I have all pro 115000. When plugged in the lite on switch works but heater does nothing at all. No noise an dosnt run at all. Can u help me please. I'm new to these things ??
machtcl1
  • 61 Answers
SOURCE: all pro 200t
It may be a reset switch on the heater. Usually located near where the electric supply goes into the unit.
Posted on Jan 10, 2009
  • 224 Answers
SOURCE: I HAVE ALL-PRO 115000 BTU
There are several things that you can do to this heater and I have made it a yearly practice to pull this preventative maintenance. Here we go, remove the top section of the heater tube this exposes all of the internal workings of the heater. Locate the burner tray, on the front is a brass nozzle which they say you can not clean. I say with carb cleaner a q-tip and tooth pick you can, in behind the nozzle a screen assembly clean this too they like to corrode. Put the nozzle assembly back together and inspect all fuel lines for cracks, holes,and dry rot replace if necessary. At the bottom of the burner tray there is a round item, this is your flame sensor. These are known to collect carbon deposits, dirt, and occasional homeless insect, clean it with windex and a soft terry cloth rag. Now put the burner tray back in the heater. Trace the fuel lines down to where they come thru the case, remove the side panel cover here is where you will find the fuel line and an in line filter. Remove the fuel filter and I use a compressor and blow gun to clean these, simply blow air backwards thru the filter and instantly it's clean. Inspect those lines again if all is good put filter and lines back together and replace the side cover. on the back of the fuel pump is a foam rubber air filter, wash it out I use dawn dish soap, but dry it real good then put it back in. Now replace the top and I want you to open the fuel tank and tilt your heater towards the fuel opening, you are looking to see if there is water from condensation while being stored. If there is empty the tank in to a five gallon bucket, oil is lighter than water so fuel floats to the top. You can either throw it out and dry out your fuel tank or siphon off the fuel and reuse it, just be careful not to get any of the water. Now you are ready to test your heater.Plug it in and you should be up and running like new again.Good luck
Posted on Dec 28, 2010
heatman101
  • 43501 Answers
SOURCE: Buddy Pro TS75KT Heater Will not lite when cold.
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Jan 16, 2011
heatman101
  • 43501 Answers
SOURCE: my heater is a 115000 btu all pro and will come on
heatman101
Posted on Jan 28, 2011
  • 4736 Answers
SOURCE: I have an allpro 115000 btu torpedo heater.
According to the Owners Manual Trouble Shooting Guide (Page 8), there are 9 different things that could be causing the problem you have. Fortunately, there are 9 solutions to finding and fixing the problem.
Below is a link to your Owners Manual (in case you have misplaced yours) that you can download and print for now and future reference.
http://www.desatech.com/manuals/Construction%20Heaters/113282-01.pdf
This should get your heater fired back up.
Posted on Mar 07, 2011
My Jandy lite 2 natural gas heater has a loud clicking noise. It fires up and heats my pool nicely. My problem is.... as it is heating there is a loud clicking noise from the gas valve area. It acts a
make sure pressure switch is good and wires are tight sounds like pressure switch cutting in and out opening and closing gas valve also make sure wires to gas valve are tight
Apr 10, 2013 | Jandy Laars Lite 2 Pool Heater 250,000 BTU...
Heater motor
its under dash on right side 3 to 4 bolts 7mm or 1\4 one plug one vent tube unbolt ( if new fan dosnt come with new blade pull c clip pull off put on new)
Jan 14, 2012 | 2001 Pontiac Grand Am SE
I have an allpro 115000 btu torpedo heater. Igniter works, nozzle flows freely and the heater runs on jet a. Never had a problem, now ignition is intermittent, heater shuts off within 10 seconds and does...
Mar 07, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
Were do i get parts for all pro 115000
Go to Google. Type in Kerosene Heaters and you will find a web site that sells parts. Keep model number handy. Rus
Nov 22, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
Starting a teledyne laars heater
check for proper millivolt reading( 400-600).it could be 20 different problems and/or components
Jun 15, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
All pro 200t
Jan 10, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
Clicking noise
Please let me know if you get a solution for this--mine has been doing this as well (404)-583-4095 Cliff in Atlanta
May 21, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
