Question about Refrigerators
I replaced the water filter on a kitchenaid refrigerator just 5 months ago and the light indicates it needs to be replaced again! Any way to clean these filters? EPN
  • 441 Answers
Nope, the filters can not be cleaned. But the loght is set to come on after a certain # of gallons of water flow thru it. That does NOT mean you need to change it, look at the size of the ice cubes, if they start to get smaller then its time to cahnge the filter, or judge it by taste. You should only have to replace the filter once a year, you dont want to go much longer than that or bacteria could start to form in the filter
Posted on Jul 20, 2009
SRS580DW Water filter indicator red light is on. Where in the fridge do I find it to take it out to replace pleace?
Resetting the water filter indicator light can also be found in the user manual for your SRS580DW Refrigerator User Manual page 8 The water filter indicator initially lights up green. Press the ICE TIMER and ICE MODE buttons at the same time for about three seconds to reset the water filter installation date. • The green light changes to orange after five months to indicate that you should soon change the water filter. It changes to red after an additional one month (six months after the water filter was changed or installed) to indicate that you must change the water filter. • If you wish to turn off the filter indicator lamp or the filter is not connected, press the ice timer & ice mode button simultaneously for 5 seconds. If you wish to turn on the filter indicator lamp again, press the ice timer & ice mode button simultaneously for 3 seconds. Click Here for the SRS580DW User Manual I am here should you have questions Thanks Sea Breeze
Jun 03, 2013 | Refrigerators
Have changed water filter, but indicatot panel calls for order h2o filter, and comes on every time we dispence water. why?
Most models also have a filter indicator reset button located in the same area. After changing the filter, reset the filter status light by pressing the Filter Indicator Reset button or by pressing and holding the Filter button for 3 seconds. The status light will change from red to green or the status display will change from "Replace" to "Good" when the system is reset.
If your model has a water filter indicator, but no reset button, press the light switch in the refrigerator compartment 5 times within 10 seconds to reset the system. The status light will change from red to green when the system is reset.
Oct 16, 2012 | KitchenAid KBFA25ER Bottom Freezer French...
Changed water filter and bushed lock & water buttons, red light went off but green light and other indicator lights (crushed ice, cubes, night light) did not work. Removed new filter & put . .back...
Below are instructions to reset water filter light. Thanks, Sea Breeze
If helpful please rate.
Reset Filter (select models)
When a water filter has been installed in the
refrigerator, the yellow Order light will illuminate when
90 percent of the volume of water for which the filter is
rated has passed through the filter OR 11 months have
elapsed since the filter has been installed.
The red Replace light will illuminate when the rated
volume of water has passed through the filter OR 12
months have elapsed since the filter was installed. A
new filter should be installed immediately when the
Replace light is illuminated.
After replacing the filter, press and hold the Reset
Filter pad for three seconds. The Order and Replace
lights will go off.
Vacation Mode
The Vacation Mode feature causes the freezer
to defrost less frequently, conserving energy. The
Vacation Mode indicator light will illuminate when the
feature is activated. To deactivate, press the Vacation
Mode pad again OR open either door. The indicator
light will go off.
Temp Alarm
Apr 22, 2011 | Amana 22.6 cu. ft. Side-By-Side...
How do you turn off replace filter light on freezer door panel?
If you're referring to the water filter indicator light that goes from green to yellow to red when it's time to change the filter, you press and hold the WATER FILTER button down until it blinks 5 times. The indicator light will change from red to green when the system is reset.
Feb 13, 2011 | KitchenAid KSCS25FKSS Side by Side...
How do I change the water filter
Removing and replacing a water filter - upper right hand corner location
Filters situated in the upper right hand corner of the refrigerator compartment of Maytag-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  • These eight inch long filters are housed in their own compartment. The base of the compartment can be released by pushing in on the release clip found at the end of the housing unit. Allow the base of the housing compartment to hang down while you remove and replace your filter.
  • Twist the spent filter to the left (counter-clockwise) and gently pull on it to remove it. There is an automatic water shut off to keep leaks and spills to a minimum.
  • Remove the new filter from its packaging. Remove the plastic wrap, and peel off the aluminum topping. Insert the new filter into the housing unit. Twist the filter to the right (clockwise) until it clicks into place. Replace the base of the filter housing by cliping it back in place.
