Question about Top Vacuums
I have the eureka- shop boss - model 2812. The blower appears to be working but the suction is very weak.
When I connect the hose for suction, the top connection still blows and the suction is weak.
5 Suggested Answers
  • 1027 Answers
SOURCE: Hose has no suction
Most uprights need to be in the up-right locked position to enable the hose pickup.
Posted on Jul 26, 2008
  • 97 Answers
SOURCE: Eureka the Boss Smart Vac.
Your belt is probably broken. Check your belt and make sure your brushroll has not seized. If both of those check out ok, (because the smartvac belt doesn't stretch,) the belt tensioner assembly may have gone bad.
Posted on Aug 11, 2008
#1 Taper
  • 1040 Answers
SOURCE: My Eureka 4870 has no suction.
The bag is full.You need to take out old bag and replace with a new bag.
Posted on Jun 10, 2009
Vac Belts
  • 701 Answers
SOURCE: looking to replace my eureka Boss central vacuum,
I would recommend the AirVac AVR7500 model. It's a great unit.
Posted on Oct 31, 2009
My eureka boss 5856 has suction through the hose, but the cyclone isn't spinning and it will not pick up anything. I have tried using it normally and with just the hose and it will not pick up.
Is the suction strong or weak?
Have you cleaned or replaced the filter?
A plugged filter will restrict air flow and cause vacuums to lose the ability to work properly.
Mar 10, 2017 | Eureka Vacuums
Eureka Optima Lightweight suction weak on bare floor, hose only works when dial is turn to floor?
I think it is normal. My favorite setting is the dial is turned to bare floor. If you set your vacuum to hose, then you need to adjust the height (do not set the dial to the bare floor).
Feb 21, 2014 | Eureka Vacuums
Eureka Smart Vac The Boss no suction from either setting. I have taken it apart trying to see if it was clogged but it isn't. Checked the hose it is not sliced.
Remove the bag cover and feel for suction above the motor. If their is suction there then check the bag compartment is sealed. You can drop a coin down the hose to check for blockages all the way to where the bag attaches.
Aug 16, 2013 | Eureka Smartvac 4870 Bagged Upright Vacuum
The suction for carpet cleaning is great but there is very little suction through the hose. I have cleaned out the hose but there is still very little suction. What else can I do?
Have you tried cleaning the hose from the vacuum end, the end that feeds the sweepings into the cannister/bag? Might be something close to that end of the hose. Also, one reason for a hose not to work is the possibility of a cut or broken hose or a loose connection. The closer an opening like this might be to the vacuum end of the hose, the less suction the unit will have through the hose as it will pull air through the hole/break easier than through the full length of the hose.
Sep 19, 2010 | Eureka 5849A Boss Bagless Upright Cyclonic...
The brush does not spin when making contact with carpeting
I tried the electrical-tape-around-the-wooden-spindle technique. After a minute or so, it's back to functioning normally.
Mar 14, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Hose has no suction
Jul 25, 2008 | Eureka 4874 Bagged Upright Vacuum
Eureka Boss - no suction in upright postion
when mine does that I find that the hose is not connected properly where it comes off to use the attachments.
If there is suction there, it is a straight shot to the floor unless it is loose where it fits together.
Jun 04, 2008 | Eureka 5892AVZ Bagless Upright Cyclonic...
Vacuums Logo
Top Top Vacuums Experts
Vernon Taylor
David Payne
David Payne
Are you a Top Vacuum Expert? Answer questions, earn points and help others
