Question about Refrigerators
Defy ecofridge top part not getting cold but freezer bottom did bottom was frozen so we put off to defrost for few hours put it on and run a short while motor stop and top warm and bottom hardly cold
  • 125 Answers
SOURCE: Admiral Side by Side Fridge is warm at top, cold at bottom
CHECK TO SEE IF THE EVAPORATOR FAN MOTOR IS RUNNING, ITS IN THE BACK OF THE FREEZER SIDE, MOTOR MAY BE BAD OR SOMETHING COULD BE BLOCKING IT...
Posted on Feb 07, 2008
SOURCE: My Beaumark Bottom Freezer Refrigerator Doesn't Work
problem is probably that the evaporator is frozen up preventing circulation of air and the fan is jammed with ice.
remove the back panel inside the freezer. melt off the ice with a hairdryer taking care not to heat up any stats mounted on the pipework.
appliance will now work but this is a temporary repair. you must find out the cause of the ice build-up ie why not defrosting.
for starters, check the defrost heater and the thermal cut-out inseries with it.
let me know how you get on and what you find. make sure the fan is free to rotate.
tresilla
Posted on Nov 06, 2008
ryeisenman
  • 9 Answers
SOURCE: cold freezer/warm refrigerator
Same problem with Frigidaire Gallery model#GLRT182SAW5 (dated 2002 on back of case)
Vents were blocked with ice. Vents (from top compartment to lower) located behind light. You can check by poking a chopstick up the (2) holes; be careful not to hit fan blades.
Solution:
- took freezer coil cover off in back; checked that defrost heater element was working (marked and rotated the timer in the hole next to light); checked that fan working. Found ice in the vents and defrost drip area. Got it out with hair dryer.
- cleaned compressor coils in back (check fan is rotating; also tweaked some of the compressor tubing bends to make them more smooth - read somewhere about a manufacturing defect ...); blew out drip tube from defroster while down there.
- Set the freezer control to WARM and the refrig control to COLD (THIS SHOULD IMPROVE AIR FLOW FROM TOP TO BOTTOM).
- Put thermometers in top and bottom. Checked that refrigerator cycles (not running continuously). Checked that cold air is coming down from (2) vents behind light.
OK: so far, so good. Lower compartment is 40 or under. Top is under 18.
CONCLUSION: Suspect marginal design. Had problems with another similar model where defroster ice doesn't drain correctly, pools and refreezes. Leading to blocked vents as well as blocked defroster drain and similar problem including dripping water from top to bottom and warm bottom.
MAYBE KEEPING THE FREEZER CONTROL AT WARM GETS AROUND THE PROBLEM?? ANYWAY, ITS WORKING FOR ME FOR NOW !!
Posted on Dec 13, 2008
lenwest
  • 150 Answers
SOURCE: refrigerator will not get cold, but freezer works
Make sure your fan is working ,its located behind the freezers back wall. If it is working the vent from the freezer down to the refrigerator may be blocked (usually with ice).With out a fan you have no circulation but your freezer may look likes its working,it may last 3 days.Also if you can move everything out unplug it turn it off w/ doors open untill all traces of ice are gone this will free up any clogged tubes. Good luck.
Len West
Posted on Feb 27, 2009
heatman101
  • 43501 Answers
SOURCE: I hear motor running but not getting cold on either side warm air
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Jun 05, 2010
My GE Refrigerator doesn't work properly.
The two main causes for your problem is the control set wrong and the second one isthe defrost element has burned out... Sometime the defrost clock will go out as well.... always try to set your controls to midrange and if the bottom of the freezer compartment is cold and frosty but the refrigerator is cold ... Remove all the food and store in a backup refrigerator you can rent from an appliance rental center... Unplug your refrigerator and let it defrost for 48 hours.... In the mean time open up the doors and clean it from top to bottom. place a fresh opened box of arm and hammer baking soda in the frige side and one in the freezer side. Plug back in after completely deftosted and place a small plastic cup half filled with water on each shelf of the freezer. Close the doors and wait 8 hours... Open the freezer and check the plastic cups.... if they are all frozen great..now wait for 3 days do the test again if the bottom cup is frozen and the top shelf is not ... its time for a new defrost element or a defrost timer.
25 years service
stocktongoodrepair@gmail.com
Sep 21, 2014 | GE Refrigerators
Refrigerator is warm, but freezer is cold and still making ice. This is a 3 year old Amanna Bottom Freezer model. There is frost in the top of the freezer drawer when I putt it out.
you will need to defrost it. the freezer is what keeps your fridge cool. the vent where the cool air goes up to your fridge is sealed or frozen.
unplug the fridge and open the doors and let it defrost.
plug it back in after a few hours and it should be working again.
Mar 20, 2011 | Amana ABB2223DEQ Bottom Freezer...
Top refrigerator warm bottom is ice cold.
An automatic defrost time turns the defrost cycle on and off every 24 hours. If problem continues, problem is most likely defective defrost timer.
Even electronically controlled units often have electro-mechanical timers for defrost cycle.
Jun 15, 2010 | Amana ABB1927DE Bottom Freezer...
Fride not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 04, 2009 | Amana ARB9059CS Bottom Freezer...
Uneven cooling in fridge and annooying alarm every 10 hours!
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Mar 28, 2009 | Fisher and Paykel Active Smart® E522BR...
Frozen vents from freezer to fridge
you most likely have a defrost problem.or a clogged drain.you need to check your defrost heater defrost timer and thermostat.if ice is formed over drain then you can unclog drain with hot water.you will see when it is unclogged,water will run down drain without running over into bottom of freezer.
Mar 09, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Not blowing cold air
Most likely evaporator coils are iced near solid...few hours unplugged would have helped just a little...needs major defrosting though.
The automatic defrost cycle will never fix it when it gets this bad...if it's still working yet.
I have one of these and have had to use heat gun/ hair dryer more than once to defrost it.
Probably the cause...which will need fixed or it will do it again sooner or latter...is the melted frost/ice goes down a little drain tube and dumps into tray to evaporate above coils...this tube gets plugged first with dust and then when melted frost drains and stands in tube the tube get plugged with frozen water.
You see it is important to unplug or fridge will self destruct.
Mar 01, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
GE Side By Side top portion of fridge and freezer not cooling
heatman101
Jan 28, 2009 | GE Hotpoint Top-Freezer Refrigerator
Amana refrigerator warm
Chances are if they are getting cool but not cold-
1) the evaporator fan in the freezer is not running
2) Defrost heater has failed
3) Defrost sensor has failed
4) Defrost timer/refrigerator control has failed.
Check for ice build-up on the back wall of the freezer. If there is ice, unplug or turn the unit off for 6-8 hours with the doors open (put any food in a cooler with ice to maintain). Note water may come out of the refrigerator.
Plug the unit back in or turn it back on, close the doors, and check temperature after a couple of hours of operation. If all OK, you will need to have the above tested, or, if you know how to use a multimeter and can read a schematic/wiring diagram, I can instruct you on how to check the above.
Jan 20, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
