My college gestner cp6123b duplicator machine does not accept order it only print one page and shows B sign lights
SOURCE: HP LaserJet 1012 Printer prints ghost images
A new toner cartridge solved the problem entirely.
Posted on Oct 23, 2008
SOURCE: hp 2600n will not accept print jobs
I have two problems. Either it won't accept a print job or when it is printing it stops when it is going through the job intermittently. Like for an hour it won't continue then all of a sudden it prints one page then a half hour later another page etc. It is so frustrating.
Posted on Mar 27, 2009
  • 102 Answers
SOURCE: Duplicating the top page text at lower page region- Duplicating
Try another Toner Cartridge if that don't Fix the problem than Replace Transfer roller or Fuser.
These are only three possible parts which may cause this issue.
Posted on Oct 10, 2009
  • 192 Answers
SOURCE: My Ricoh Aicio 1013F is showing a duplicate shadow on the copy.
This is almost always the hot roller and/or the pressure roller bushings in the fusing unit. The Hot roller in this model is rated for 90,000 copies, but they commonly fail earlier than that. The pressure roller bushings also wear as they are made of plastic. If you can drag your finger across one of your copies, and the toner doesn't stick to the paper, then you definitely need bushings.
Check how many copies you have by press the "user tools/counter" button in the upper left of the control panel. You should see the word "counter" on the display. Press the "OK" button near the display; this will show you your copy count. If you are near the 75 to 80,000 mark (or multiples there of [150- to 160,000, etc.]), I'd say it's time to replace the hot roller.
Unless you are certified to work on these machines, you would need to get a service technician to do this. These particular machines are more difficult than some of the larger models, and I definitely would not suggest anybody try this repair unless they know exactly what they are doing.
Posted on Dec 17, 2009
  • 33 Answers
SOURCE: My Sharp AR-M205 copies are showing a light
sounds to me like the upper fuser roller is coated and offsetting..open the left door and where the heat roller is look at it and see if it has black on it ..if so it needs replaced.......if that is not it then the drum is bad
Posted on Jul 20, 2010
Printing last page first
Driver, the printer can't even hold one page in memory let alone many pages.
Jan 17, 2014 | IBM 6400 Matrix Printer
I can't get my chromebook to print to a my HP printer
Are you using the Google Cloud Print? If you are, you need to install a software called proxy, as part of the Chrome OS. The proxy will register the printer with the service.
Printer turned on? Classic printer installed on another computer?
When you first connected your printer to Google Cloud Print, you had to use another computer to enable the Google Cloud Print connector. Is the computer you used to enable the connector turned on? are you using the same user account you used to connect the printer to Google Cloud Print on your linux? If not, log in using the same Windows, Mac, or Chrome user account you were using when you connected the printer with Google Cloud Print.
If using a cloud ready printer; are you using the same user account you used to connect the printer to Google Cloud Print on your linux? If not, log in using the same Windows, Mac, or
Delete the printer and reconnect the printer with Google Cloud Print. Are there duplicate printers on your Google Cloud Print page?
In Google Chrome, select Options > Show advanced settings > Sign out of Google Cloud Print.
Visit the Google Cloud Print page and click on Printers. Delete any duplicate printers (printers with the exact same name) and then sign in to Google Cloud Print again to print.
Nov 24, 2013 | Samsung Chromebook Xe500c21 12. Led...
Gestner dsm620d copies with thick black lines on it
Print a counter page. Does it have the same symptoms? If not, the problem is in the optics. If yes, probably the fuser hot roller is worn out (you can look at it and see them) or the drum is worn out.
Sep 04, 2013 | Gestetner Office Equipment & Supplies
Cannot print screen shows ADF.what does this mean?
Hi!
ADF stands for Automatic Document Feeder and it means the device mounted on top of your pixma that allows multiple pages to be scanned/copied/faxed one at a time automatically.
Now why does it not print? The machine "believes" some document is inserted in the ADF in order to be scanned/copied/faxed, and wants that operation to be completed before it accept any print job. Please remove, if present, any paper from the ADF. Maybe its only some small piece of broken paper or even dust on the sensor in the ADF.
Aug 08, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
I am getting a light duplication on my copies half
The duplication problem can be either the drum or the fuser. Most likely your drum needs to be replaced. If you can measure the distance between the first print and its duplicate I might be able to help more.
thanks adi
Dec 15, 2009 | Brother MFC-7420 Printer
For long time I did not use the machine, now print is not clear
change the toner of that printer or refill it then it will work fine
Aug 26, 2009 | Riso RZ220 Duplicator
Hp 2600n will not accept print jobs. Color cartridges show empty. black shows half full. Printing of a test page produces a great test page quality
Feb 03, 2009 | HP Color LaserJet 2600n Printer
Ican't send my fax to Manatee college. All the time report shows
If it is just thier phone number they may have a fax that is old or not up to date with industry standards. Since this is a college I think they have a newer machine. Thier could be some line noise. I would email or snail mail it.
Dec 18, 2008 | Canon FAXPHONE L170 Plain Paper Laser
THE KEYS ON SHARP AR-5316E X REFUSED TO WORK
I dont have the exact manually for this machine although most of the sharp error codes are consistant for most newer models. L1 refers to the scanner area of the machine. The scanner is a part that looks at your original by shinning a light across the page and tranfering that to the machine with mirrors. If you lift the lid and push the print button, you will see it under the glass. Something may be blocking its movement if you hear an unusually noise when trying to print. If no noise it could be a sensor, motor, or a circuit board.
Nov 01, 2008 | Sharp SF 2020 Copier
Shadow/duplicate printing
in computer goto printer setting mode and uncheck option
toner saving mode and check out for dark or light effect
Jan 08, 2008 | Epson ACULASER CX11NF All-In-One Printer
k24674
