Question about Poulan Garden
How do i replace the fuel lines correctly for my Poulan Predator 35cc/16 chainsaw? Where can i find a diagram or picture for THIS particular model?
* Poulan Predator 35cc/16 in. * Model: P3516PR * need a diagram so i put the lines on correctly, i think i put the lines on backwards after i cleaned the carborator.
    Top Expert:
  • Poulan Master
  • 44,073 Answers
Poulan might be able to supply the diagram.
Posted on Dec 12, 2016
My choke will no stay out on my poulan chain saw
Sounds like the choke latching system is not fully engaging if it is the W28 and on the P3516C. Some minor teaking of the latch may be all that is needed.
Jan 01, 2015 | Poulan Predator P3516pr 35cc 16" Gas...
What is the ratio of gas to oil for a 35cc engine
Mix 3.2 ounces of Poulan 2-cycle air cooled engine oil to one gallon of fresh unleaded gasoline to obtain the recommended 40:1 fuel to oil ratio.
Over a period of time oil will separate from gasoline. To properly insure oil and gas mixture, I recommend thoroughly shaking your oil and gas mixture before refueling your unit.
If the saw is to be stored for longer than 30 days - drain the fuel tank, re-tighten the gas cap, and start the unit and let it run until it stops.
Jun 09, 2014 | Poulan Predator 35cc P3516pr Chainsaw...
What tool do I need to adjust the high & low speeds of the carburator for my Poulan Predator 35cc chain saw because it will not idle at the proper speed.
Should just be a little bladed screw driver, most are, turn the screw very little, 1/4 turn at a time till something changes, they are sensitive. If you run out of adj and nothing has changed, turn the screws in all the way, both of them, then out 1 1/2 turns, this will get you running, you can fine tune from there.
Aug 29, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I NEED A DIAGRAM OF THE FUEL LINE TO THE CARBURETOR FOR A POULAN PREDATOR SERIAL#03296D300154-6 MODEL#2150PR
What you request doesn't exist. An IPL containing fuel system parts with very little detail can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/PWE/2150-Predator-Gas-Saw-Type-6/75.2150-Predator-Gas-Saw-Type-6.1.59.1.html
The fuel system parts can be found on the "Engine Assembly" and "Handle & External Assembly" illustrations.
e17de8d.gif Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer, the output line from the carburetor connects to the suction side of the primer bulb (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
HTH
Lou
The serial number you provided allowed me to find the correct IPL for your saw Type 6 (-6 from serial number). Thank You.
If you feel Poulan should provide better illustrations please contact them here: http://www.poulanpro.com/node4033.aspx There is a toll free telephone at the bottom of the page.
If you contact them and aren't satisfied with their reply, please elevate your concern to their parent company (Husqvarna) here:
http://www.husqvarna.com/us/homeowner/support/customer-support/
Oct 29, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I need the fuel line routing or diagram for a Poulan Predator 2150 LE. I have parts list but it does not depict the fuel detail I need.
Jimmy there are no Poulan drawings with fuel system detail worth the ink it takes to print them, but that is all there is.
Routing runs from fuel tank to carburetor, (if equipped) through carburetor to primer bulb (once compressed bulb draws fuel as it returns to normal) , bulb (as it is compressed) returns displaced to fuel tank. HTH
Lou
Oct 22, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Installing fuel lines for, poulan 2150 16''
Find the model of your saw and open the IPL and handle assembly drawing here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
This is as good as fuel routing gets!!! If this isn't sufficient Find your nearest Poulan repair facility or try your friendly neighborhood chainsaw seller/mechanic. Resubmitting this question won't get any better answer. HTH
Lou
Sep 14, 2009 | Poulan Garden
I have predator and wont start
Does it have good compression? Is the muffler plugged? Is the spark plug wet after trying to start? If not, try a little starting fluid in the plug hole, and try to start. If you get a few pops, try resetting the carburetor H and L jet screws each 1-1/2 turns out from CW stops. It should run with these settings. Warm the engine up, then apply full throttle and adjust H CW until it runs fast, but 4-stroking. It should smooth out when cutting. Next, set idle L for fairly smooth idle, yet follow the throttle without lag. Adjust idle speed just below chain movement. Hope this helps.
Sep 10, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Diagram of fuel line for Craftsman 16" chainsaw
Your saw is a Poulan. Try converting the cc to a model number. A 2.2cc Craftsman is often a Poulan model 2200. go to this link and find something that appears the same under (POULAN-WEED-EATER).
http://www.ordertree.com/cms/illustrated-parts-list/9788.html
The IPL will help. Pay attention to the year there is a different area for older saws.
For a current saw Craftsman should have something available.
Sep 04, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
I have a poulan pro 38cc 16"chainsaw about 5 yrs. old. It ran fine until I let it sit too long and when I went to use it,discovered the fuel lines had disentegrated. Replaced the lines,drained the fuel and...
SOUNDS LIKE YOU FOLLOWED ALL THE CORRECT PROCEDURES. TRY TO GOOGLE SEARCH YOUR POULAN PRO MODEL #, I'VE HAD ALOT OF LUCK GETTING MANUALS AND DIAGRAMS FROM THERE. GOOD LUCK!!!
Jan 24, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Garden Logo
141 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
