How do I delete 911 ?and get to option or back field can't go there ?
    Top Expert:
  • Computers & ... Master
  • 8,376 Answers
Can you please put more info backup on fixya as to what it is you are talking about and someone might be able to help you out..
Posted on Dec 12, 2016
How do I delete or edit contacts in my phone list, I have a cat b15 android
complete steps in case someone else wants to know how to add one as well..
Add or Remove a Contact
From the home screen, tap the All Apps icon.
Scroll to and tap People.
Tap the Add contact icon.
Tap the preferred contact sync option.
Note: Tapping Sim-only or Phone-only will save the contact to that location only, and will not be backed up to the Google account.
Enter the Name of the contact.
Tap the Phone field, enter the desired 10-digit number, and then tap the phone label field.
Tap the desired option.
Enter any additional information in the desired fields.
Once finished, tap DONE.
The contact is now added.
Tap the Back key.
Delete:
To delete a contact, tap the Menu key.
Tap Delete contact.
Tap to select the preferred contact.
Tap the Delete icon.
Tap OK.
I hopes this helps a bunch of people matter of fact this is one i will add to tips thanks and good luck
Dec 26, 2014 | Caterpillar CAT B15 IP67 Rugged Android...
Tip
CAT (Catapillar) B15 IP67 Rugged Android Smartphone Add or Remove a Contact
First off from the home screen, tap the All Apps icon.
Tap the Back key.
Tap Delete contact.
Tap OK.
on Dec 26, 2014 | Cell Phones
How to delete a hard drive of os ?
if its a multiple os option at startup you want to get rid of you :
-press start
-type msconfig in the search field and hit enter
-select the boot tab
-select the os you want to delete (the current active one do tell you its the active one in its description)
-press delete
-OPTIONAL: you may also set the timeout optiion as low as 3 sec. making it go away in 3 sec instead of 30 sec
if you want to delete an os system from a secondary harddrive (the active system will not allow you to delete it) it should be as easy as to remove the protected and hidden attributes (right click a folder and options) and delete it - this does not remove it from the multiple os option at startup- see above
Jul 27, 2014 | Microsoft Windows 7 Ultimate for PC
PHONE CALLING 911, i CANT DISENGAGE!
To read a 911 Emergency Call alarm message:
1.Press Function
2.Press [ALARM]
3.Press [SHOW 911]
This will show what extension calls the 911.
4.Record the number of the extension from which the 911 call originated.
If additional 911 calls were made, press [MORE] to view them.
To delete the 911 alarm, press [CLEAR]
5.Contact the appropriate emergency services.
6.Press [EXIT].
Apr 20, 2014 | Mitel Superconsole 1000
I forgot my memory card password , what is the solution?
This is what I did to unlock a memory card password in my nokia phone. You can try it in yours First is you unlock the phone
      1. Turn off the phone and insert the memory card into the memory card slot. Turn the phone back on.Press the "Menu" button on the main screen and click on the option for "Extras."
      2. Scroll down to the bottom of the list. Click the selection for "Memory Card."
      3. Select the "Options" icon on the screen. Scroll through the list to the "Unlock Memory Card" option and press "OK."
      4. Type in the unlock password in the password field. If you do not know the password, the default unlock code is either "12345" or "1357."
        • Delete the Memory Card Password
      1. Turn off the phone and insert the memory card into the memory card slot. Turn the phone back on.Press the "Menu" button on the main screen and click on the option for "Fun & Apps."
      2. Navigate to the option for "Gallery" and click on the "OK" button. Scroll to the "Memory Card" item and then click on "Options." Scroll to "Memory Card."
      3. Click "Delete Password" when the window prompt appears. Make sure the message "Memory card will be unlocked, do you want to continue" appears. Click on the option for "Yes" to confirm.
      4. Scroll down to the password field and enter in the default password. If you do not know the password, the default unlock code is either "12345" or "1357." Click "OK" to delete the password from being required.
