Question about Kenmore Kitchen Appliances - Others
Pull bottom off kenmore 4 slice toaster one screw different
  • 883 Answers
SOURCE: 4 slice toaster
open the unit. look for disconnected wires from sloppy factory
Posted on May 21, 2007
SOURCE: duraband 4 slice toaster manual model # TS-5221
if u need a manual for a toaster, then u r really in trouble...espcially for the amt of money u paid for it.
if u need instructions on how to use a goes:
A toaster is used to heat slices of bread, bagels, waffles, etc. to a hot, crispy consistency. Most toasters allow the user to set the toasting length to ensure the toasted bread comes out to temperature and crispiness to the user’s likes.
Toasters should be used on a flat, uncluttered surface near an electrical outlet but far from sinks, or running/standing water.
To toast bread in a toaster, follow these instructions:
1. Place slices of toast, one each, in the slots on the top of the toaster.
2. Find the toast setting (a knob or lever) and adjust to the desired wellness of the toast. (Generally, there is a scale printed near the knob or lever ranging from light to dark toast).
3. Push down the toasting lever (moving the slices of bread down into the toaster between the heating elements.
4. When the toast is finished, the slices will “pop” up automatically.
5. Remove the toast from the toaster.
If the bread should get stuck inside the toaster, DO NOT PUT ANYTHING INSIDE THE TOASTER in attempt to dig it out. UNPLUG the toaster, turn it upside down and shake. If the toast does not fall out, use a plastic fork or knife to gently remove it from the toaster. Using metal utensils could damage the heating elements. NEVER stick anything in the toaster while it is plugged in.
*For further safety, it is recommended that the toaster be unplugged after each use.
I wish u luck and happy toasting.
Posted on Nov 05, 2007
  • 32 Answers
SOURCE: Need replacement dualit 2 slice toaster elements
You can get any part you need at the Dualit Repair Center:
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
Posted on Jun 05, 2008
SOURCE: 4-slice egg & muffin toaster
On my fourth one the idea, but the egg poacher keeps burning out.
The 800 number is 1-800-688-1989
Calling them now...this last one only lasted 3 weeks.
Posted on Jul 28, 2009
SOURCE: T-Fal Avante Bagel Tpaster - 4 slice
Energized coil (Magnet) which holds down lever mechanism may be coated and in need of scraping for it to make full contact
Posted on Aug 31, 2009
How to take bottom off a cuisinart toaster model CPT-40
There should 4-6 screws to loosen. You may have to ring right type of head that will take it off.
Jan 25, 2013 | KitchenAid KTT340 2-Slice Toaster
I am trying to repair a Sunbeam Model T-35 radiant control toaster. Everything is working but I can't seem to get the timer control (for setting light and dark) set correctly. Is there some...
I have/had a similar problem. Here's how I fixed it.
1. Clean the crumbs out throughly. I removed the bottom of the toaster (6 screws) to make sure all the debris was removed. Use a soft brush. Replace bottom and tighten screws. 2. Gently brush the sensor area in the 'one slice' slot with a soft brush. 3. Remove 'darker-lighter' knob. I gently pried mine off with a small screwdriver. 4. Plug toaster in. 5. Put a slice of your usual bread in the 'one slice' slot. 6. Watch it toast. 7. When 'done' to your liking slowly rotate the control counter clockwise using a small screwdriver until the toaster stops toasting. 8. Replace knob with the pointer at the mid point (up and down) to allow for minor adjustments.
Aug 18, 2011 | Sunbeam Vacuums
Where do you buy the special screw driver to take the bottom ff the 44336 toaster as the toaster wont stay down on that side?
Well, I don't have that type of toaster. What do the screws look like? If they look kind of like allen but an allen wrench will not work, they would be TORX.
Feb 03, 2011 | Morphy Richards 44051 4-Slice Toaster
The bread won't stay down. The lever keeps coming back up
There is a bottom pan that gets clogged up with bits of bread, turn the toaster upside down and turn the set screw on the pan and open, flip the toaster back over and shake it, this will release a lot particles, keep at it until you removed as much as possible, this should the toaster for sometime.
Jan 17, 2011 | Kenmore KTES3 2-Slice Toaster
4 slice toaster when pressed down to start toaster they won't stay down.(either side) Yes I have it plugged in
Try cleaning the bread crumbs out of it. If you get enough piled up under the latch mechanism, you can't push it down far enough to engage it.
You may be able to do an adequate job by opening the bottom cover - most toasters are made so it's easily removed for this very purpose. If not, you'll need to pull off the knobs and remove screws so you can take off the top cover. Be careful not to touch the heater wires with any tools - after they've been used a while they become rather brittle and break easily, and even a scratch can cause them to erode and fail. I assume you know to unplug the toaster before working on it.
Jan 06, 2011 | DeLonghi RT400 Retro 4-Slice Toaster
Our toaster stopped working a little while ago, but it is outside the (presumably) one year warranty period. It's a 4 slice, soft touch black toaster, cost about £75, I think it is this model. It only...
remove from the electricity supply
remove crumb tray,
remove bottom 4 os 6 screws.
at the bottom of the toaster there is what liooks like a flat fish hook that engages with the handle when you push the handle down to start toasting. clean around this and try to get it to engage when you push the handle down, it wont stay down unless the electricity is connected but dont plug it in as you will probably kill your self!!
put it back together abd try it
if it does not work 4 slice toaster from Tesco £9.99
Nov 09, 2009 | Dualit 45375 4-Slice Toaster
Morphy Richards coolstyle Model 44880 4 slice toster
I have the 44280 2-slice version and had similar problems. To dismantle, unscrew the two star-shaped screw heads which hold the retaining slides in place. I don't have a star socket (female), only the usual male, so I used a pair of pliers. Pull out the two chrome slides. Pull off the two knobs also using pliers. Remove the outer casing with care as there are two fine wires attached. Now you can see the problem - probably a broken or lost nylon retaining catch on the electromagnet, and probably unobtainable by an individual. At this stage I decided to buy a new toaster!
Sep 29, 2008 | Morphy Richards 44778 4-Slice Toaster
4 slice toaster blows fuse when toaster uses 4 burners
You will need to move it to a different outlet that is not on the circuit that you are using or just toast 2 slices at a time.
May 06, 2008 | Toastmaster 328 Toaster Oven with...
Dualit CTS4E 4-Slice Toaster
Buy and fit a new timer switch.6 screws to remove bottom cover, pull the knob off and 2 screws hidden by the knob will be revealed, these hold the timer in. Make sure you put the wires onto the new switch in the same place you took them from.
May 08, 2007 | Dualit CTS4E 4-Slice Toaster
Kitchen Appliances - Others Logo
81 people viewed this question
Top Kenmore Kitchen Appliances - Others Experts
Charles T Nevin
Charles T Nevin
Sal De
Are you a Kenmore Kitchen Appliances - Other Expert? Answer questions, earn points and help others
