My furnace blows only lukewarm air. It fires and burns good and blows good volume of air
  • 10,137 Answers
Check the induction fan motor to see of it's running at the correct speed. Flame tips on the burner must be blue.
Posted on Dec 14, 2016
koolbreezes
  • 540 Answers
SOURCE: on a standing pilot, coleman
HEY J, this could be a dangerous situation. You could have a crack or rusted out heat exchanger, if this unit is over 20 years old, which it is because it a standing pilot, units are obsolite! This could be letting in CO2 ( carbondioxides-- poision gas fumes) n, Oklahoma, our gas co. will come out for free to give our units a CO2 gas fume check anaylsis. Check this out before someone dies or ill repairable damage done to the body! Thank-you-very-much!
Posted on Aug 30, 2008
  • 25 Answers
SOURCE: I have a sears forced-air
You probably have a bad Thermo-couple . It is a copper looking rod that sets in the flame of the pilot lite It also has a copper wire that goes to the main valve and connects with a 1/4-3/8 nut or a metal clip. The purpose of this part is to tell the computer that the flame is lit and all is good, but it fails often with the same symptoms.
Be very carefull not to touch the white ceramic igniter, for it will fall apart and that will cost you 40.00 bucks to replace. The last time I replaced my thermo coupler on my furnace, it cost 9-10 bucks and most hardware or heating supply will have it.
. But remember use the proper tools, don't just grab any old pliers, look very carefully and u will be ok.
good luck, mule460
Posted on Oct 17, 2008
diths_kri
  • 67 Answers
SOURCE: furnace blowing cold air
THERMO
Posted on Jan 07, 2009
meBNme
  • 334 Answers
SOURCE: My Ruud Achiever 90 Plus not blowing cooled air
Look on the condensor, (outdoor unit) at the very bottom of the rear panel and you should find a red reset button. push it. If that does not solve the problem, and the outdoor unit is running (make sure both the fan AND the compressor are running) then you are looking at a low refridgerant issue and possibly dirty coils.
In that case, clean the coils and have refridgerant added.
Posted on Sep 24, 2009
  • 3 Answers
SOURCE: I have a intertherm furnace
There are two motors in an AC. One is the fan motor and is controlled by a switch. The other is the compressor motor. It's operated by the thermostat. If the thermostat doesn't work you'll only get warm air (cooled only buy the fan) because the compressor is not doing it's job of compressing and releasing the freon.
Usually when this happens it's mostly caused by the thermostat. It also can be caused of a bad compressor motor or a locked up compressor.
Posted on Oct 21, 2010
I have a carrier furnace and it seems to be only blowing out lukewarm or cold air and my house only gets up to 63 degrees
Make sure your filter is clean and that your heat registers are open and the cold air return is not blocked. So if you turn your thermostat up to 70 degrees is the burner shutting off before the house gets up to temp? If the thermostat has batteries are they new? Out side of that you may need a service tech.
Jan 01, 2018 | Carrier Heating & Cooling
Goodman GS9 blowing air but not getting hot
Does furnace fire up ,if not you have a issue with your furnace and not thermostat
Feb 12, 2018 | Goodman GMS90703BXA Heater
I have a intertherm furnace model mac1175 series, it's blowing lukewarm air, how do i get hotter air ?
Oct 21, 2010 | Heating & Cooling
Goodman furnace app 6 yrs old blower only runs app 4 minutes then kicks off does this continuously
You need to remove the blower ,blow it out with a good air compressor. oil if if there is a place. be sure to blow it out once a year. its thermo protected. To stop from burning up the motor.
Aug 17, 2009 | Heating & Cooling
Gas Furnace is not heating anymore.
the fan you hear come on at a call for heat is most likely just the inducer motor. the click you hear is probably the relay for the hot surface ignitor which should glow red, then in turn ignite the main burners. your going to have to determine if the ignitor is coming on. if it isnt the ignitor is bad and will need to be replaced. if it comes on and than shuts off after a few seconds the ifc board is probably at fault
Apr 09, 2009 | Heating & Cooling
Furnace blower blows cold air
It is possible that you did not set the new blower on the proper speed. Black wire is high. Blue is medium. Red is low. If the fan is operating to slow it can run to hot and trip the high limit control. Make sure the filters are clean. When the old motor went bad, the problem might not have been discovered rite away your high limit control might need to be changed.
Also anytime you work on a furnace you can kick up some dust. Always clean the flame sensor.
Good Luck
HVAC Teacher
Mar 08, 2009 | Honeywell Power Humidifier: Furnace...
1997 2500 dodge ram only blows lukewarm heat, what could be wrong?
It can be not enough coolant. Check the coolant level. Also the regulator can be at the position than car takes air form outside not inside. Have it checked too.
Good Luck
Dec 15, 2008 | 1995 Dodge Ram 2500
I have a sears forced-air furnace that automatically lights. It will go on when I first turn up the thermostat. It burns and produces heat for about 10 to 15 minutes. Then the burner goes out and it starts...
good luck, mule460
Oct 17, 2008 | Heating & Cooling
Heating & Cooling Logo
50 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