Jan 01, 2011 | Nokia 5800 XpressMusic Smartphone
I have forgotten my memory card password
  • 1
  • 2
  • 3
  • 4
  • 5
  • Oct 08, 2010 | Nokia N70 Cellular Phone
    I have a lot of redundant items in my itunes library and want to delete them. Itunes help says just pint at them press delete and you will be offerred a remove option. doesn't work. I point, point...
    First, make sure you're actually in the music library listing, and not in a particular playlist.
    Then, if you're in Windows, make sure you're hitting the "delete" key and not the "backspace" key.
    Your other option is to right click on the item you want to delete, then select "Delete" from the list of options.
    If you're on a Mac, you'll need to hit the function key (fn) at the same time as the "delete" key.
    Or, you can press Ctrl while clicking the mouse on the song you want to delete, then select "delete."
    Let me know if these options don't work for you!
    Aug 26, 2010 | Apple iTunes
    How to delete the pre listed site names SEw395
    Please delete the history in browser >> options. Clear cache and cookies also. All sites which are browsed will be deleted forever.
    May 24, 2010 | Sony Ericsson W395i GSM Quadband Phone ...
    Is possible to configure my ymail.com account with my mac. if it is what are the setting
    Yes you can and please follow the settings that is listed below.
    1. In Entourage, Click the Tools Menu
    2. Select Accounts
    3. Click New
    4. Select IMAP from the Account Type Drop Down
    5. Click OK
    6. Select the Account Settings Tab
    7. In the Account Name field, enter a meaningful label that will help you
    recognize the account (i.e. USA.NET)
    8. Place a check in the box labeled Include this account in my 'Send & Receive
    All' schedule
    9. Enter your Name and your full Email address in the respective fields
    10. Under Receiving Mail, enter the following information:
    a. Account ID: your full email address (i.e. rickberglund@usa.net)
    b. IMAP server: imap.postoffice.net
    c. Password: your password for your USA.NET account
    11. Under Sending Mail, in the SMTP server field, enter smtp.postoffice.net
    12. Click the button marked Click here for advanced sending options
    13. Place a check in the box labeled SMTP server requires authentication
    14. Select Use same settings as receiving mail server
    15. Close this window
    16. *Optional* If you wish to leave a copy of your email on the USA.NET server and
    have them deleted only when you
    delete them from Entourage:
    a. Select the Options Tab
    b. Place a check in the box labeled Leave a copy of each message on the server
    c. Place a check in the box labeled Delete messages from the server after they are
    deleted from this
    computer
    17. Click OK
    I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
    Feb 15, 2010 | Yahoo Mail
    Bad Request Your browser sent a request that this server could not understand. Size of a request header field exceeds server limit. Cookie: VISITOR_INFO1_LIVE=5gcTVq-0wa8; PREF=gl=US
    Hi there!
    If "your browser sent a request that this server
    could not understand" - and "size of a request
    header field exceeds server limit", that strange
    request may be a bad or "super-sized" cookie.
    Simply delete all your cookies, and everything
    should be fine.
    While you're erasing your cookies, you should
    also be deleting your "temporary internet files"
    and "history" to make everything fresh.
    Here's how:
    Internet Explorer 6:
    → Tools → Internet Options
    → Delete Cookies → OK
    → Delete Files → OK
    → Clear History → Yes
    → OK
    Internet Explorer 7:
    → Tools → Internet Options → Delete...
    → Delete files → Yes
    → Delete cookies → OK
    → Delete history → OK
    → Close (browsing history window)
    → OK
    Mozilla Firefox
    → Tools → Clear Private Data
    [x] Browsing History
    [x] Download History
    [x] Saved Form and Search History
    [x] Cache
    [x] Cookies
    → Clear Private Data Now
    Have fun!
    *Your vote is highly appreciated. Thanks in advance!
    Dec 27, 2008 | YouTube Videos
    Computers & Internet Logo
    23 people viewed this question
    David Payne
    David Payne
