Lightning strike - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 8,204 Answers
When and How Should a Surge Protector Be Used on a Fixed Switch?
Common Causes of Lightning Strikes
  • Outdoor network cables or power cables are routed overhead.
  • A switch is deployed outdoors but is not properly grounded.
Damages of Lightning Strikes
  • If power cables of a switch are routed overhead in an outdoor environment, lightning strikes may burn the power supplies.
  • If network cables of a switch are routed overhead in an outdoor environment, lightning strikes may burn interfaces of the switch.
When a switch undergoes lightning strikes, overvoltage is induced by lightning on network cables and transmitted to interior of the chassis. The surge protection measures, such as lightning rod and chassis grounding cannot prevent the damage. Therefore, surge protectors or surge protection circuits are recommended.
Surge Protector Use Precautions Take the following precautions to protect a switch from lightning:
  • Ensure that the ground cable is connected to a ground bar or a ground point on the cabinet.
  • Avoid routing cables overhead in an outdoor environment. Bury cables underground or route them in steel tubes.
  • To protect network interfaces against lightning, use 8-line surge protectors (or Huawei certified 4-line surge protectors).
  • When installing a network interface surge protector, connect the IN end to terminals and the OUT end to network interfaces of the switch.
If a fixed switch is installed in a network box, follow these instructions:
  • Connect the ground cables of the switch and surge protectors to the ground bar in the network box.
  • The maximum length of a ground cable cannot exceed 40 cm, and a length of smaller than 15 cm is recommended.
  • If the network box is located outdoors and power cables are routed aerially over a long distance (more than 300 m) to the network box, it is recommended that you install a power supply surge protector in the network box. The decoupled power cable must be at least 3 m long
S2300 Switch Thunder link com
Dec 08, 2016 | Office Equipment & Supplies
Had Lightning strike. TV box destroyed and tv does not get power. Which boards may need to be changed?
The power supply board is the first board to feel the impact of a lightning strike.. Try that one out first.
Jun 21, 2016 | Televison & Video
Why does the battery level icon show only a "lightning strike" symbol?
Lightning Strike Symbol means that the battery is charging.
If it is shown even when it is not charging then your charging circuit needs to repaired. Just replace the charging IC not a very high cost. Might cost around 5-10USD.
May 24, 2014 | Amazon Kindle Paperwhite
Will a nearby lightning strike cause a power board failure?
It could happen yes it would depend where the strike entered the TV. Not all lighting strikes hit on the electrical lines, on a TV they can come through the cable, as well as a antenna if you have one hooked up.
May 10, 2014 | Samsung UN32EH4003F
Lightning strike, blows internal fuse (6.3v 125/250) on plug in.
sounds like the lightning strike took out at least the power supply if not more. sorry to be bearer of bad news.
Oct 31, 2010 | Toshiba 24AF41 24" TV
Flashing stike laptop won't start
lightning strike usually is battery indicator try charging/replacing battery also battery might be dead and ac adapter broken
Jul 06, 2009 | Computers & Internet
Lightning strike and tv picture messed up
This unit needs to be sent or taken in to a service center for complete testing and service. The lightning strike has caused a component failure, in the main board of the television. This is the board that controls all the functions of the television. The customer service telephone number for Insignia is 1-877-467-4289. You can also go to the website Go to the customer support section and ask them for help getting you television evaluated and serviced. I hope this information helps you solve your problem.
May 18, 2009 | Insignia 37" LCD Flat-Panel HDTV
Compac presario 2200
There is a high probability that your laptop has been fried, especially if it was plugged into the mains at the time of the lightning strike.
A lightning strike could damage many components and even if you could get it fixed (most likely require a motherboard replacement) there are no guarentees that some other component won't fail in the future.
If it was me, I would put my money towards a new laptop and get a surge/lightning protection power board and disconnect the laptop from the main during a lightning storm.
Jan 07, 2009 | HP Compaq Presario 2200 Notebook
Surge from lightning strike damaged tv and won't turn on.
Unless you are skilled at trouble shooting power supplies , you will be better off getting a skilled repair center to repair yourset. If its repairable I have seen surges from lightning strikes make the set no longer cost effective to repair.
Jun 18, 2008 | Televison & Video
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
