Question about Garden
26Hp Briggs (44677) runs on either cylinder but only runs on one side when both are hooked up.
    Dedicated:
    Visited the website for 20 consecutive days.
  • 242 Answers
If it is a Vanguard it has two coils, each has a kill wire from it to the key switch, each kill wire has a diode in it to separate the two coils from sharing the spark from the other cylinder through the kill wire. I have bought new diodes from Radio shack and soldered them in place of the originals. But it looks like they want you to buy a new wiring harness.
26Hp  Briggs (44677) runs on either cylinder  but  - 78f4f22f-7d57-4f1e-bd5e-e2b50cafcb3c.jpg
Posted on Dec 15, 2016
Only firing one cylinder, replaced both plugs and one coil? What else could be causing this?
Justin, Did you replace the right coil, are the leads good,
Are both the triggering magnets still in the fly wheel,are they clean? Touch any piece of metal to both of them and make sure they are equal strength or close to it. If one magnet weak replace.
Twin cylinder briggs and stratton not firing on 1 side
22hp twin Briggs running on one cylinder at idle MyTractorForum com The...
Lawn tractor 1 cylinder not firing General Discussion Forum In Depth...
Briggs 422707 Firing one cylinder
Feb 09, 2016 | Garden
My 26hp briggs will not charge my battery
Check connections going to regulator or replace regulator. Thank you for using fixya.
Aug 14, 2013 | Briggs & Stratton Garden
New craftsman 26hp gas out exhast
sounds like the float in the carburetor is not functioning correctly.
After the mower was turned off did gas start to drip out by the carburetor?
Jul 13, 2013 | Garden
Have just bought craftsman mower gas spraying out exhast
Float was stuck and it may be OK now , but were I you I would add a fuel line shut off and turn it to off between uses .
Feb 15, 2018 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Riding mower with 26hp briggs and stratton motor runs about 20 to 30 minutes thens cuts out
It sounds electrical in nature check the solenoid for continuity, check your key switch it may be bad also, check the spark plug wires and the part they hook into. Look for melted wires and replace as needed.
May 11, 2012 | Husqvarna Garden
Engine needs rebuilt
Hello
HAve you Checked the Valve Clearances on the Dead Cylinder?
If the Valve Clearances are Not Correct, then you will have a Dead Cylinder as you Described.
I No Longer Suggest Rebuilding Engines.
The Cost of Parts and MAchine Shop Work is Usually More than a Short Block or Complete Engine.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 10, 2009 | Garden
Replacing engine. Briggs 26hp on GT5000 garden tractor
Unfortunately, there is no single manual for this. It depends entirely on what crankshaft the OEM requested be used in the engine. You need to find out the diameter of the crankshaft and any threading to it, direction of the threading, etc. From there, a replacement can usually be found pretty easily. That or contact Briggs customer support (number in your owners manual) with the Model, Type and Code numbers off the engine. From this information they can see how the engine was outfitted for that OEM. Horsepower tells them nothing as those ratings and stickers are often replaced by the OEM and often NOT the information Briggs sends out on the engine.
Mar 07, 2009 | Briggs & Stratton Garden
Garden Logo
67 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
