Question about Sewing Machines
What kind of thread do I use for the Expressive 820
  • Sewing Machines Master
  • 11,749 Answers
You would use sewing machine thread depending on what you are sewing. If you are embroidering, you'd probably want to use embroidery thread. If you are quilting, you would probably use cotton or quilting thread. If you are sewing garments, then you will probably want to use polyester or polyester-wrapped cotton thread.
Be sure you are using the correct needle corresponding with the thread and project. (You don't have to use Schmetz needles, but this is a great guide.) Also, change the needle often to avoid sewing problems.
Schmetz Needles Needle Guide
Posted on Dec 12, 2016
Elna expressive 900 thread breaking (although not really) and bunching up on underside of fabric ESPECIALLY when doing embroidery. Why?
try using gutermann thread and needle according to your fabric thickness and tension dial must be 3-5 and bobbin thread hold the end of the thread and bounce to see how loose the thread is cos if it releases too easy you need to turn the screw on the casing just a little see how you go
Apr 08, 2017 | Elna Sewing Machines
Elna expressive 860. how do you change the spool tension? (my top thread started looking loose on my embroidery
Make sure that when you thread the machine, that the thread is always seated completely in the tension disks. Remove the thread and rethread from the beginning.
Feb 14, 2017 | Elna Sewing Machines
What embroidery hoop does an elna 650p heirloom edition use?
I believe this model is a sewing machine not embroidery. Elna 6005 Heirloom Edition. "Expressive" Line is Embroidery/Sewing. Expressive 860 through 960.
Cheers,
Embroidery Services
San Diego, CA
Jul 07, 2016 | Elna Sewing Machines
I have an 820. The needle threader is clean of lint but still does not work
Threading the BERNINA 880e 830e 820 Bernina Sewing Center Tampa
http://www.manualslib.com/manual/726261/Bernina-820.html?page=30
Bernina 830 880 Needle Threader Cleaning
Install a brand new needle. Verify that it is installed correctly and is facing straight forward. If it is still not threading properly, then something may be bent or out of place in the threader.
May 15, 2016 | Bernina Sewing Machines
Bernina 820, quilting with the BSR foot, my machine will sometimes skip 1 to 4 stitches after going over a seam, help
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Sep 27, 2013 | Sewing Machines
Bernina 820 Tension Error Message
You need to take your machine in for service. The 8 series machines have new upper tension parts that can be installed under manufacturer warranty and MAKE SURE your Bernina dealer is well trained on the 820 and 830 or they'll never get it adjusted right. The 8 series are just all around buggars when they're out of whack.
May 20, 2012 | Bernina Sewing Machines
Sewing Machines Logo
51 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
