Question about Kenmore Refrigerators
Kenmore side by side fridge the ice maker is making ice but only dispences1 to2 times a day i hear and see the gear moving back and forth whats up?
  • Nater13 Dec 13, 2016
    If the heater that is mounted to bottom of the ice mold is not energizing, the harvest will not be able to separate the cubes from the mold... MODEL NUMBER?
SOURCE: ice maker broken
Our is broken as well. Water dispenser works.....
Posted on Feb 24, 2008
mikedurland
  • 481 Answers
SOURCE: kitchen aid superba fridge - ice maker not working .. water dispencer is
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Posted on Jul 06, 2008
jumptrout51
  • 3361 Answers
SOURCE: ice maker will not dispense the ice
The auger motor and coupling in the rear may be frozen and won't turn.
Remove the ice bin.
Place a screwdriver or similar device in the forks of the auger and twist counterclockwise till it moves. The replace the ice bin and try again.
It will be difficult to move.
If that does not work. Turn off the fridge and use a hair dryer to hrat the auger gear and motor till it frees up.
Posted on Mar 23, 2009
  • 351 Answers
SOURCE: Kenmore Ice Maker Not Working
Probably need a new ice maker, whirlpoolpartssurplus.com
Posted on Jun 23, 2009
  • 6 Answers
SOURCE: kenmore coldspot 106.556325 not making ice
could be your ice maker or your water valve
Posted on Aug 30, 2009
Timer ice maker kenmore side
If the timer piece you are referring to is behind the square white cover, and it's moving slightly back and forth, you should visually check the ice making area it's self to see if the ejector fingers are jammed with ice, or against the ice stripper. Ice Maker jams can be caused by reduced water pressure to the unit mainly from the water filter, your water filter in the toe kick should be replaced at an interval of 6 months to a year, regardless of filter status light. When water pressure is low, not enough water fills the unit and the undersized cubes can become lodged or stuck in the ice maker while being ejected, equally so if there is an over fill situation caused by other failures the ice maker can't eject at all. Pleazer Appliance...
Ejector fingers
Ice Stripper
Apr 17, 2014 | Refrigerators
Ice maker won't fill with water
Well the ice maker itself is what calls for water. It probably is fried. The way it works is the ice maker basically sits in the freezer and waits until the ice mold reaches 28f. When it gets to 28f the ice mold thermostat closes the electrical circuit to the heater and the motor. The motor basically stalls out because the heater hogs all the power. As the ice loosens the motor does not need as much power and manages to move the ice till you hear a CLICK and that is what kills the power to the heater and the resulting surge moves the ice on around at an astounding snail pace not unlike watching grass grow. At near the end the water valve gets energized by a probe rubbing against a copper plate located behind the main drive gear. over time it gets to where the arcing sticks the probe to the plate and instyead of 7 seconds of fill time it fills for 25 or more seconds or just smokes up the puppy and burns the tip of the probe.
Dec 12, 2012 | Kenmore Side by Side Refrigerator
Ice Maker stopped working
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jun 07, 2010 | Maytag 18.9 Cu. Ft. Top-Mount Refrigerator...
Kenmore side by side fridge - ice dispenser stopped working
You might check out this site and ask a question. They have drawings on many of the fridges and I have bought many parts from them.
http://www.appliancepartspros.com/partsearch/
Jul 28, 2009 | Refrigerators
Whirlpool Gold Refrigerator (GS5SHAXNLOO) Ice maker not running, some ice in maker melted together
I have the same model. This has happened to me several times (usually when the door was kept ajar without notice).
Simply open the door, take a common hairdryer and blow at high speed (hottest also) all around the area of where you can feel the ice in the tray, but hasn't dumped yet. It will usually take about 5-8 minutes of consistently moving back and forth around that area. What has happened is the lines bringing water to the trays have frozen over. When you "thaw" them out, the ice made will dump in about 45 minutes. When you hear the ice fall, you will know it's in working order again. I have NOT heard this is a "flawed" icemaker, only that it is hypersensitive to freezing lines when a door is left ajar. In your case, to prevent this from happening again. If you shut the icemaker off again, make SURE you turn off the source of the water feed BEFORE you turn off the ice maker. By doing this, the lines will empty as it makes it's last tray of water. Try that - very confident it will fix your problem!
May 29, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker will not dispense the ice
Remove the ice bin.
Mar 23, 2009 | KitchenAid Superba KSRS27CN Side by Side...
Arctica ice maker won't work without help
The solenold valve would not shut off completely & was leaking water on the paddle that the controls the icemaking. We replaced the solenold water valve & we now have ice!!!!! Good luck!
Feb 20, 2009 | GE Profile¿ Arctica® Energy...
Ice maker not working, water not going in tray.
Here is a tip that I wrote about the reasons why ice makers do not work.
heatman101
iuoiout
Mar 28, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Kenmore Coldspot Ice maker is not working on our side by side refrigerator
I have a kenmore coldspot side by side model # 106.53662300.
The ice maker red light is blinking and it has made very little ice in the last 24 hours. What do you think the problem is?
Jan 23, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker won't stop making ice
OK, there's two possible issues but you have to figure out what is happening. Does the ice maker continue to make ice forever and would fill up the whole freezer section in time OR does the ice maker just "over make" ice that overfills the bin which then falls out? If the ice maker just keeps making ice you need the motor module replaced but if it can be turned off by moving the lever up then you need the "modified lever assy." that is on our service bulletins.
Dec 23, 2006 | Kenmore 55693 Side by Side Refrigerator
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