  • Condition the filter by dispensing several glasses of water through your refrigerator. This ensures that all fine carbon particles have been removed.
  • Check the filter and the inside of the refrigerator for leaks. If you find a leak, remove and install the filter again.
  • Finally, reset the 'change filter' indicator light, if your refrigerator has one, at the front of your refrigerator. The procedure for resetting the change filter indicator light can vary from fridge to fridge. Typically, the indicator light can be reset by holding down on the 'lock' button and the 'water' button simultaneously for three seconds. Sometimes, it is the 'lock' and the 'light' button you need to press down on simultaneously for three seconds in order to reset the filter indicator light.
Removing and replacing a water filter - center ceiling location
Filters situated in the center ceiling of the refrigerator compartment of Maytag-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  • Turn the filter a quarter turn to the left, in a counter-clockwise motion. The 'unlocked' symbol on the filter will be lined up with the indicator line that is molded into the refrigerator just above the filter. Allow the ears of the cartridge to disengage from the filter holder.
  • Gently pull down on the filter, being careful to not spill any water still in the filter. Discard the used filter.
  • Remove the new filter from its packaging. Remove and discard the red plastic cap found on the top of the new filter.
  • Apply the appropriate month sticker to the filter to remind your self to remove and replace the filter in six months' time.
  • Insert the new filter into the filter opening. Line the 'unlock' symbol on the filter up with the indicator line that is molded into the refrigerator above the filter. Turn the filter a quarter turn to the right, in a clockwise motion. You will be able to feel the filter stop when it is all the way in, and the 'locked' symbol on the filter will now be lined up with the indicator line above the filter.
  • Close the refrigerator door and dispense several glasses of water through the water dispenser in the door in order to purge the new filter of any impurities. Open the refrigerator door again and check for leaks. If you find a leak, remove and replace the new filter again.
Nov 29, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Superba kitchen aide refrig red light for water filter wont go of
You just need to replace the light switch on the filter control panel. I hope this helps you out.
Sep 10, 2009 | KitchenAid Superba Architect KSCS25INSS...
How to clean the kitchenaid java express coffee maker
The Coffee Maker can be descaled using
a packaged descaling agent or vinegar.
Always mix the descaling solution using
cool water.
• When using a descaling agent, follow
the directions on the package for the
recommended amounts of descaling
agent and water to use.
• When using vinegar, fill the carafe with
a solution consisting of 1⁄2 vinegar and
1⁄2 water.
Descaling Steps:
1. Before descaling, always remove the
water filter (see “Installing the Ion-
Exchange Water Filter” on page 7) and
make sure the brew basket contains
no coffee or coffee filters.
2. Run the Coffee Maker through a
complete brewing cycle using a full
carafe of the descaling solution.
3. If the cleaning needed indicator lights
after the brewing cycle is complete,
repeat Step 2 using fresh descaling
solution. Keep repeating Step 2 until
the cleaning needed indicator no
longer lights after brewing.
4. Rinse the Coffee Maker by running
it through two brewing cycles using a
full carafe of fresh, cool water
each time.
5. Wash the brew basket in hot, soapy
water and rinse with hot water. This
part can also be washed in the upper
rack of the dishwasher.
6. Reinstall or replace the water filter.
Replace the filter every three months
under normal usage, or more often
with heavy use.
Mar 30, 2009 | KitchenAid JAVASTUDIO KCM534 14-Cup Coffee...
Plastic Taste in Refrigerator Water
Hi there, I noticed the same condition when I left the filter in ours a little too long. The optimal performance from the filter is achieved (I have found) when you change it after 3 months. This is about the same amount of time it takes for the light to change from green to red on the filter light.
Hope this helps. ~Steve
Jan 24, 2009 | KitchenAid Refrigerators
Slime in refrigerator water line
The water quality is really bad, you should change your filter often even the big water filter from your main line, need to change it after 4 to 5 months.
May 30, 2008 | KitchenAid KSRS25IL Side by Side...
KitchenAid Superba
You indicator light on your fridge is set on a timer. If you never took a single glass of water it would go on after six months or so. It is just an aide to remind you. To replace it, firmly turn counterclockwise about a quarter turn with a little pressure pulling down or out depending on the location of the filter. You need not turn off water. Replace with new one.
Sep 21, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
63 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
