Hi-8 cleaning tape made by TDK for a number of years with good results. Remember that if your heads are dirty both recording and playback will be affected and once you have cleaned the heads you need to test the camera by recording new footage and then playing it back to see if matters have improved. Good Luck.
CCD sensor problem ( that you can play back but have no image in capture mode is typical of this common problem ). Sony might do this repair free of charge because properly manufactured CCD sensor should last 10 years+ .
