Question about Home Security
I have a afre safe. when i put in the correct code the screen display open but i don't hear the lock open. directly after that the screen show err1
  • 17 Answers
SOURCE: Radio Locked Up, due to wrong code entered.....
Leave the radio on for one hour and the radio will reset. Works on all locked Mitsubishi radios. Dont go opening up the radio for no reason....
Posted on Jul 15, 2009
  • 484 Answers
SOURCE: err1 when i put cd in and it spits it out frrrrustration
If it is a CD-R, chances are your stereo is too old to play it. If it is not a CD-R, but a regular CD, then it's probably either a dirty lens (you can buy CD lens cleaners almost anywhere) or a bad CD.
Posted on Sep 13, 2009
Testimonial: "Thanks, I'll try and clean it cause it does this with new cds also."
SOURCE: I purchased a new Sentry
(1) sounds like the interior lock activation screw is still installed. it's the long screw on the inside of the door with the yellow tag; (2) when entering the code, make sure the key is turned to the right; (3) after entering the code, make sure you next press the program button. enter the code wrong three times and it locks up for two minutes.
Posted on Sep 13, 2010
  • 11 Answers
SOURCE: Have an electronic safe, am
Red light means low batteries. the only thing that worked for me was heating the safe to help the batteries recover a bit and it opened!
Posted on Mar 14, 2011
  • 78 Answers
SOURCE: I have cs-2 safe the key is inside and safe is
Call the company and get some information from them
Posted on Sep 28, 2014
My safe, a Cathedral EA15 Will not lock. Any suggestions people?
Instructions
  1. 1
    Enter your code on the keypad located on the front of the safe. Some electronic digital safes require you to input a special character like "#" before and after your code. The safe should either beep, have a LED turn green, or display "OPEN" if you have correctly entered the code.
  2. 2
    Turn the handle to the right within five seconds of correctly entering the code. If you wait too long, the safe will lock and you will have to enter your code ag
Open the safe with a key. Use your emergency key that came with the safe to open it if you forgot the code or if the batteries have died. Remove the key cover from either the handle or the control panel to reveal the lock.
  1. 1
    Enter your code to open the safe.
  2. 2
    Place the electronic digital safe into code reset mode. On some models you need to hold the last digit of the code or press the "*" button to get into code reset mode. Other safes require you to open them and press a small red button on the inside of the door.
  3. 3
    Enter your new code on the keypad and press "#" to finish. Some safes may require you to press "*" or a letter to finish the code. If the safe requires it, enter the new code again to confirm that you entered it correctly.
  1. 1
    Use your code to open the electronic digital safe's door.
  2. 2
    Locate and remove the battery cover on the inside of the door.
  3. 3
    Replace the used batteries with new ones. For most safes, this will require two or four AA batteries.
  4. 4
    Test the batteries. Use your code while the door is open to test the batteries before closing the safe.
Feb 08, 2015 | Locks & Locksmithing
I push in the wrong radio code 3x on my 2001 audi now its stuck on safe mode and wont let me in to push in the right code
First of all you should exit from safe mode. Then turn ON the radio and let it turned ON for at least one hour, in order to exit from safe mode.
IMPORTANT NOTE:
You must have the security anti-theft code for your VW radio from the car manufacturer, or from a VW dealer!
You can find the radio code at: http://www.radio-code.co.uk/
The sequence of a 2001 Audi Concert radio programming is:
1. Push simultaneous "SCAN" and "RDS" keys until on the screen will appear "1000" displayed.
2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt.
For example: we have the security code "5079". Then:
3. By the no.# 1 key you will set up the first safe code digit. Push 5 times on the no.# 1 button. The "5" number will be setted.
4. By the no.# 2 key you will set up the second safe code digit. Push 10 times on the no.# 2 button. The "0" number will be setted.
5. By the no.# 3 key you will set up the third safe code digit. Push 7 times on the no.# 3 button. The "7" number will be setted.
6. By the no.# 4 key you will set up the four-th safe code digit. Push 9 times on the no.# 4 button. The "9" number will be setted.
7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed.
The radio is now ready for use!
Audi Delta CC Radio
Please perform the following procedures while the car is parked. Otherwise you risk getting into an accident while your attention is not focused on the driving. Entering anti-theft code The following is the procedure to re-activate the radio if the display shows "SAFE". It is important that the procedure be followed in the correct order.
  1. Turn on radio. The radio display shows "SAFE".
  2. Press the FM1/2 and DX buttons simultaneously and hold until "1000" shows on the display. Release the buttons. Do NOT press these buttons again, otherwise the radio will consider "1000" to be the code.
