Question about Jeep AM/FM Cassette with CD Changer Controls - Upgrade Swap
Number 1 cylinder misfire
I have a 1997 jeep cherokee sport, 4x4, with 4.0L motor. i would like to know what would cause the number one cylinder to miss fire, also what would cause it to multiple misfire. I have replaced wires plugs, cap and rotor along with the distributer. please any suggestions would be greatlly appreciated.
  • dshall1975 Dec 16, 2007
    My 97' jeep cherokee misfires while I am driving it on the hwy. I have replaced all of the senors , all the ignition parts , and still am having problems.
  • missfirejeep Jan 16, 2008
    96 jeep cherokee with rough idle and muliple miss fire codes,changed wire/plugs/cap/rotor/rebulit dist./iac /map sensor/coolant temp sensor for comp/crank sensor/fuel filter/exhaust manifold/coil/de carbonized engine.still idles rough and miss fire code is same ?
Fill up the gas tank and add some fule injector cleaner
that solved my problem with misfire in cylinder 1
took about 2 days and my engine light went back off
i used a brand called
lucas fuel injector cleaner
i got it from advanced auto
auto zone also carries it
Posted on Jan 15, 2009
I need to know where the number one cylender is on a 360 jeep moter
Posted on Oct 23, 2010
I have a misfire in cylinder #1. I have had the spark plugs, wires. coil pack, and upper intake gaskets replaced and the engine still has a misfire in cylinder #1. When I replaced the coil pack it was ok for about a month. I tried the Lucas fuel injector cleaner and it seems to be fine until the gas runs out. If I don't use it again my engine starts sputtering. Oh, I forgot to mention that my engine sputters really bad. The engine light is on as well. Could this be a dirty injector and if I continue to use Lucas cleaner will it clean all the junk out of my injectors? Like I said it seems to be working. Please help! Thanks.... kthompson
Posted on Jul 12, 2009
97 Jeep Cherokee Sport W/4.0L Engine seems to run fine but has no compression #1 cyl. Have surfaced head, installed new head gasket, checked valves, still has no comp. KLW
Posted on Jan 18, 2009
Have the ignition module checked
Posted on Dec 05, 2007
Fireing order diagram
cylinder firing order is: is 1-5-3-6-2-4 .... In Jeep Grand Cherokee Laredo ...Happy motoring.
Sep 04, 2014 | 1996 Jeep Grand Cherokee
Why is code reading misfire in cylindar 1 on 1997 jeep grand cherokee 4.0
Can b many things..easy ones being spark plug/wire/injector malfunction...but it can b as bad as a bad head gasket
And coolant leaking into cylinder 1...
Aug 26, 2014 | 1997 Jeep Grand Cherokee
Compression test 1997 jeep cherokee sport 4.0 mfi what should the pressure be
Hi there:
Normal numbers for a 4.0L should be 120 to 150 no less then 30 psi per cylinder.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jun 21, 2012 | Jeep Cherokee Cars & Trucks
I hava jeep 97 jeep grand cherokee laredo203,000 miles problem is i gotta misfire that i cant get rid of replaced spark plugs,distributor cap and button cleaned fuel injectionand it keeps coming back what...
What is the misfire code?
If it is a specific cylinder try swapping the injector with another cylinder. If the misfire follows the injector to the other cylinder than you know the injector is bad. If it doesn't follow than I would be checking compression on that cylinder.
Oct 27, 2010 | 1997 Jeep Grand Cherokee
What would cause a cylinder 5 misfire in my 2002 jeep grand cherokee 4.7L
04jeeplibertypo305changedinj coil plug counters stayed high for #5 saw spikes on other cyls changed chk sensor no spikes on any misfire counter a week later back with a po 305 ?
May 14, 2010 | 2002 Jeep Grand Cherokee
1997 Jeep Cherokee Sport. Rear Passenger Window goes down not up
could be the switch one side not working test with meter
Oct 26, 2017 | 1997 Jeep Cherokee
What is the firing order on the distributor cap on my 1997 Grand Cherokee
For the 1997 Jeep Grand Cherokee:
I do not know if you have the 4.0L In-Line 6-Cylinder or the 5.2L V8, however I have included both below:
For the 4.0L In-Line 6-Cylinder:
Firing Order:
1-5-3-6-2-4
Cylinders:
(back)
...6
...5
...4
...3
...2
...1
(front)
Distributor:
....(back)
.....5....3..(+)-screw
1.............6
(+).4....2
For the 5.2L V8: (Side Note 5.9L V8 = Same)
Firing Order:
1-8-4-3-6-5-7-2
Cylinders:
.......(back).......
|..8..|.........|..7..|
|..6..|.........|..5..|
|..4..|.........|..3..|
|..2..|.........|..1..|
.......(front)
Distributor:
.....(back)
.........3
....4........6..(+)-rounded tab screw
8................5
[ ].1.........7
.........2
......(front)
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.com!
Apr 18, 2010 | 1997 Jeep Grand Cherokee
1999 jeep cherokee 6 cylinder engine light
1.Plugs
2. Vacuum leak
3. Injector fault
4. High or low fuel pressure.
Thats the list of things to check.
This is a #3 cylinder misfire.
There is also TSB about #3 injector needing added heat protection. This could definitely be the cause. I start at plugs and go from there.
Hope this helps.
Thank you,
Lee
Dec 12, 2009 | 1999 Jeep Grand Cherokee
Car Audio & Video Logo
1,807 people viewed this question
Top Jeep Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Oloyede Monsuru
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
