Question about Lands Phones
I have a 3 set of cordless phones and the base set is working the other two say that there is no line. If I connect a regular plug in phone it wrks fine. how do I fix this or get replacement?
SOURCE: Cordless phones will not connect to base.
I just had the same problem and tried several things with no results. Then, I figured I had tried everything else so I just unplugged the battery pack, set the phone down for 25 minutes and then plugged the pack back in. Phone worked again after that.
Posted on Nov 14, 2006
  • 3 Answers
SOURCE: base not able to connect to handset.
I successfully reset Radio Shack (Uniden) 5561 handset by reconnecting the battery while holding the '*' and '#' key, then press the right upper soft key near the LCD window. The display will indicate "EEPROM/RAM cleared!!" and will return the handset to the factory default condition - looking for a base to register to.
Posted on Mar 23, 2008
SOURCE: cordless phone does not connect
You may need to reset the Telephone Answering System. Complete the following steps to reset the Telephone Answering System:
Step 1: Disconnect the power to the telephone base.
Step 2: Wait a few minutes and then reconnect the power to the telephone base and charger.
Step 3: Set the day and time.
Posted on Apr 03, 2008
  • 47 Answers
SOURCE: My Phone will not connect to the base unit...
My handset displays CONNECTING...
Move the handset closer to the telephone base. You might have moved out of range.
This is what was listed in the Vtech Manual.
What I suggest is not just powering it off, but remove battery and wait a couple of minutes. Put battery back in and try it. The other thing I suggest is a new battery or switching it temporarily with a phone that works, to see if that helps before you buy a new one. If the battery is weak it will have trouble reaching the base.
Posted on Jan 06, 2009
RPFinney
  • 385 Answers
SOURCE: cordless phone not connecting to base. no dial tone.
switch the A/C mains off 5 minutes
or
Re-register them to the base,
This resolves the problem
Regards
Richard.
Posted on Apr 26, 2009
Base handset has interference.
If you still have a regular phone about, plug it inhere the base handset is connected and see if the symptoms remain. If they do, the problem is likely with your house wiring or the phone company. If no interference on the regular set, base handset may be defective. Try it at someone else's house.
Radio Shack (hurry :) has in-line filters that may clear up line noise.
All he best
Mar 06, 2015 | Uniden DECT2188 DECT 6.0 Expandable Corded...
My DECT6.0 telephone will not give me a dial tone nor answer any calls neither will the additional handset..Although my verizon direct line functions as it designed
Hello.
Here are some tips, found online:
Reset the phone:
Unplug the battery in the handset, unplug the phone line from the base and unplug the electricity from the base. Leave everything unplugged for an hour or two instead of a couple to five minutes that way you can get more of an idea of whether your phone will work. After an hour or two plug in everything. If resetting the phone doesn't work then try the next step.
Check the surge protector:
Is the phone line plugged into a surge protector? The surge protector may have stopped working or blown a surge, a sudden burst of electricity, which may have caused the dial tone in your cordless phone to go. Unplug the phone line from the surge protector then plug it back in and see if you get a dial tone. It could be that the phone line plugged into the surge was loose or not plugged in securely.
Try a different phone plug, outlet.
Check the base:
Is the base dusty and have possible dirt in the prongs where the phone sits? Lift the base and blow off dust.
Check the handset for dirt.
Rub metal connections on handset and base:
Use a pen cap or coin and rub the metal connections on the bottom of the handset. Rub the prongs, metal connections on base.
Hope these suggestions help.
Jul 25, 2011 | Uniden Cordless Phone
Phone says check telephone line
Unplug your Phone and plug in a regular un-powered phone. If it rings your cordless base station is bad and you will need a new one if it does not ring then there is a problem on your phone line and you need to contact your phone company. Note, the phone company will charge you for repairs inside your house.
Mar 07, 2011 | Uniden Cordless Phone
Phone is not working
Mar 02, 2011 | AT&T 650530003417 Cordless Phone
I connected an elite 9035 to charge the handsets but also connect the phone line at the same time which i later realized was not as the instruction manual recommended. i am not able to make (no dialing...
Sep 15, 2010 | Uniden Cordless Phone
Buzzing on the phone line with incoming calls on a uniden CORDLESS phone - Model # XC310
Sep 03, 2010 | Uniden Cordless Phone
Suddenly line 2 only works on wired phones
Here are a couple of things to try. First is to disconnect the base and install a regular two line phone to verify that line 2 is ok at that jack. Also on Panasonics website, when you unboxed and installed that unit, there was a cord that had green plugs on it. That was a 4 conductor cord. If somebody changed that out to a 2 conductor, it could cause this. Also it could be a defective cord. If you have another 4 conducter cord from the wired phones, swap it out. Make sure on the base, on the back, that it is plugged in to the correct plug, marked line 1/2. Basically if a regular 2 line phone works, it is possible that the unit is defective. Also maybe unplugging the base from power and resetting that may fix it also.
If that does not help here is Panasonics number.
1-800-211-PANA(7262)
Jan 05, 2009 | Panasonic KX-TG2740 Cordless Phone
I bought a Uniden cordless phone, put the batteries in (it has 4 remote bases) and charged it for 20 hours as instructed. I tried calling it on my cell phone but I'm not getting s response. The display...
Double check that the telephone cord is firmly plugged into the back of the cordless phone base, the wall outlet, the outlet where the telephone modem is and at the L1/L2 jack on the back of the telephone modem. Your phone is not getting the dial tone line voltage from the telephone modem to the cordless base. There might be a short in the wiring. (It is unclear as to whether you are setting an old phone into this new base or swapping out and using another base with the old phone. Irregardless, the problem would seem to be not in the phone but ratther narrowed to the cord between phone modem and phone base. That is a very good reason to check how firmly the cord is plugged in.
Aug 27, 2017 | Lands Phones
2 Telephone lines and one phone jack
Most of the Cordless 2 line phone BASE UNITS have the connections on the back for line1/line2 or seperate line 1 and line 2 connection. If you have the type of phone with the line1/line2 jack you have to be sure that both lines are on the same wall jack, otherwise make sure the phone you purchase has seperate line jacks and you will have two phone cords going to the base unit.
Jul 26, 2008 | Lands Phones
Do you need to purchase a special plan from your phone provider in order to use a digital cordless phone...or can you use your regular landline connection?
Nope you can you use a digital cordless phone on any analog or digital line. The term "digital" in refrence to the phone just means that the wireless signal between the base and the cordless is digital. Where as the actual line that the base is plugged into can be analog or digital.
Hope this helps
Jul 06, 2008 | Lands Phones
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
