Question about Vizio Televison & Video
I have a vizio d650i b2 is not turn on have blinking power light 2 year start tirning off by it self ones in a while now nothing happen
    Top Expert:
  • Vizio Master
  • 75,169 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Dec 13, 2016
4 Suggested Answers
  • 64 Answers
SOURCE: POWERING ON
good day
since it is unusual, have it checked by a competent technician. it may only be a simple reset but nevertheless at least you wont be bothered again by that problem
Posted on Oct 09, 2008
mace1mace
  • 1138 Answers
SOURCE: why does my vizio lcd
Good day!
Please follow this procedure to fix your problem:
  1. Open the cover of your TV.Remove all screws at the back.
  2. Next,power ON the TV and check the output voltage of power supply using voltmeter.
  3. It should have not less than 5vdc for system board,12vdc for sounds and 24vdc for inverter board.If the 3 supplies are got a voltage drop your power supply had problem.For example if you check the 5vdc then the reading is 4.50vdc only.
  4. If you have voltage drop,check some leak/bulge on top capacitor on power supply.replace it by using soldering iron and soldering pump.
  5. When the power supply looks like OK,no voltage drop and no leak/bulge on top capacitor.The problem is your system board or main board.There's no easy remedy for that.You have to replace the whole system board.
I hope this solution helps you to fix your problem.Thank you and good luck.
Posted on Jun 13, 2011
mileso
  • 3320 Answers
SOURCE: I need to change the resolution to 1080 on a vizio D650i-B2
The resolution for TV's is auto sensed by the content being sent to it.
If you are playing a 720p file, you cannot make it 1080p. 720p vs 1080p Can You Tell The Difference Between HDTV Resolutions
Posted on Apr 26, 2015
I have a vizio model # d650i-b2 the sound goes out on a regular basis. what can i do?
It is hard to say but most likely you need a new main board for that TV especially if the sound goes out after it warms up
Jan 24, 2018 | Vizio Televison & Video
Vizio D650i-B2 lost picture
with the green issue I would think main. t-conns bad too. are you sure its not cable box ? we have had many with green picture issue and sound loss
Dec 02, 2017 | Vizio Televison & Video
I have a 65 inch Vizio. Model d650i-b2. It won't turn on, no startup lights, nothing. Just acts as if it's not even plugged in.. what could be my problem? Thanks
Probably you have a problem in the power supply board .
Vizio lcd or led always has a problem in the standby circuit of the power supply .
Jul 30, 2017 | Televison & Video
HOW TO IN STALL A TV BASE STAND ON A 65" MODEL NO:D650i-B2
https://support.vizio.com/s/article/ka61a000000DWK4AAO/D650i-B2-Model-Information?language=en_US
May 02, 2017 | Televison & Video
I have a Vizio D650I-B2 tv and will not turn on what so ever and I need help getting the back panel off.
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Dec 12, 2016 | Vizio Televison & Video
How do I remove the back cover on a Vizio D650I-B2
Disassemble & reassemble procedure to many popular brand TVs and other devices are given in detail with illustrations.
Jul 24, 2016 | Vizio Televison & Video
Apr 26, 2015 | Vizio Televison & Video
How do i fix the colors from my tv they are all wrong
Please use your remote to access the video portion of the setup screen. You should find a reset video to factory defaults there or in the initial setup portion. Your manual should point you to the proper section to find these.
Dec 01, 2014 | Vizio Televison & Video
Tv won't turn on
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
if it is 2,2 I have start to finish instructions for this repair in this model.
SD TECH
May 01, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Televison & Video Logo
236 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
