Question about Garden
Have a 13 year old Toro two stages now thrower...left auger just spinning right auger works...can't find any info to repair......Help please....
2 Suggested Answers
rabbitbrains
  • 575 Answers
SOURCE: I have a Toro two stage snow thrower that has an auger issue..left just spins as it want the right moves snow....how do I fix...the machine is 13 years old can't find any answers....help please.
The shaft has shier pins that break when an object gets caught in the auger. This prevents further damage. You will need to replace that pin. Make sure you stop the blower, unplug the spark plug before working on it. The pin holds the auger to the shaft. Turn the auger until you see the hole through the shaft and insert a new shier pin.
Posted on Dec 12, 2016
Dec 12, 2016 | Garden
I JUST PURCHASED A SINGLE STAGE SNOW THROWER FROM LOWES. WHAT IS THE DIFFERENCE BETWEEN A SINGLE STAGE VS A DUAL OR MULTI STAGE SNOW THROWER THANKS DON DMH8@AOL.COM
a single is just that a single auger that scoops snow and shoots it out chute their a smaller unit --a dual front auger scoops snow into another auger which shoots the snow through the chute the duals are bigger and they move more and heavier snow
Nov 26, 2016 | Garden
Where can I find detailed instructions on replacing an auger?
first remove the chute. then remove the bolts holding the auger in place. then rotate shaft by hand and find the two roll pins that hold auger assembly shaft. drive these pins out and you auger will slide out the front of unit
Aug 28, 2014 | Yard Machines 26" 208cc Two Stage Snow...
Left auger does not engage/spins freely
The shear pin is sheared off. Somewhere along the auger, you'll find a hole drilled all the way through it. The shaft inside also has a hole drilled all the way through it. Compare the two augers - the holes are USUALLY in a straight line with each other (when one is up/down, the other is also up/down).
Get a replacement shear pin (DO NOT use a hardened bolt!) and put it through the holes when the auger holes are lined up with the axle holes.
Feb 19, 2014 | Toro Power Max 724 OE 24 inch 205cc Two...
I have Toro 826LE model 38620 S/N 250010001 & up snow thrower; one side agur will not turn under power and free wheels by hand. The problem occured this morning, there was no indication of a problem...
It sounds like you have sheared a roll pin. Look at the auger that is not turning, on one end you will see a hole, there is a steel pin that goes through the shaft, I am pretty sure that pin has sheared and allows the auger to spin freely on the shaft. You may have to find a small punch and drive out the broken piece before inserting new one. Seeing how the auger has been spinning on the shaft you're gonna have to line up the hole in the auger with the hole in the shaft. Look at the good side to see alignment. Hope this helps ya.
Dec 21, 2010 | Toro Garden
My toro 1128 OE snow blower wont throw snow the auger turns but the thrower doesnt rotate. Does anybody have any suggestions
I have a toro 98 cc powerlite snowblower model 38182 it was running fine one day then bog down and died after that i cant get it to start it has a good fire on the plug plug isnt very wet it pops threw carb once in a while help
Dec 26, 2009 | Toro Lawn Mower With Toro Power Tools
Where is toro 31820 auger shear bolt?
Shearbolt is located at #54 in this diagram.
https://homeownersolutions.toro.com/portal/server.pt?space=CommunityPage&cached=true&parentname=CommunityPage&parentid=1&in_hi_userid=19462&control=SetCommunity&CommunityID=214&PageID=238#drawingDiagramPage
part#322-9
It may be hard to spot on the auger shaft as it may have sheared flush with the holes so look close. You may also need to remove the part of the bolt remaning inside the shaft.
Dec 22, 2008 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
