Question about Garden
Transmission fails to move tractor attimes Why
    Top Expert:
  • Garden Master
  • 8,155 Answers
My RZ4623 will not move.
If the unit stopped moving at once. I suggest checking the belt. It is very unlikely both Hydro-Gear units would fail at the same time. check under the mower, and check on top of the transmissions, you should see the drive belt running between both transmissions and the engine.
Feb 15, 2015 | Husqvarna Rz4623 46" Ztr Lawn Mower Zero...
Why wont my john deere d140 move when I ngage the double foot pedal
The drive belt may be broken, or it may have slipped off a pulley.
Aug 03, 2014 | John Deere Garden
I have a JohnDeer TRS 22. it starts fine butbthen shuts off when i engage the transmission. any suggestions.
You tractor may have a switch under the seat that has failed. Many tractors have this as a safty feature to keep the tractor from moving if the operator is not seated.
Dec 09, 2013 | John Deere Trs22 Snowblower Operators...
Will not move forward or back
either the drive belt which connects the crank shaft pulley to the top of the transmission pulley has failed, or the hydrostatic transmission has failed. the first is easy to spot, a broken belt, and fix; the second problem basically means you will spend more to buy a new transmission than another mower will cost.
Mar 29, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
What is the main problem with mower not wanting to move forward or reverse?
if the engine is running, but the mower is not moving generally you have a problem such as:
1) the main drive belt between the engine and transmission has failed
2) the main drive belt is good, but the hydrostatic transmission has failed.
first issue can be resolved by about anyone with a good selection of tools, a twelve pack, and a couple warm sunny hours. second issue means you are going to get a new mower unless you have an expensive mower and it is worth spending 1500 dollars to get a new transmission for it.
Mar 16, 2011 | Briggs & Stratton Garden
La 115 with hydrostatic transmission will not move forward or backwards with engine running
if there is no problem with the drive belt getting power to the transmission, then the transmission is failing.
Aug 22, 2010 | John Deere Garden
Mower barely moves forward or backwards with or without the blades turning,engine runs fine but can't seem to get mower to move
Well you have a fault with the belt which goes from the engine to the transmission being too loose or the transmission itself has failed. Get underneath it and, with the engine cold and not running, grab hold of the belt and see if there is any slack in it. This would be the topmost belt, it should not have any slack in it unless the clutch pedal is pressed down. Don't try this with the engine running unless you have an extra set of fingers and a surgeon at hand. If the belt is good then your transmission has failed and you need another mower as the cost of the transmission will exceed the value of the mower. There are mower boneyards around and used trannys for sale on ebay, but most likely you will be looking for another mower.
Aug 01, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have 2001 Husqvarna lawn tractor model YTH1746 wnt go into gear
those fluid drive transmissions fail on quite a few brands as they all use the same ones....replace the trans...they are expensive but still cheaper than a new mower.
Jul 21, 2010 | Husqvarna Ariens 46 In Deck 20 HP Kohler...
John deere stx38 wont move transmission locked up?
Engine OFF, raise drive wheels and check if transmission is locked
Jul 14, 2009 | John Deere Garden
Craftsman LT2000 brakes are failing
On the tranxaxle near the right rear wheel is where the brakes are located. There will be a rod going back to a lever. This lever will have a nut on it. Tighten the nut with a 1/2" wrench. With the transmission in neutral on level ground ensure the mower can be moved with slight resistance.
May 19, 2009 | Garden
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
