Question about Refrigerators
My national Luna fridge won't run, it's four years old but has only done six weeks work , went to turn it on and it won't start , there's power and everything lights up ok
Noggin
  • 944 Answers
SOURCE: AEG fridge/freezer isn't working
This sounds like your fridge has a leak somewhere and it slowly discharged its refrigerant. the compressor can sustain damage when there is no refrigerant and often will hum and eventually fail. Sorry but you may need a new compressor - if you were going to replace the fridge soon anyway then i would go ahead, but a compressor and the labour to fit it etc may be cheaper than a new fridge - you need a refrigeration repair man/shop (if you can take the fridge to a repair shop it will always be cheaper than calling a guy to your house) Sorry i can't really help, but the symptoms are classic, if you are lucky then a technician may be able to fix the leak and restart the compressor, but not always if you want to try something yourself just try tapping the compressor smartly but not too hard with the end of a dry wooden or plastic stick or similar with the fridge plugged in. the compressor is the thing at the bottom in the back that looks a bit like a small fuel tank, should be right in the middle and will be the largest thing in there. Just be careful not to break any copper tubes or touch any wires. Sometimes a stuck compressor can be freed this way, but you will almost certainly still need the leak fixing and a refill of refrigerant. Sorry about the bad news :( Hope this helps :)
Posted on Mar 09, 2007
SOURCE: The power cord is hot but no lights or clock, nothing works.
I wish I had waited but I finished tearing the pot up and canned it. Next time I will know because I have ordered a new one.
Thanks; Stob
Posted on Jan 22, 2008
  • 2318 Answers
SOURCE: PROTRON 26 TWO YEARS OLD
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com
Posted on Jan 21, 2009
SOURCE: no electrical power after replacing battery
I've had similar problems with my cars, and everytime it was a bad ground or power wire, or corrosion on the terminals. Get a wire brush and clean both battery connecters..even a little corrosion can cause a no power situation. If you have a test light, connect the ground of the test light to the negative cable of the battery and touch light to the positive cable...if the test light doesn't light up, then you have a break or lose connection in your ground wire. Trace the battery ground to the engine block and clean that also...the smallest thing can interupt power...hope this helps..
Posted on May 22, 2009
woodchuck789
  • 4059 Answers
SOURCE: magic chef fridge not working
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Could also be beginning of defros problem.
Posted on Jul 09, 2009
Squeals heard from my fridge compressor
hi there,
what you thought of the sound is correct. the compressor might have gotten a little rusty after running 24hrs. if turning it off helps then do so but make sure you have everything important removed from inside the fridge. solving this problem can only be done by a repairguy as it has to be opened up.
Jun 15, 2010 | Refrigerators
Head (foil and blades) used to last 10-12 months. Now they last about six weeks. I don't hink I have done anything different when shaving. Braun Syncro is abotu four years old.
Six weeks? That's very peculiar. Are you certain that they are seated properly on the shaver? If there's a problem with the head and they're not fitting into place slightly off, they can end up wearing out faster.
If you've used your shaver for a number of years, your best bet is to probably step up to a newer model Braun shaver. The 7000 series was OK, but the 8000 series is much better. You can still pick up new old stock ones off "that auction site". They shave not much differently from the new 9000 series (Pulsonic). Good luck!
Sep 16, 2009 | Braun Syncro 7526 Electric Shaver
We have a G.E. mod.# GSS22KGMCWW refrigerator that frosts
you have defrost problem 1 timer 2 defrost thermostart 3 heater best way call service
Apr 05, 2009 | Amana ARS2464B Side by Side Refrigerator
Frigidaire refrigerator making beeping sound
Unplug your refrigerator from the ac outlet, and 0open theref door for approx. 5 minutes. Then plug it again, after you hear the beeping close the door. wallah it's fixed.
Dec 21, 2008 | Frigidaire FRS3R5EMB Side by Side...
My fridge stop cooling including the freezer section, motor is running okay. This is a icemaker fridgedair. Help , please.
Hello kenbarn
Welcome to Fixya
You said,
your fridge stop cooling including the freezer section, motor is running okay. This is a ice maker Frigidaire. Help , please.
What is the model number?
And how old is the fridge?
First try to unplug the fridge for 5 minutes and then turn it on again and see if we reset the system.
If not then you have a bad thermostat or leaking freon, and the pressure is too low to cool anything.
Or,if the compressor went then you may find this article I just read interesting!!!!!!
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Please remember to enter a rating before you sign off!
Thank You, HUUUM
Oct 05, 2008 | Frigidaire Refrigerators
Ice maker not working
Hello bnelson488,
Since the ice maker is erationally starting and stopping at it's own leisure.
1.We must first try to turn off the fridge.
2.unplug it or if you can not reach the plug you can turn off the breaker to the fridge also, for 5 minutes!
After this you restart the fridge and see if the system reset it self.
This is a common way to reset some units!
If nothing works then perhaps the ice maker needs to be replaced.
How old the fridge?
Let me know how it works and if you have any questions.
Please remember to give a rating before you finish..
bless you
Huuum.
Here is an interesting article I just read.
Repair or replace?
When a repair makes sense.
Sep 04, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Samsung Automatic cut of or turn of from working After 4hrs
Dear friend,
ngfam at you service! happy to assist!
There is a fire danger here!
CALL SERVICE RIGHT AWAY!!!!!!!!!!!!!!!!
How old is the appliance ?
If it's 10 years old or more it's not worth sinking good money into bad !Todays appliances are so much more efficient that you save money on you electric bill!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 19, 2008 | Samsung RS2630SH Side by Side Refrigerator
Please help me! Im laid off and have no money for repair man and babys milk needs to be cold
Peace Friend,
ngfam1 At your service!
You need to borrow some money to fix it!!
You and your family have to eat and you can't afford to eat out or to get sick from spoiled food!
Below I referred you to a great service nation wide!
If none of these tasks remedy the problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
Aug 04, 2008 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Ddbb362 viking designer
It sounds like the light switch may be keeping the light on when the door is closed. Faulty Switch. Regards Advisor
Aug 19, 2007 | Viking DDBB363 Bottom Freezer Refrigerator
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
