Question about Fisher Washing Machines
I HAVE A FISHER PAYKEL MODEL GWL15.. IT RUNS BUT AT THE BEGINNING MIDDLE AND END OF THE CYCLE IT STARTS TO MOAN AND GROAN... I THOUGHT THE BELT MAY BE SLIPPING
I NOTICED THE AGITATOR WAS BEARLY MOVING AT FIRST AND MACHINE WAS GROANING.. WHEN THE AGITATOR STARTED TO PICK UP THE GROAN WENT AWAY... SAME DURING SPIN CYCLE.. WHAT IS WRONG?
  • Keith Nicholls
    Keith Nicholls Dec 18, 2016
    I have the same problem
5 Suggested Answers
RescueTech
  • 145 Answers
SOURCE: Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Posted on Apr 20, 2009
  • 1752 Answers
SOURCE: my maytag won't spin. The agitator moves but the
Sounds like the transmission is shot. Call a repair shop, or buy a new one.
Posted on Oct 21, 2009
  • 713 Answers
SOURCE: Fisher and Paykel Washing Machine
Hi just found your posting.Do you still require help?The problem with your machine sounds like your suspension rods are faulty.Please reply and I can help you rectify this fault.Looking forward to your reply.
Posted on Jul 16, 2010
Jahn27
  • 1554 Answers
SOURCE: Washer model GWL10us doesn't cycle Thur wash
Some of the Wash Progress LEDs flash when the machine stops due to a fault. The 8 Wash Progress LEDs stands for the binary digits and by indicating the digits, the fault code number is determined. The fault code can be shown by activating Diagnostic Mode if none of the Wash Progress LEDs are lit.
Turn machine OFF on the front panel then hold down the Water Temp Down button and press the POWER button until the machine gives 2 short beeps and lights up. Release buttons and you are in Diagnostic mode. Press the Spin Speed Up button until the Hold and Slow LEDs are lit. Write down the LEDs which are lit across the Wash Progress LEDs and post it back.
Please make sure to accept the solution you find the most helpful. Failure to do so will automatically give credit to the first solution no matter how unhelpful it is. Accepting a solution does not stop you from communicating with an expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Sep 05, 2010
Does it matter which wires goes where on a diverter valve for a Fisher Paykel GWL15 washer?
I thought they could only plug in one way? if not, it shouldn't matter, just keep an eye on it first cycle. it activates the diverter right near the start of a cycle.
Oct 28, 2013 | Fisher and Paykel GWL11 Top Load Washer
Fisher paykel gwl15 won't pump out water
My F & P Model GWL15 did the same thing. I purchased a new pump but that was not the problem. Tip the machine back and look under. There is a valve diverter that I removed and checked. There was a dime and lots of lint stuck in the valve so it wouldn't move back and forth anymore. I downloaded a parts manual, page 10 and item # 23 is the valve diverter. Once I unclogged it and put it back together, it worked great. I noticed it works better than it has for a long time. I'm a 60 yr old woman so anyone can do this. Good luck.
Oct 19, 2011 | Fisher Paykel EcoSmart GWL15
I have a Fisher & Paykel GWL15 and I have not found what is making the squilling noise when the washer starts to fill and when it is in the rinse cycle. I previously was a appliance repairman and in GE...
More likely to be the pump. Right after it lets water in it recirculates the water. To find out start the cycle. When you hear the noise, disconnect the wires going to the pump and see if it stops. The pump is on the bottom. To get to it just tip the machine back.
Nov 30, 2009 | Fisher Paykel EcoSmart GWL15
The rinse and spin cycles never end
I have seen this often on another brand. Once it starts malfunctioning on the rince/spin cycle, the boars needs replacement.
Nov 13, 2009 | Fisher Paykel EcoSmart GWL15
I have a fisher paykel ecosmart wash cycle but when
Tip the Washer and check the hoses.... my husband just found 2 pennies stuck in one of the hoses in my F&P GWL15
Sep 30, 2009 | Fisher Paykel EcoSmart GWL15
Fisher paykel gwl15 overfills and will not advance
Is it filling so it is flooding your floor? Could be that too many suds are in the pressure switch tube ( are you using "he" soap? ) or the pressure switch is not registering the water level. Note the lights illuminated when it beeps and call F/P.
Jul 03, 2009 | Fisher Paykel EcoSmart GWL15
Hi Dale..
Apr 20, 2009 | Fisher and Paykel GWL11 Top Load Washer
My fisher paykel eco smart is GWL11 not GWL15
Press "end of cycle" for 5 seconds or more to clear the screen. Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Dec 02, 2007 | Fisher Paykel EcoSmart GWL15
Washing Machines Logo
35 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
