Question about Keurig Coffee Makers & Espresso Machines
My Keurig won't dispense any water..even without a cup in it. Can you help mr?
SOURCE: My Keurig dispenses about 3oz of water on next to largest setting
I JUST fixed (I Hope!) my 11 month old B60 by taking a paper clip and a straightened safety pin to the top of the coffee maker (where the top pin punctures the top of the cup) and the BOTTOM pin which punctures the bottom of the cup. (remove the bottom dark brown holder by pushing up on it).
After one or two attempts, I ran water through it without the coffee cup, then used a decaf cup and brewed it just fine....
Posted on Aug 26, 2009
  • 60 Answers
SOURCE: The Keurig is heating up the water, yet is does
Descale, Clean out the needles with an unfolded paper clip, Take out the K cup holder and clean it out
Posted on Mar 23, 2010
  • 40 Answers
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
Posted on Oct 07, 2010
  • 40 Answers
SOURCE: platinum B70 keurig coffee maker water heats up
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
heatman101
  • 43501 Answers
SOURCE: My keurig is not filling up the cup with water,
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
-llllllllllll
Posted on Feb 26, 2011
When I use a Kcup NOT made by Keurig, in my Mr. Coffee, I get only water. No punch on bottom of K-cup.
Call Keurig @ 1 (866) 901-2739. The Companies to most of your products, are generally very good in helping you with issues. Best regards!
Aug 24, 2014 | Mr. Coffee BVMC-KG5 Single Serve Coffee...
How to descale a Keurig
Fill it with a 50/50 mix of distilled white vinegar and water. Run it normally, but without using any full K-cups (it's OK to use an empty one if it refuses to dispense water without a K-cup in place). Catch all the vinegar/water that comes out, save it, and cycle it all back through one more time before discarding it. Last, repeat once with clear fresh water before making coffee again.
Aug 01, 2014 | Keurig B60 Coffee Maker
No water coming out of keurig
It could be that your Keurig's water line is clogged. To flush out debris, run water through your brewer a few times without a K-Cup. I'd recommend this step if your Keurig is brewing some coffee, just not a full cup.
Turn off your brewer and use an unfolded paperclip to clean out the holes in the top needle.
Still won't brew? Try the burp and slap method: unplug, remove water reservoir, turn your Keurig over and spank its bottom.
If you've given your Keurig a good spanking and it still won't behave, contact Keurig (866-901-BREW) for help.
Apr 12, 2013 | Keurig Coffee Makers & Espresso Machines
I have a keurig mini and the water is barley dispensing. I dont know if its clogged or what. What can i do?
heatman101
Jan 04, 2011 | Keurig B100 Coffee Maker
Just bought a secondhand Keurig. It will dispense
Do you have this part to insert the k-cup into? There has to be an exit needle and this part has the exit needle inside of it.
http://iwantsweetdeals.com/Keurig-Breville-Replacement-K-cup-Holder-Assembly-P1208231.aspx
Jan 14, 2010 | Keurig B70 Coffee Maker
My keurig will not dispense right amt of water
Try brewing a cup without a K-cup in it on the largest cup button (will brew just hot water). This will help clean it out in the event it is clogged. If that doesn't work, completely remove the K-cup holder where the needles are (careful not to get **** ) by pushing up from the bottom and rinse using hot water, preferably with a sink sprayer if you have one. Sometimes the needle can get clogged, especially if you ever use the hot cocoa K-cups, so the manufacturer recommends brewing a "blank" cup of just hot water after each hot cocoa K-cup brewed. Hope that helps...Best of luck!
Jan 02, 2010 | Keurig Special Edition B60 Coffee Maker
When I run water through the Keurig, it works fine, but the moment I put in a coffee, it balks, sniggers and refuses to brew. I think there must be something wrong with the perforation -- as though it...
Check the needle inside the k-cup reservoir to ensure it is clean and not clogged. You can completely remove the k-cup reservoir by pushing up from the bottom (where it normally dispenses into the cup) and it should pop out easily. Wash it out with hot water and check the needle for any debris. The manufacturer even recommends carefully inserting the tip of a small paper clip into the needles to push out any debris if needed. Then replace the k-cup reservoir by aligning the arrows and snapping it back into place. Lastly, brew a cup of just hot water on the largest brew size without a k-cup. This should further help clean out any debris or obstructions. Then try to brew a new k-cup as usual and see if the problem is corrected. Hope that helps...best of luck!
Dec 15, 2009 | Keurig B60 Coffee Maker
Aug 25, 2009 | Keurig Platinum B70 Coffee Maker
My Keurig B60 is suddenly not dispensing water when a K-cup is in the machine. Dispenses fine with no cup in chamber.
I solved it by running the machine a couple of times without a K cup in it. The second time through, a few grinds ended up in the cup. After that, the machine works fine.
Dec 03, 2008 | Keurig B60 Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
