Need help with tower speakers hook up you can call me at 15753568024
500 watt tower spkrs unable to hook up to tvhoo
If the speakers are powered with their own amplifier, then connecting them to the audio out terminals on the TV will work. If the speakers have no amplifier, then they will never work on your TV. You must go to the audio setup on the TV to redirect the sound to the external jacks.
Dec 12, 2016 | Televison & Video
How do I get this system working properly again?
Here's what I would do:
1) Wherever you get sound, hook up each speaker in turn to validate they are working. If you have another, known working system to do this with, even better.
2) While testing your speakers on the known good system, once a speaker has been proven working, validate that your sound source (and cable) is working by using it as a source once everything else has been validated.
3) Now that you've isolated and proven everything but the receiver, put the receiver in stereo mode and try it out as a simple left/right amp. Once you get this far you will be able to do the surround stuff, but only with a surround encoded (ex: AC3) data stream.
If you need more help, just ask.
Graham Leach
Dec 16, 2014 | Audio Players & Recorders
How do i hook up logitech speakers #z313 to my desktop i need a diagram
Phone jack on woofer goes into computer tower (should be color coded green) and power cable on woofer plugs into 120VAC. Speaker phone jack plugs into back of woofer. The speaker cable has an on-off switch and volume control as well as a phone jack for your headset.
Nov 14, 2012 | Logitech SPEAKER SYSTEM Z313 PC Multimedia...
I need to hook up my sound or speakers in the back of the tower.
The stereo audio jack has a green color on the output jack. Connect your speakers to this output jack.
Apr 06, 2012 | Dell Inspiron 531s Notebook
HOW TO INSTALL ba265
Hook your green and orange wires off the speakers into green and orange inputs on the back of your tower. Hook the round black cable off the a/c adaptor plug into the black input on the back of the right speaker. Then plug into an outlet. There is no software for these speakers.
Apr 02, 2011 | Boston Acoustics BA265 Computer Speakers
How do I hook up my logitech speekers
If you're running a tower, you jack it into the speaker or audio output on the back of the unit. If you're using a laptop, you run the speakers by plugging the 1/4" stereo plug into the headphone/audio output jack on the front or side of the computer.
You have to make sure you're hooking up the input to the Logitech speakers- refer to your manual for details, or read the fine markings on the speaker power supply and audio input jacks.
Good luck, and hope this helps.
Oct 21, 2010 | Office Equipment & Supplies
Where do i hook my speakers on my computer tower
there should be a headphone input that is green on the back of the tower. if your speakers dont have a headphone sized cable you will have to buy a converter cable
Sep 04, 2009 | Audio Players & Recorders
Were i hook up my computer speakers, the cord that hooks to the mother board came unhooked, were do i hook it back up at?
on the back of the tower, there are 3 jacks colored Red Green and Blue, the speakers plug into the Green Jack
Mar 28, 2009 | Compaq Presario 5000 PC Desktop
Partial sound from my JBL E60 Towers
Are there 4 inputs on the back of the speakers? If so, you either need to hook up all four, or connect the upper and lower inputs to each other. The speakers come with gold plates that connect the upper and lower inputs, but you can just use speaker wire to connect them. At least that is what I did on the used set of speakers I bought when one plate was missing.
Mar 27, 2009 | Yamaha HTR-5830 Receiver
No sound from my speakers
connect the speaker cord to the socket on the tower properly and check for the sound mute
Sep 26, 2008 | Audio Players & Recorders
47 people viewed this question
 Grubhead
Grubhead
