Question about RCA Televison & Video
RCA 46 projection tv power button quit working.
ctf1800
  • 4402 Answers
SOURCE: RCA 46" Rear Projection TV-How do you adjust the convergence colors
are you looking to correct the problem or make and adjustment
adjustments you can do from the remote once you in the menu
however if that doesn't fix your problem most likely it need convergence ic's
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 05, 2007
  • 1030 Answers
SOURCE: RCA 56 inch projection TV
six inches will just reach the bottom of the main cuircit board. Does the units green light flash? there is no reset hutton there is a fuse. but i would suspect if it got wet then something blew
Posted on Feb 18, 2008
  • 11 Answers
SOURCE: 46" RCA, CTC169PA, pulsating power supply.
HV Splitter!
Posted on Feb 19, 2008
Slinteriors
  • 8617 Answers
SOURCE: SET JUST CLICKS WHEN POWER BUTTON IS PUSHED
I would check the low votage regulators, horizontal output and the flyback. The relay is the first stage of the start up process so the standby voltages are suspect as are the oscilation / Hv circuits. how are your trouble shooting skills?
Posted on May 23, 2008
yambo
  • 230 Answers
SOURCE: RCA 46 inch convergence problem
AM sorry, but can you provide your model number TV and chassis please?. I will tell you location parts. Thank you
Posted on Aug 13, 2008
Where is the reset button on an rca model#p46924 46" projection screen tv?
Hello
Reset button is on its remote control itsef. You can locate it at the bottom right side. Point it towards TV, and reset the setting you want to. OK.
Apr 22, 2011 | RCA P46924 46" Rear Projection Television
I have a 60" RCA D56W02B rear projection TV. I've
Yes,the power supply board,where the actual power a/c cord plug into it,are most of the causes of power LED light blinking problems.
Feb 17, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
D52W19 RCA 46 inch t.v.
my RCA D52W19 52" rear projection TV will not power up ( turn on )
Nov 17, 2008 | RCA D52W19 52" Rear Projection Television
RCA P52721LV
In the back where the power cord comes into the unit there is a small fuse there, replace and try.......
Sep 21, 2008 | RCA P46924 46" Rear Projection Television
RCA P46924 46 in rear projection tv will not turn on
More than likely it has bad solder connections on the circuit board. You could try tapping lightly on power supply/deflection boards to see if it makes contact. Usually I find bad solder on those right under where the power cord plugs in, on the bottom of the board. If you have a soldering iron and solder you could save a few hundred dollars in repair costs, but use caution and make sure all power to set is disconnected. Maybe mark each plug as you disconnect them. Hope this helps. Good luck, Russmann.
Jun 02, 2008 | RCA P46924 46" Rear Projection Television
No power
Yes could be several problem, the first one in my mind is burt horzirontal transistors, Q14401 or bad hight voltage block.
Could be convergence problem that is causing the system to shout down.
Hope this helps
What About Bob
Mar 01, 2008 | RCA P46924 46" Rear Projection Television
Power, volume buttons
Is this on the remote or the buttons on the TV?
Aug 17, 2007 | RCA P46810LV 46" Rear Projection...
Televison & Video Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