  3. Use Preset buttons 1 ... 4 to enter the four-digit code number from your radio card. Preset button 1 corresponds to the first digit, Preset button 2 corresponds to the second digit, etc. Each press of the button increments the number by 1.
  4. Once the code shown on the display is correct, press the FM1/2 and DX buttons simultaneously and hold until the word "SAFE" appears in the display, then release the buttons.
  5. The radio should unlock and be usable shortly afterwards.
  6. If an incorrect code is entered, the word "SAFE" appears, first flashing and then continuously. You can repeat the above steps to unlock the radio once more, the number of attempts will be shown in the display. If an incorrect code is entered again, you radio will be locked for about one hour. After one hour - the radio must stay on and the key must remain in the ignition lock - if the display goes out, the you can repeat the above procedure to unlock again. The cycle - two attempts, one hour lock-up - still applies.
Oct 27, 2011 | 2001 Audi A6
What buttons do you hold to unlock stereo for 2001 audi Ty
IMPORTANT NOTE:
You must have the security anti-theft code for your Audi Concert radio from the car manufacturer, or from an Audi dealer!
The sequence of programming for a 2002 Audi TT Concert radio is:
1. Simultaneously push "SCAN" and "RDS" keys until on the screen will appear "1000" displayed.
7. Then simultaneously push again "SCAN" and "RDS" keys to confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed.
The radio is now ready to use!
Audi Delta CC Radio
  7. If you lose your radio code, contact your Audi dealer.
Oct 14, 2011 | 2001 Audi TT
I got an Audi TT Turbo Model 2000 The radio Bose Audi concert is giving safe on the screen and nothing else what should I click on to reset the radio so I can put the code.Thanks
  2. Press the FM2 and RDS buttons simultaneously and hold until "1000" shows on the display. Release the buttons. Do NOT press these buttons again, otherwise the radio will consider "1000" to be the code.
  4. Once the code shown on the display is correct, press the FM2 and RDS buttons simultaneously and hold until the word "SAFE" appears in the display, then release the buttons.
May 29, 2011 | 2001 Audi TT
Hi I got a 2002 audi a6 the radio displays safe but even if I keep scan and rds buttons pressed nothing happens.wat is the solution
it depends on year of car and make of RADIOHERE IS THE SETTINGS FOR A 2002 AUDI A6 Quattro V6 2.7L Turbo (APB) engine code
For the Audi Concert Radio
YOU STILL NEED YOUR RADIO CODE TO ENTER THIS!!!!!!!!!!!! tell me if this work for you
Entering Anti-theft Code
Note: Some European market Concert radios have a TP button instead of the FM2 button, so the description above with those units would require pressing the TP and the RDS buttons simultaneously.
Dec 03, 2010 | 2002 Audi A6
I purchased a new Sentry Safe, Model CSW 4747 yesterday. When I unboxed the safe, the safe was open, the lock handle was down, cyclinders were a little pertruding, and the lock cyclinder was popped out. ...
Sep 11, 2010 | Office Equipment & Supplies
Unlock procedure for vw/audi
audi gamma cc type
1e2fb0f.jpg The following is the procedure to re-activate the radio if the display shows "SAFE". It is important that the procedure be followed in the correct order.
  2. Press the FM1 and AM buttons simultaneously and hold until "1000" shows on the display. Release the buttons. Do NOT press these buttons again, otherwise the radio will consider "1000" to be the code.
  4. Once the code shown on the display is correct, press the FM1 and AM buttons simultaneously and hold until the word "SAFE" appears in the display, then release the buttons.
audi delta
Mar 29, 2010 | 1997 Audi A4
I bought an Audi A3 secondhand with audi chorus Blaupunkt-WERKE GMBH 7648 245 380 SERIEL NO AUZ1Z2X678588 ,the radio is on a safe mode please help me with the code and the method to enter the code
You must retrieve the code that comes with the Audi's radio unit. To change to safe mode:
  2. Press the P.Scan and RBDS buttons simultaneously and hold until "1000" shows on the display. Release the buttons. Do NOT press these buttons again, otherwise the radio will consider "1000" to be the code.
  4. Once the code shown on the display is correct, press the P.Scan and RBDS buttons simultaneously and hold until the word "SAFE" appears in the display, then release the buttons.
Sep 12, 2009 | Car Audio & Video
I have a 1999 Audi A6.
Mar 02, 2009 | 1999 Audi A6
Factory code will not open model # DA3831 safe
i am a locksmith that has worked on several of these. The safe is manufactuered with three types of lock mechanisms 1. combo dial 2. digital 3. advanced digital the advanced digital is what you have there are no green lights on it. look at the manual carefully there are 2 seperate sections on the digital key pads yours will be the second.
Nov 23, 2008 | Sentry Fireproof Safe
Home Security Logo
49 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
