Question about Ariens Garden
Wheels won't move forward or backward
On our Ariens snowblower the wheels won't go forward or backwards
    Top Expert:
  • Ariens Master
  • 8,375 Answers
How do I fix my snowblower when the wheels won,t move ahead or back
Sounds like gear on axle shaft broke shear bolt or key. Take bottom plate off base of snowblower.It is ok to tip snowblown up on front end so wheels are in air. After plate is off turn wheels and see if drive gear is moving with axle. If not key way or bolt has broken off, replace and will be back in motion.
Feb 18, 2015 | Craftsman Snow Blower / Snowblower Bottom...
Why can't I shift gears
that is because it is a posie trac rear end they all do that
Jan 21, 2018 | Ariens Garden
The car won't go forward or backward
Lift up all the wheels one by one, rotate each wheel and check which wheel resists to rotate. Disassemble the jammed wheel and carefully examine to see why is it so.
Grease the caliper pins, free up the pistons and reset the brake components.
Dec 03, 2012 | 2001 Toyota Echo
Gt 245 lawn tractor won't go forward or backward
Check the drive belts first. and make sure the hydro release lever is in the correct position. If it is not- you can push the lawn tractor and have the rear wheels turn. It sometimes doubles as a "Forward" "Neutral" "Reverse" lever on other brands of lawn tractor.
The belts should be in their guides and pulley grooves- check to make sure it does not have a hidden break by having the engine off, and pulling on the belt.
Lastly, check to make sure the hydro itself is not out of oil or low on oil. It uses low viscosity "HyGard" oil. Capacity if you drain the old oil out and refill is 4.6 quarts. Look for a leak if the level is low.
If it still does not move, make sure the levers are set so you are in forward motion positions, and push- if the rear wheels move there is a problem in the hydro unit.
Apr 07, 2012 | Garden
My 10 hp snowblower is not yet 5 years old and it stopped going forward. The axles turn but the wheels don't. It goes backwards o.k. I've looked through the owners manual and am a little confused as to...
check the keys on the axle and if they are okay check to make sure the chain that drives the wheels is not too loose on the sprockets.
Mar 15, 2011 | Garden
Not sure, but i think the electronic clutch is not engaging when i push the control levers forward or backwards. the engine and the mower deck both run, but the mower will not move
The electric clutch is to power the blades/mower deck. There is a belt that drives the hydrostatic pumps to power the wheels. Make sure the Parking brake is OFF. Could be a belt, spring, idler pulley.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 19, 2009 | Ariens 34 In. Zoom Series Riding Mower
Ariens ezr 1742 will not move. everything works fine except it will not go forward or reverse.
There is one common problen that causes this. Infront of the rear wheels there are two housings for the indepentent hydrostatic transmissions. There is one gold colored shaft with a ninety degree angle on it sticking out from EACH of the housings on the top front. Again these are on both sides and they each need to be pushed downward so that the rods can then be pushed backward into the transmissions to inguage them so both of the wheels are powered. Give this a try.
Jun 07, 2009 | Ariens 34 In. Zoom Series Riding Mower
Need manual
my ariens mower won't go forwards or backwards
Feb 04, 2009 | Ariens Garden
Garden Logo
235 people viewed this question
Top Ariens Garden Experts
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
enb54
Level 1 Expert
Are you an Ariens Garden Expert? Answer questions, earn points and help others
