Question about Sony (DDU1613) (ddu1613black) Internal DVD Drive
Sony DVD-Rom DDU 1613 will not burn DVD locks up
It has worked in the past but is not now
Re: Sony DVD-Rom DDU 1613 will not burn DVD locks up
A dvd ROM is not a burner it would burn if if was a r/rw
Posted on Dec 19, 2007
  • 244 Answers
Sounds your laser damage. Try to open and clean the laser but I will not recommend you to do it by yourself but that's your decision.
Posted on Nov 21, 2007
0 characters
3 Points
Sony DVD-Rom DDO 1615s not ejecting
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have physicall unplug the dvd drive from your computer restart the plug it back in this should activate the found new hardware wizard
hope it helps
Feb 19, 2012 | Sony DDU-1615 / 16x DVD-ROM / 48x CD-ROM /...
MY PC has sony DVD-ROM DDU1615 that I can't record my videos onto a dvd
you cant burn a disk with a dvd rom
you will need both a dvd rw unit and a dvd rw disk to burn any video to a disk if you have both of these the burning program might not support video burning or you might not have selected the right option there are lots of free burning software programs that can burn videos to a disk you might have to burn it as an ISO image
BurnAware Free is one of the most popular free CD, DVD, Blu-ray Disc burning software available for Windows.
Using this program you can easily create and burn Audio and MP3 CD, Data and DVD-Video disc, ISO and Cue Image,
erase or format rewritable disc, copy your CD or DVD to ISO image.
hope this helps
Jul 21, 2011 | Sony DDU-1615 / 16x DVD-ROM / 48x CD-ROM /...
My sony DVD-ROM DDU 1615 does not play DVD video or record my videos onto dvds.
If you want to just PLAY DVD movies with your current setup, then try downloading and installing a free program called VLC MEDIA PLAYER from WWW.CNET.COM which will let you play DVDs on your computer.
Here is the direct link to their download page where you can read about the software, check out other user's reviews, and download it free if you want:;productListing
I use this free progarm on my computer and it works great.
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated.
Then just click on the DOWNLOAD NOW (19.42 MB) button that you see on the left hand side of the page.
Then follow the onscreen instructions to download and install the program. Be sure to click on the yellow security bar at top of the page if necessary to ALLOW DOWNLOAD.
However, if you want to actually BURN videos onto recordable DVDs, then you are going to have to go out and buy a bit of new hardware.
The ROM part in DVD ROM stands for READ ONLY MEMORY. That means your disk drive can only READ DVD disks, it is unable to BURN (record) onto disks. For that you will have to go out and buy a DVD RW disk drive. They look exactly the same as yours, but are a few bucks more, and they have the extra capability of burning files onto blank recordable DVD disks (DVD-Rs).
Please comment back here to this page if you have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
Thank you very much, good luck, and take care.
It doesnt appear on my computer
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Hope this helps
Jun 03, 2011 | Sony (DDU-1613-B2) Internal DVD Drive
My cdw/DVD (Sony CRX230E) player will not play movies or home made movie
Control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
hope this helps
Jan 08, 2011 | Sony DDU-1615 / 16x DVD-ROM / 48x CD-ROM /...
My sony dvd rom is not displaying on my computer., for example G drive. So i am not able to read and write any dvd.
check the communication cable are inserted or not, you can see it to open the cpu cover and look for the same, there are two cables are inserted in dvd/cd rom first for the power and second for data. if you find all the things are ok you can check it from your BIOS settings.
Jun 07, 2010 | Sony DDU-1615 / 16x DVD-ROM / 48x CD-ROM /...
Try to burn a cd
Hi, make sure that you have the right type of CD or DVD in the burner. From what you have written about what you drive is it is a "_" not a "+". It actually makes a difference. You may have acidently bought the wrong type for your burner and this will bring up that error.
Check your CD's and give that a go.
Oct 27, 2007 | Sony DDU-1615 / 16x DVD-ROM / 48x CD-ROM /...
Sony DVD Rom DDu1622 reading problem
the only info for you is got to this link and download the frimware again and update if all fails get another dvd rom or writer and don't update firmware at all good luck on this one
Apr 27, 2007 | Sony (DDU-1613-B2) Internal DVD Drive
Insignia D400, new Radeon 9250, Sony DDU 1613 not working
you need windows professional or vista the reason the game runs slow is you need at least 1 gig of ram as the operating system takes 256mb to run this is why the game recomends 2.0 ghz cpu or higher 1gig of ram or higher the graphic card recomended NVidia Geforce 512mb xfx series with pixal shading and dx 9c compatable. clean the dvd lens with a dvd lens cleaner. the motherboard maybe the cause to the iso-13346 specification as the game is designed on intel and amd processors. hope this will give you help
Apr 23, 2007 | Sony (DDU-1613-B2) Internal DVD Drive
Sony (DDU1613) (ddu1613black) Internal DVD Drive Logo
254 people viewed this question
Top Sony DVD/Blu-ray Drives Experts
Brian Sullivan
Brian Sullivan
isaac johny
isaac johny
Are you a Sony DVD/Blu-ray Drive Expert? Answer questions, earn points and help others
