Question about Hampton Bay Dryers
Hi, I have Hampton Bay Ceiling Fan with 4 lights. Recently I changed the bulbs to "LED". Now all 4 bulbs are flickering. Is there any thing I can do to repair it. Will appreciate your help !
  • Hampton Bay Master
  • 10,045 Answers
If your fan has a dimmer function, then make sure you have dimmable led bulbs (not all LED bulbs are dimmable).
Posted on Dec 14, 2016
  • 625 Answers
SOURCE: Installing ceiling fan with two switches AND a remote
in your ceiling box should be three wires. a red goes to the three way switches, a black goes to the hot and the white is the neutral. the fan wires are black, blue and white. since you have a remote, connect the [fan] blue & black together with the [line] black. connect all white wires together. the remote will now ramp up your lights from off to full on and the fan remote will let you choose lo med high and off. just tape up the red wire in the box.
Posted on Aug 22, 2007
  • 44 Answers
SOURCE: How to Change light bulb (yes, really...)
If yours is the same as the model 04890 that I looked up on the net, you will unscrew the center nut of the light fixture being carefull to not let the fixture drop to the floor. Once you have the center piece off you will be able to unscrew the bulbs and install new ones. Be carefull and be sure power is off before you do this.
Posted on Feb 09, 2008
  • 10 Answers
SOURCE: Hampton Bay Ceiling Fan Windward II
There is a 4 position (dip) switch on both the fan housing and the remote. Make sure these switches are set exactly the same and the remote will control the light and fan separately. If not, the remote may be getting interference on the preset frequency - try CHANGING the dip switches to a different setting and the remote should work.
Posted on Oct 24, 2008
SOURCE: I have a Hampton Bay
Replace the LED assembly with CFL lamps..
Go here for details and pics..
Posted on Jan 01, 2009
SOURCE: hampton bay ceiling fan , model # 55295
I had the exact same problem. To solve it, I had a friend hold the area of the fan that the globe screws into. I wore rubber dish gloves to get a good grip and pushed up slightly on the globe as I turned counter-clockwise. My friend held the other part and turned clockwise a little as well. It took a lot of pressure for it to finally come loose and then we just turned it about another 90 degrees and the globe slips right out of the groove.
I couldn't believe how hard this was to do.
Posted on Feb 14, 2009
Change upper light bulbs on hampton bay model 560-084
Please check the manual. If you dont have a manual you can download a free copy from here
Hampton Bay Lighting Manuals
These manuals are courtesy of Hampton Bay
Dec 02, 2016 | Hampton Bay 24002 Ceiling Fan
I need a replacement LED light bulb or kit for my Hampton Bay fan model number AM215-BN. Where can I get one?
Aug 14, 2016 | Hampton Bay Dryers
Lights flicker on ceiling fan: We have 4 cfl bulbs in a ceiling fan light fixture that have recently started to flicker. They've been there for a while without the problem, so it's not a matter of a new...
It is not a ceiling fan or wiring problem. It is your bulbs. Normal CFL bulbs do not work in dimmers or with remotes. Remotes work on RF signals and cause interference with the bulbs. You may also notice a buzzing sound and the lights may not go out when you turn off the switch. It is a fire hazard, can invalidate your warranty on the bulbs and will shorten their life. Try changing the bulbs to the new dimmable CFL's and see if it helps. It should eliminate your problem altogether.
Mar 15, 2010 | Hampton Bay 52 In. White Redington...
We have a hampton bay ceiling fan model 54cvt. We cant figure out how to change the light bulb or change the direction of the blades. We dont have a manual for the fan.
This fan is also known as the Hampton Bay Covington 54 Ceiling Fan. You need to turn the globe anti clockwise until it comes out. The full instruction manual can be found here.
If you have another fan model other than the Hampton Bay 54CVT then try here
Jun 28, 2009 | Hampton Bay 52 In.Carriage House II in...
Hampton Bay Ponte Vecchio ceiling fan light flickers
Try swapping out the bulbs and see what happens. There are bulbs made specifically for ceiling fans that have heavier duty filaments in the bulbs, or you could use compact fluorescents. The warning about using a solid state control was referring to using a solid state dimmer at the wall switch.
Mar 01, 2009 | Hampton Bay AC434-WB 52'' Ponte Vecchio...
Lights flicker when turned off by remote
I had this same problem with a Hampton Bay fan with a remote light switch. I call the manufacturer of the of the switch and was told that the model switch I had would not work correctly with CFL bulbs. The problem is with the dimmer function. You either need to change the bulbs to incandescent, or change the remote receiver in the ceiling. Hampton Bay was kind enough to send me a new receiver that works with CFL. The CFL units are white, and the incandescent is black. Hope this helps you.
Feb 26, 2009 | Universal Remote Control Hampton Bay...
Ceilng Fan light fixture-metal clasps have broken off
For Hampton Bay ceiling fan replacement parts!!!
There is a a major ceiling fan manufacturer in Fort Lauderdale FL called King of Fans (website: that deals strictly with Hampton Bay ceiling fans & parts. They are the Home Depot distributor for Hampton Bay ceiling fans. Their number is 1-800-330-3267. There is also a 1-877-527-0313 number for Hampton Bay products other than ceiling fans...
Nov 25, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Dryers Logo
56 people viewed this question
Top Hampton Bay Dryers Experts
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
