Question about Singer Sewing Machines
My singer sensation model 9410 doesn't pick up the bottom thread to make its stitch. What can I do to fix this problem myself.
  • Singer Master
  • 12,042 Answers
Try installing a brand new needle and verify that it is installed with the flat side facing the correct direction in the machine.
If this doesn't improve your situation, most likely your machine has been knocked out of time. Search for sewing machine timing or take it for service.
Posted on Dec 12, 2016
    Top Expert:
  • Singer Master
  • 8,248 Answers
The bobbin housing in singer model 9410 keeps moving out of position
After you put the bobbin case in, release it, and then pull on it to make sure it is in correctly.
The gathering is called a "bird's nest", and is caused by the machine not being threaded correctly.
Rethread the machine top and bobbin.
Then, sew a test stitch on a scrap of like material.
Apr 08, 2013 | Singer Sewing Machines
Singer stylist 477 bobbin case problem
a bit difficult unless you are a machine mechanic or have a detailed workshop manual beside you
I would not waste time DIY and would take it to a reputable sewing machine repair shop
Nov 26, 2017 | Sewing Machines
Bottom thread lose on my Singer Confidence 7467 model
try adjusting the top thread tension one letter or number higher
till the stitch looks good
Jul 23, 2012 | Singer Confidence 7467 Mechanical Sewing...
Using a White model 616 with a twin needle?
singer has a free manual in pdf form for the machine, which can tell you if the machine is capable of using the twin needles
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example w616 ) & click search
May 21, 2012 | White Sewing 1866 Mechanical Sewing...
My singer model 237 makes a stitch that doesn't look right. The bottom thread is just goes through the top thread loops under the material
Hi, if stitches are off, there is a problem with balance between the upper and lower stitch adjustments. You have to tweak these. Also, make sure there is no lint in the bobbin case area or under the feeddogs. Here is an excellent blog for 237 Fashion Mate owners. You are lucky to have one of these from the 1960's. http://blog.sew-classic.com/2010/02/02/singer-237-fashion-mate-sewing-machine-reveiw.aspx
Happy Sewing!
Jul 17, 2011 | Singer Sewing Machines
I have a Singer 2662. It has quit picking up the thread to make a stitch.
Try a new needle. If that doesn't work, then the timing is probably off. Check for a broken or stripped gear.
Apr 20, 2011 | Singer Sewing Machines
Singer 9410 bobbin problems
It should not affect the winding, the reason the needle is still going up and down is because the oil has gone dry on the shaft and unless you can get to the shaft where the balance wheel is then it would be wise to take the machine in for a service, loose stitching on the bottom is a tension problem, make sure the top tension is set about 4 or 5
Oct 26, 2009 | Singer Sewing Machines
I have a Singer 9410 sewing mach. w/ tension & peddle problems
Be sure you are using a Class 66 bobbin for this Singer machine. Using another style bobbin can cause tension problems and thread looping/bunching.
Apr 23, 2009 | Singer 7442 Mechanical Sewing Machine
Loose stitches on bottom
FYI.. Loops on the bottom, problem is on the top..
Loops on the top, broblem is with the bobbin.
Apr 11, 2009 | Singer Sewing Machines
Sewing Machines Logo
49 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
