Question about Home Security
Replaced doorbell Now coil buzz's ... Why ? - Home Security
    Genius:
  • 1,181 Answers
Buzz all the time or just when button pushed?
Posted on Dec 12, 2016
I had to replace the doorbell button, now the doorbell only buzzes instead of chimeing. I have tried three different buttons and they all give the same result. Whats wrong?
This has to be a setting of dip switches that got changed somehow on the chiming unit. Open that up and check the settings.
Feb 22, 2015 | Home Security
Bike wont start
Very weak battery or solenoid contactor burnt/worn out OR very bad battery connections
Jun 15, 2014 | 1993 Harley Davidson FXR Super Glide
2 lights. 2 switches and a buzzer. how to connect them to make the buzzer sound when a light is turned on
Copy following links:
http://waterheatertimer.org/images/3-way-circuit-with-buzzer-300.jpg
http://waterheatertimer.org/How-to-wire-switches.html#3-way
Above illustration assumes that buzzer is rated for 120Volts.
If doorbell buzzer is rated for 12-24 Vac, then copy following links:
http://waterheatertimer.org/images/3-way-circuit-with-buzzer2-300.jpg
You need contactor with 120Volt coil. The light switches turn on light. At that moment, power goes to 12-24V doorbell transformer from hardware store. At same moment, power goes to magnetic coil on contactor. The contactor is a switch, and it connects wires between transformer and the doorbell buzzer. Buzzer turns ON.
When light turns off, buzzer turns off.
http://waterheatertimer.org/H230A.html
Apr 17, 2013 | Electrical Supplies
Doorbell doesn't work
It seems your doorbell transmitter got wet and corroded the contacts.
These push buttons are not sealed at all and thus will let rain, snow etc. eventually corrode the electronics.
Solution: Find a new push button on eBay.
Cheers
Feb 26, 2013 | Desa International White Wireless Plug In...
I have a 6a859 relay, does the 120 power lead go on 2 or 3?
Your load cannot exceed 1 amp
You'll need to connect load wires to a contactor or relay that has 120V coil
Local HVAC supply carries contactors
Grainger has contactors 120V coil and 25 amp across terminals
Fasco H230A with 120V coil and 30 amp across terminals
Sep 19, 2010 | Amperite Dayton Solid State Timer On Delay...
Want a replacment Little Tikes playhouse doorbell
Last time I bought little tikes replacement parts from amazon, take a look here Long Range User Friendly Wireless Doorbell cheers
Apr 10, 2010 | Little Tikes Picnic On The Patio Playhouse
New wired Heath/Zenith doorbell buzzes until disconnected
it sounds like you have a bad push button . if the wires where crossed you would most likely have this problem as soon as you turned on power .
Mar 15, 2009 | Honeywell Electrical Supplies
The start button only buzzes and won't engage in the typical spin cycle?
start button energise a relay that latches open and provdes the current path for the very heavy draw of heaters, and motor.
the relay is dead, or dying and instead of locking open is fluttering like a doorbell (buzz buzz).
Not a repairable item, it is replaceable and not very expensive, much less than a new dryer, last one purchased was $29.99
Relays are common to many dryers, the local parts guy will have one to match if you take the dead one.
typical relay looks something like this, not all are transparent
Sep 06, 2008 | Dryers
Home Security Logo
50 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
