Question about GE Washing Machines
How do open the I access the drive belt on a GE front load washer model #WHDZH626foww?
dutchman05
  • 487 Answers
SOURCE: ge front load washer leaks from bottom
full display
And for the part numbers look here
Have fun with it and please rate me on this site
Posted on Apr 20, 2008
  • 5 Answers
SOURCE: GE front load washer model #WBVH6240FWW leaks when
Check the big rubber seal around the door for any holes or tears. Had the same problem, my husband had a screw in his pocket that torn a hole in the gasket.
Posted on Sep 27, 2009
  • 1531 Answers
SOURCE: Washer is not draining. How do I remove the front
you will need to remove the lid first then remove the screws that hold the control panel in place.then you will need to remove the door boot on the front panel. there will be two screws on the bottom of the panel that will need to be removed as well as the screws on the top of the panel.
Posted on Feb 15, 2011
Testimonial: "Thanks so much, really appreciate the quick response!"
  • 121 Answers
SOURCE: ge front loading washer door won't unlock
I had the same problem. I didn't want to spend the money or go to the trouble of replacing the whole latch assembly with the GE latch repair kit.
I found that the plastic latch piece screwed to the door had broken and one of the two latch "fingers" was stuck in one of the latch openings on the washer. I fixed the problem by removing the broken part from the washer and drilling and countersinking very small holes (1/16" I think) in the plastic latch piece on either side of the "latch finger". I then put the broken off piece back in place and drillled pilot holes for #4 sheet metal screws in the door where the latch is located. The door liner is plastic and I think I used a 1/32 inch drill bit. I reattached the broken latch piece with two 1/2 inch stainles steel #4 flat head phillips screws from Home Depot. The screws hold the broken latch piece in place as orinilally positioned.
The repair is working fine and the door now latches like it did before the latch part broke
Or: http://www.appliancepartspros.com/part_details.aspx?image=0&part_id=2045520&pn_=WH10X10002 Same part cost $200 direct from GE
Read more: http://forum.appliancepartspros.com/washer-repair/8379-ge-washer-front-loader-door-wont-stay-latched.html#ixzz1LmNUKfTN
Posted on May 08, 2011
  • 44 Answers
SOURCE: my GE model wcvh6800j1ms front
Front right would most likely be the discharge pump. Here's a diagram:
Sounds like you could have a pump problem or a loose hose. First, go ahead and clean the drain pump filter (as per instructions in the Use & Care Manual). Screw it back in tightly to see if that resolves the issue.
If not, check this posting for how to run a diagnostic test: http://www.fixya.com/support/t9576766-found_small_part
Test T02 will show you the most recently encountered codes. At the bottom of that posting is a link to the code definitions with problem resolutions: http://www.fixya.com/support/t9556917-ge_model_wcvh6800j_error_code_04
If you don't get any error codes and all tests run correctly, open the front access panel and see if you can figure out where the leak is originating from (To remove the panel: undo three screws and lift from the bottom).
Please post back once you either have codes or have located the leak source...then we can troubleshoot more.
Posted on Jul 28, 2011
Spin. Working short time do not put cloth water out
Sounds like the belt that spins the washing drum is slipping. It my need to be adjusted or replaced, or try washing a smaller load of laundry.
Mar 10, 2016 | GE Washing Machines
Ge washer sbsd227fxx water 9c3
i need the part number for ge front load washer driver belt model sbsd227fxx
Aug 24, 2013 | 1998 Citroen Saxo 1.1
My daughters GE same model washer will not agitate. Stop agitating after just a few months after being purchased. I believe this is a trait from this type of washer. Perhaps GE needs to recall them all...
Premature failure usually is a reuslt of overloading and/or not enough water. So, there is a rubber drive component that fails and some models have agitator pawls, or dogs that fail. Both are fairly easy to change, and not pricey, except for labor..
Feb 07, 2011 | GE WBSR3140DW Top Load Washer
HOW DO I CHANGE THE FINS ON MY FRONT LOAD WASHER?
open up the top cover and the front,then the rear access panel,remove the drive belt,then the spinner pulley,then you can push the drum and spline shaft out the front to replace the baffle/paddles,i would replace the lip seal if you remove so as to protect the drum drive bearings
Mar 23, 2010 | GE Washing Machines
Cannot get drive belt on ge washer model #whdsr316g1ww
I have a front load kenmore washer. Initially the machine didn't drain the clothes fully, then the belt came off. The belt will not stay on. Help
Feb 25, 2010 | Washing Machines
Washing machine won't turn back and forth
Most likely your drive belt has slipped off. Open up the back of teh washer and see if the drive belt has slipped off and ease it back on with a screwdriver.
Jun 29, 2009 | GE WSXH208A Front Load Washer
Changing the belt on a GE front loading washer
Hello , i can try to help , I have always got these belts on by starting the belt on the small pulley/motor , then rolling it on the large pulley , kinda like putting a bike chain on. Let me know if you have any other questions and how it turns out.
Phil
Jan 07, 2009 | GE WSXH208A Front Load Washer
Washing Machines Logo
23 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
