Question about Proform 110R Exercise Bike
My proform gr80 stationary bike panel won't work. I have changed out batteries and cleaned it. What else can I do?
2 Suggested Answers
jbiggs8150
  • 14 Answers
SOURCE: proform xp 70 stationary bike console is not getting power
IF BATTERIES ARE NEW THEN CHECK THE CABLE AND CONNECTION FROM BATTERIES TO THE CONSOLE.MAKE SURE ALL CONNECTION ARE TIGHT AND CABLES ARE NOT BROKEN,FRAYED,CRACKED,OR CORRODED LOOKING.ALSO MAKE SURE SAFETY DEVICES(KEYS,PINS,CLIPS) ARE IN PLACE .
Posted on Oct 13, 2012
The electric display does not work on my stationary bike
It may sound daft.But giving the infomation in your question,Maybe try changing the batteries.
Oct 11, 2017 | Nautilus Nr Recumbent Exercise Bike
The console will not turn off with new batteries
Leave the machine for a few hours. You may not be giving it enough time. Also you may inadvertently changed the settings. Check that.
Sep 15, 2013 | ProForm XP 210 Upright Exercise Bike
Half of my panel does note work it is proform 595
adjust the REED switch, test it for open or faulty. clean it, and plug it the terminal. see the diagram attached.
2) Tight the ribbon cable for keypads.
3) Replace the batteries by new ones FULL charges, with the same type, same polarity, clean the contacts batteries v.well
God bless you
Dec 06, 2012 | Proform 595 LT Treadmill
Proform xp 70 stationary bike console is not getting power
Oct 13, 2012 | ProForm 70 Perspective Treadmill
Proform GR 80 won't turn on even after new batteries, how do I fix?
On mine, I found that the battery contact springs on the inside of the control head (not the ones on the battery lid) were flattened out and were no longer making good contact with the batteries. I used a small hook to stretch them out a little so that they could make contact. As soon as I put the batteries back in I saw the display light up and now the bike works normally again.
May 17, 2012 | Exercise & Fitness
Proform Crosswalk display will not work. Belt and incline work fine. Have changed batteries, adjusted reed switch to within 1/8
adjust the REED switch, see the diagram for to do it. clean, and tight the connector very well.
God bless you
May 11, 2012 | Proform Crosswalk Ls Treadmill Walking...
Proform gr 80 recumbent exercise bike cant get the display to turn off when I get off bike. battery powered?
The GR80 uses for type D batteries. The battery compartment is on the bottom of the console, look for the D-shaped battery door, press the tab located towards the front side of the console and open the door. Careful, the batteries may fall down if you open the door - type Ds are heavy enough to be felt when they fall on your feet.
Jan 16, 2011 | Proform GT 85 x Upright Bike at GNC
How do i change the battery vitamaster 62c Stationary Bike
Simply pull the indicator module straight up out of its plastic holder. No screws are attached. With a thin flat screwdriver pry open the bottom off the module. Insert 2 AAA batteries. Reassemble.
Oct 28, 2010 | Kettler Exercise Bike EX1 Stationary Bike
Need a manual for Proform Carb Counter Stationary Bicycle
The exercise bike sounds like the Proform XP70. It has a carb counter feature. Here is the link to the PDF of the manual.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0502412.pdf
Good luck,
Techjoel
Jan 24, 2009 | Cycling
Proform 110R Exercise Bike Logo
126 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
