Question about Dayton Heating & Cooling
Dayton unit heater model#4LX58A. The unit is getting spark but seems to be not quite enough spark to get it to fire. If I use a cigarette lighter I can get it to fire. Any idea what the issue is?
  • Dayton Master
  • 3,162 Answers
Weak spark try cleaning the electrode .
Posted on Dec 13, 2016
2004 Mitsubishi Outlander
You had better recheck that fuse again with an Ohm meter..
Jul 25, 2017 | Cars & Trucks
Had cell phone and computer plugged into dual cigarette lighter unit and cigarette lighter overheated and quit working - we checked the fuse - it seems fine.Just want the cigarette lighter socket to work...
More than likely overheated the wiring going to the lighter as well and burned it off. If you pull the lighter socket out you should see if it did. Simply solder it back on and be careful not to overload it again.
Jan 29, 2011 | 2000 Oldsmobile Silhouette
I have a 2E511C heater that wont fire up but the spark plug is firing
You probably already know this . The 2E511C was manufactured by DESA for Grainger, so you must follow these Reddy Heater troubleshooting tips.
It sounds like the heater is not getting fuel or the fuel is not hitting the spark and you must troubleshoot and find out why.
Contact me for a Dayton to DESA parts cross reference chart.
Oct 27, 2010 | Dayton E51 Oil Filled Utility Heater
How do i change 12v power / cigarette lighter! in a Peugoet 206
The cigarette lighter is connected to a harness that's being the unit. You need to most likely remove the panel that the cigarette lighter is attached to in order to remove the lighter unit out. Once the unit is out, disconnect the wiring harness to exchange it. I don't know how exactly your lighter will come out
Aug 25, 2009 | 1991 Peugeot 405
Heater wont ignite. Has fuel coming out front of
if the spark plug is sparking it is hot enough to lite the ther dirt in fuel tank???is there water in the fuel???? what is the air pressure set at????is the nozzle clean and spraying correctly?????any of these will cause the heater not to fire.not the spark plug.
Feb 20, 2009 | Dayton E51 Oil Filled Utility Heater
Distance to keep between a 2000 watt heater & wall insulation?
The fiberglass will not catch fire. There is a sfer barrier built into the wall heaters. When you install a wall heater you basically just cut the wall open and throw the unit in with the flue and gas and away you go. If you can to second guess take some of the insillation and take a match or a lighter and hold it in your hand and light the fiberglass, you will see that it wont burn even with direct flame on it. You are 100 percent safe
Feb 12, 2009 | Dayton Electric Heater
Wat the hell is wrong with my dayton heater?170,000 btu oil fired...wont stay runnin?on shut down puffs like a mutha....
Most use a spark plug to ignite fuel it could need cleaning. You also could have water in fuel or dirt
check and clean ignitor/spark plug clean fuel line and nozzle, drain and clean tank Check for water in fuel by tilting unit to have a low corner siphon fuel from that corner after 1 hr inspect for water.
Jan 23, 2009 | Dayton E51 Oil Filled Utility Heater
Heating & Cooling Logo
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
