Question about Whirlpool Dryers
My Whirlpool dryer is plugged in but will not turn on
    Problem Solver:
  • 15 Answers
I would start by checking to make sure the circuit breakers are not tripped. An electric dryer runs on 220 and will have a double circuit breaker - a gas dryer runs off of 110 and will usually not have a dedicated breaker. Once you have determined the power is on, the next most likely problem is the door switch. This prevents the dryer from being activated with the door open. You can "jiggle" the switch while attempting to start the dryer, or check the continuity with an ohmmeter.
Posted on Jul 20, 2009
My dryer was working just fine no problems and out of nowhere it throws the code F1 any suggestions
Go to https://www.whirlpool.com/manuals/ and enter your model number. The directions on how to find the model number are also on that page.
You might try turning off the dryer and unplugging it completely. Be careful when unplugging the dryer. Let it sit unplugged for a few minutes and then plug it back in. Let it sit plugged in for a few minutes and turn it back on.
Depending on your model, you might find the answer at https://www.youtube.com/watch?v=zMEbaXiusVY, https://www.youtube.com/watch?v=JRw_0eGkMAs or http://dryernotheating.net/whirlpool-cabrio-dryer-f1-error-code/.
Lastly, call Whirlpool customer support (see phone number on the Whirlpool webpage above) or call a local repair shop.
Aug 24, 2014 | Whirlpool Dryers
I just bought a whirlpool electric dryer and it won't work, it is plugged in and hooked up to the vent.
Is the circuit breaker turned on? Most people turn 220 v outlets off if not being used.
Aug 18, 2011 | Whirlpool WED5300S Electric Dryer
My Whirlpool Duet dryer has the "Control Locked"
Hi
To unlock it press the END OF CYCLE SIGNAL button for 15 seconds and the unit will reset.
Dec 31, 2010 | Whirlpool GEW9250 Electric Dryer
My whirlpool dryer doesn't turn on. It's plugged up next to the washer that still works and just got thru drying a load.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 13, 2010 | Whirlpool Dryers
Whirlpool electric dryer - looks like a WED5200T but no model number on the unit. The drum turns and air blows from the vent, but the timer has stopped working and there is no heat.
you have a white strip on the back of your dryer un plug your dryer first.....then un plug the strip and hook the two wires together that will allow the heat to start again.....the timer shouldnt have anything to do with the heat....turn it on and put your ear to the knob and you should here a clock sound if not your timer is bad
Nov 10, 2010 | Whirlpool WED5200T Electric Dryer
My 5 yo whirlpool duet dryer just stopped. had run perfectly this morning. now, the power light won't come on. it is plugged in, free from lint, and tub spins freely. any ideas?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 07, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Plug dryer in wall wont start
The most obvious thing to me is that the cord may have been loosened or damaged by the move, or the terminals in the machine may have loosened. Either test the cord on your "new" machine, or replace it with a known "good" cord. Wait a minute....you already have one of those....
Try it, it may be the very thing!
Regards, --W/D--
Jul 28, 2009 | Whirlpool WED5100SQ Front-Load Electric...
Elkectric dryer won't start
to put it kindly depending on way you connected wires unit could be damaged,replace pigtail with three wire and outlet to original.outlet wires should be black,red and white. turn breaker off attach white to middle and red,black to sides,"either side is fine".Attach dryer pigtail in same manner with white on white and if plug in and turn breaker on.If there is no operation at this point dryer possibly damaged from previous wiring.Just remember be safe when working with electrical and ask before trying to change things that aren't the same.
Apr 20, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool duet dryer
Try pressing the End of Cycle button on the far right and holding it for more than 3 or 4 seconds.  It should reset.
Jun 01, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
94 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
