Question about Home
Shower panel just flashs and unit has heat - Home
2 Suggested Answers
  • 12962 Answers
SOURCE: Unit Powers up, heating light flashes continuously , but unit will not Heat up or Release any water from Shower or Steam Head. Any Suggestions ?
Heating element is open.
Posted on Nov 08, 2015
Where to buy aariel steam shower 120V 3kw heating element
best thing i could advise you to do is go to their web site and order direct...this is your best bet...good luck
Dec 26, 2012 | Dmm WMK-A06 Pearl Steam Shower Unit,...
Triton 300si wireless shower problem - Shower motor is working but the low presure sign is flashing but all other water pressure is normal. Water was coming out but going hot and cold but has now stopped...
check inlet water first for consistency, if flow is fine and pump is working correctly, then check non-return valve on your pump outlet.
if these check correctly, check electrical side, if flow to heating element is constant, if that is interrupted, i am afraid that motherboard on your unit may be faulty,
you have then only two choices, dismantle the unit and check all wiring and component or get unit to repair centre or call plumber... or eventually replace unit by yourself.
please be aware that mendling in electrical circuit is dangerous! fully disconnect from power before you remove the covers!!
please be aware that before you attempt to repair electrical or plumbing gear you need to cut off power or water supply to the unit in full, they do not mix very well... :-)
Jul 29, 2010 | Home
Water is hot until you adjust the shower temperature to warm from hot, then heat unit shuts off and it is 100% cold. Shower head is low flow so wonder if the flow is below minimum for heater to fire?? Can...
These unit is design to operate at a specific flow rate and cannot be ajusted if you need to have a warm shower you will need to get a bath remote where you can turn down the temp whenever you need without disrupting the flow rate
Jul 21, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
My triton T100xr shower is flashing low pressure
my triton t100xr shower will work for a while then the low pressure light comes on and the shower shuts down not restarting for quite some time, any suggestions please
Nov 03, 2009 | Kitchen Appliances - Others
Shower goes cold after 5 mins
Sounds like you have got some elements out in the unit or you need to turn the heat up.
Jan 31, 2009 | Home
Triton electric shower T90si ran dry and not now working.
pump needs attention and the heating element has burnt out
pump needs water to run and the heater element needs water to keep it cool
Sep 07, 2017 | Heating & Cooling
Triton electric shower runs cold
hi it sounds as though the thermostat has gone on top of the can assembly, or moreover it has scaled up & the element needs replacing, if thats the case your better off buying a new unit as the cost of the can assembly & the fitting it will be nearly as much, plus witha new unit you'll be getting a 2 yr guarantee?
Just a thought!
Dec 01, 2008 | Home
Home Logo
73 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
