Question about John Deere Garden
2007 JD 450J 2500 hours: checked oil levels - Hydraulic and transmission. Engaged drive, normal PSI, crawled at very low jerky speed. Backed up some and then it stopped no PSI and no longer moves.
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
Sometimes they have air pockets disengage the transmission
as to push. start put in gear and run this will help burp out air.
shut off and engage the transmission and try.
Posted on Dec 12, 2016
Loss of power in drive of my jd f935
These units run a hydraulic style transmission. The loss of drive could be as simple as low oil level. There is a check plug on top of the transmission, oil level should be within 1" of the fill hole. The probable loss of drive is from wear. This would require a new transmission. Repairing these style transmissions is expensive.
May 05, 2015 | Garden
How to fix a ford f150 with trans fault and flashing overdrive light with diagnostic codes p0731 and p0732>
P0731 Ford - Incorrect First Gear Ratio
Possible causes
- Low transmission fluid level
- Dirty transmission fluid
- Shift solenoids
- Transmission mechanical problems
- Transmission hydraulic control circuit
p0732 Gear 2 Incorrect ratio
Possible causes
- Faulty Shift Solenoids
- Shift Solenoids harness is open or shorted
- Shift Solenoids circuit poot electrical connection
Start by inspecting the transmission oil level and condition, and change fluid if necessary.
also check OUTPUT SHAFT SPEED OSS for proper installation and function
hope this helps
Sep 16, 2014 | Ford F-150 Cars & Trucks
Why is oil leaking from air cleaner?
this is usually due to an oil overfill situation. You most likely added the full quart of oil into the crankcase on setting it up without checking the actual oil level periodically as you fill it. Recheck and drain out the excess as needed.
Jul 14, 2014 | Briggs & Stratton 020324 3700 PSI Pro...
The oil pressure drops when at idle on my 2007 hd ultra classic motorcycle.
Hi Anonymous, start by checking oil level in tank and it is between the add and full mark. With engine at normal operating temperature 180-230 degrees and the use of a 10 micron synthetic media oil filter, oil pressure will be 30-38 psi at 2,000 RPM and 3-5 psi. at idle. The oil pressure light is designed to come on at 2 psi. or less. To accurately test oil pressure remove oil pressure sending unit and install known good oil pressure gauge that reads 0-50, there might possibly be some plumbing required for hard to access points. If you are out in the middle of nowhere and there is no cell phone service and your oil pressure gauge isn't working and your oil pressure light is burned out, despair not, you still have one last line of defense left HYDRAULIC LIFTERS.as long as those tireless workers are quiet, you have oil pressure, maybe not much, but enough to get you down the road at a slow to moderate speed using the least amount of RPMS as nessary. Good luck
Apr 02, 2013 | Harley Davidson FLHTCUI Electra Glide...
Low oil pressure 1450 Harley 2001
Oct 25, 2012 | 2001 Harley Davidson FLHTCUI Electra Glide...
Jerky movement
there are 2 drive belts that control the transmission. 1 is a variable speed drivebelt going from the engine back to the trans. it is the long one. the shorter belt drives the trans. off of the other variable speed belt. both belts are located under the mower and are not fun to get to. I would bet that one of these belts are slipping and grabbing, giving you the jerky ride. visually inspect for cracks or peeling, then check tensioning system for the belt to make sure they have the correct tension. less likely would be in the geardriven trans. it might act that way if some teeth of the gears inside are worn or broke. one other thing to check if all else looks good.... the variable belt drive pulley expands and contracts to change speed of the transmission input. I have seen these pulleys fail to operate correctly and this could also cause the ride to ****. hope some suggestions here help. R
Aug 23, 2012 | Toro Power Lawn Mower
Oil pressure gauge is reading low pressure at idle fluctuates
Hi Anonymous, start by checking oil level in tank and make sure it is between the add and full mark. With engine at normal operating temperature 180-230 degrees and the use of a 10 micron synthetic media oil filter, oil pressure will be 30-38 psi at 2,000 RPM and 3-5 psi. at idle. The oil pressure light is designed to come on at 2 psi. or less. To accurately test oil pressure remove oil pressure sending unit and install known good oil pressure gauge that reads 0-50, there might possibly be some plumbing required for hard to access points. If you are out in the middle of nowhere and there is no cell phone service and your oil pressure gauge isn't working and your oil pressure light is burned out, despair not, you still have one last line of defense left HYDRAULIC LIFTERS, as long as those tireless workers are quiet, you have oil pressure, maybe not much, but enough to get you down the road at a slow to moderate speed using the least amount of RPMS as necessary. Good luck
Mar 25, 2012 | 2000 Harley Davidson FLHTCUI Electra Glide...
Have a JD 2010.When engine is cold, the hydraulic does not react. When engine is warm, it is jerky. I am looking for the location of the hydraulic filter to see if it is clogged. Oil is fresh.
Look in front of the right hand side step, there is a round door with three bolts on the side of the transmission case, drain the oil first from the drain plug underneath.Remove the bolts and lever the door off, be careful there is a spring behind,the filter is a wire mesh type cartride and has a small wire handle to pull it out . wash the cartridge in solvent and blow clear with compressed air. Make a new gasket when reinstalling and use lots of Gasket sealant.
Nov 15, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Whining from transmission or shaft drive , yamaha xvs650 2004 mod
Check the gear oil level in the shaft drive and make sure it is the right level, and that you are using the proper type of oil (check your service manual).
However, I understand it's normal for these bikes to exhibit some gear noise at low speed due to the design of the transmission (straight-cut gears).
Sep 14, 2009 | 2004 Yamaha V Star Classic
50,000 mile service
48,000 miles or 48 months
Maintenance Service Schedule 2007 dodge
Change engine oil and engine oil filter
Rotate tires
Lubricate drivetrain / steering / suspension
grease fittings (if equipped)-except Powerwagon
Lubricate front drive shaft fitting
(2500 / 3500, 4X4 & Powewagon)
Lubricate tie rod end links - Powerwagon
Check automatic transmission fluid level
Check manual transmission fluid level
Check the coolant level, hoses and clamps
Inspect exhaust system
Inspect brake hoses and brake linings
Inspect the CV joints/U-joints (if equipped) and
front suspension components
Check spare tire for proper pressure & correct
stowage
Lubricate outer tie rod ends 2500/3500 4X4
51,000 miles or 51 months
(2500/3500, 4X4 & Powerwagon)
Inspect brake hoses
Jan 04, 2009 | 2007 Dodge Ram Truck
Garden Logo
37 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
