Question about Garden
I have a 20 hp mahindra tractor with front end loader the problem I am having is it will not go up a slight hill in forward or reverse what can I do thank you
  • 1,181 Answers
If it is a hydro or automatic it sounds like you need to check fluid levels, if manual trans you may need a clutch or clutch adjust
Posted on Dec 12, 2016
  • 7 more comments
  • Bruce
    Bruce Dec 13, 2016
    Thank you for your help
  • D. E. Hev Dec 13, 2016
    I hope it did help, further test if it is manual trans. To check to see if clutch is slipping edge up to a stump or some such stable object like a pile of dirt that will not move, put it in first and release the clutch at idle. If the clutch is good it should stall the tractor.
  • Bruce
    Bruce Dec 13, 2016
    I got the tractor for my son and it is a hydro should I still check the clutch that way
    No only for clutch type, First thing on a hydro would be check for low fluid, clogged filter or lever slipped and not moving far enough. After that things get expensive.
  • Bruce
    Bruce Dec 13, 2016
    I think I'll have to get a service manual for the 2015 I'll check fluid when I get to my sons on Thursday should I dump all the fluid and put new filters on and what type fluid should I use thank you
    Try this site
    Good luck, may just be that a brake is set or something, are you saying model 2015 or year 2015 as the model 2015 was 28hp I think
  • Bruce
    Bruce Dec 13, 2016
    Just checked with my son it is model 2015 and is 20 hp
  • Bruce
    Bruce Dec 13, 2016
    2015 hst
Mahindra 4035PST tractor forward/reverse sticks
Don't waste your money
on unnecessary sources and unwanted repairs. Get this manual online at and get complete guide on whether to repair or not, service it, and how to repair etc
Mar 13, 2018 | Mahindra Cars & Trucks
Riding Lawn Tractors with Hydrostatic Transmission Tip of the Year
Hello everyone! IF you have a riding mower or tractor with hydrostatic transmission you are going to love this insider's tip. Slightly overfill the transmission. Always keep the fluid level about 1/4 inch above the full line on the dipstick. Once you have done this you will instantly notice that the tractor has more speed in forward and reverse. You will also notice that it has more power when mowing up hill. Doing this solved several problems I was having with low power and also slow reverse. I had adjusted the linkage but it did not solve my problem, adding the additional transmission fluid did. Enjoy your more responsive tractor! Joe
on Oct 14, 2010 | Garden
My lt1000 will move slowly in reverse and when going up an incline you have to move the shifter around to make it keep moving ,any ideas on what the problem is?
This may be normal. slow in reverse is normal. Up a hill, if you are talking about keeping forward on the lever, this is normal. If you are talking about moving it fore and aft or left and right to get up a hill, needs adjustment.
May 30, 2014 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Have a JD 300 with front loader. The tractor will not go forward when the tractor is started. It has a reverser and will go backwards immedictely when started. If the weather is real hot it will take...
Hi, don't know if you have checked this but anyway if you hydraulic oil filter is clean there may be another sintered bronze filter in the sump of the hydraulic tank this could be patially blocked> don't know this particular machine but if it is partially blocked it may be that you will clean that or there is air in the hydraulic system. Hope this is of some help.
Sep 29, 2013 | John Deere Muffler 1010 Diesel Tractors
Mower slips in and out of forward gear but rides perfect in reverse;What do I need to adjust?
Reverse is a different gear set than forward gears. Sounds like forward gear set has a broken tooth. Not an easy fix.
Jul 18, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Hydrostatic transmission
They are not fast going back but they are strong. The belt is looseing tent ion bad belt.
Jun 21, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Tractor will not go in forward gear, only reverse.
Try rocking the mower forward and backward while you try to shift it.
Aug 19, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Will not go into gear
a hydro uses a foot pedal on the right side , you push forward to go forward or rock the pedal rearward to go in reverse - a regular transmission has a shifter usually between your legs for reverse 1st 2nd or 3rd gear - you also said the blades wont engage . are they electric ( with a switch ) or do you manually move a lever .
Oct 23, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
112 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
