Hook up towers unable to hook up the way i want to
    Top Expert:
  • Computers & ... Master
  • 8,211 Answers
Can you put more info up on fixya so we know what you are trying to do and with what.
Posted on Dec 12, 2016
500 watt tower spkrs unable to hook up to tvhoo
If the speakers are powered with their own amplifier, then connecting them to the audio out terminals on the TV will work. If the speakers have no amplifier, then they will never work on your TV. You must go to the audio setup on the TV to redirect the sound to the external jacks.
Dec 12, 2016 | Televison & Video
How do I take apart the New Bright Power Horse Tower Crane TC36 to fix the tangled strings inside?
WOO HOO I FIGURED IT OUT!!!! You have to pull it apart from the base up. First thing I did was take off the feet. If you look down the tower potion you can see a screw. Then u took off the tower. I figured out that if you just lined up the black square portion it would have come apart with just the one screw. Anyways now there is 2 more screws to get. 3 total to take the new bright tc36 tower crane apart. They are hard to see, but once the base is off you can get at em. Good luck everyone.
Jul 09, 2012 | Garden
Tower turns on but nothing else does! Not the monitor, keyboard
Inside the case there will be a small Silver battery its only flat and not that big But if that dies then pc is unable to store boot up date even if pc isnt plugged in
So Replace that battery Put side case back on the pc Then plug in and turn on, It should boot up without any bleeping. And once replaced them battery's last for ages .
Jun 27, 2010 | Velocity Micro Edge Gaming Desktop PC ...
We have a samsung hdtv monitor. Bought bose
you can try checking in your t.v.s menu for audio program
Sep 19, 2009 | Samsung Audio Players & Recorders
Knex Drop and Swing... won't drop the swing
The Knex website has building help for this problem. There answer is as follows:
Make sure all rods and connectors are fully hooked together, especially the blue and gray connectors. Even one peice not fully hooked together can twist the model just enough to jam the gears. (You may have it hooked together correctly prior to jam problems so it is good to check since I found a loose on holding the motor.) The chain links need to all be attached in the same direction, and fully hooked. The chain also needs to be on the tower with the hooks facing down and in as the chain runs on the outside of the tower. (Chain should be outside on the front and inside in the back with the 5 yellow bar side in the front.) Check that all gears are positioned correctly according to the instructions and the teeth facing the correct way. If you are still unable to get the seat to drop, you may remove the top yellow cross rod that the chain runs over - the model will also work with this piece removed.
I did all of these steps with my son and his still had trouble dropping all the time. It still seems light so the seat didn't have enough weight to drop with gravity during the non-moving cycle of the orange half gear. We decided to tape on 2 marble passengers to see if that helped. It did!!! When searching for other solutions, I noticed a UTube video that added people also so this seems to be a common solution. Try it or some other light weight added and see if it solves your problem.
Dec 24, 2008 | Toys
I have a Lexmark 5150 all in one.I recently hooked up to broadband.I cannot use the fax now. It says no communciation. How do I get my fax machine to work again? The printer and scanner work fine.Do I have...
Hi Brenda,
Your All In One wants a phone line hooked directly to it. It won't fax without a "POTS" line directly hooked to it. POTS stands for "Plain Old Telephone Service" which is the line with good old dial tone on it.
Dec 17, 2008 | Lexmark Computers & Internet
How do i hook it up to my computer
how do you hook what up? printer perhaps? usually usb on back of tower. well basically its all on the back of the tower. first tell me what you are trying to connect.
Feb 26, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
