Question about Sewing Machines
I got a frister rossman 700 sewing machine Needle thread boby thing ok But as im sewing its got loose stiching at the back front looks well sewed But due to not tight at the back it will open up
  • Sewing Machines Master
  • 12,472 Answers
If it is the upper thread creating loops on the back of the fabric, either the upper thread is not seated completely in the tension disk or the tension is too loose. When re-threading, ALWAYS RAISE the presser foot so the thread will seat completely.
Posted on Dec 12, 2016
5 Suggested Answers
  • 980 Answers
SOURCE: needle keeps breaking on my frister+rossman cub 3
You may need to retime the machine if you have made sure the needle is in the correct way round, I can attach instructions if you email me drivewithken@blueyonder.co.uk
Posted on Sep 11, 2009
kirkx
  • 2019 Answers
SOURCE: I have a janome 8050
The key to proper stitches is that tension on the bobbin must equal the tension on the upper thread spool as well. The bobbin has a tension screw that may have come loose or the thread is not properly in the tensioner. For example, the bobbin could be in backwards. Or the tension of the top could be too light and allowing the tension on the bottom to pull the thread down too much.
Open the bobbin tray and watch while you slowly rotate the hand control to see it make a stitch.
You will probably be able to figure out what is wrong.
Posted on Apr 08, 2011
SOURCE: frister & rossman manual for model979
check with sewvacdoctor.com
Posted on Feb 20, 2012
SOURCE: I need a manual for Frister Rossman sewing machine model 46, Please Help!
contact this site & ask them about a manual
http://sewingparts.co.uk/machines/high-lift/frister-46.html
Posted on Oct 03, 2012
I am looking for a Frister Rossman model 35, I need to know how to change the needle
This may be helpful:
Frister Rossmann PZ Instructions Manual Page 7
Be certain that the flat part of the needle faces the correct direction in your machine. On most machines the flat side faces away from where the bobbin mechanism is located, ie if the bobbin area opens on the left side, the flat needle should probably face the right side of the machine.
Feb 23, 2018 | Sewing Machines
I am looking for a Frister Rossman 204 sewing machine manual
Try Googling (Frister Rossman)(204)(manual) without parens.
Jan 05, 2018 | Sewing Machines
I've just been given an industrial frister Rossman but was told it needed oil before use. How do I oil it please?
What is the model? Generally, most sewing machine have oil ports. Place a couple of drops in every port and joint you see. Let the machine run until loose.
Apr 25, 2017 | Sewing Machines
Wind bobbin frister rossman 420
Hi - if I understand your questions you're trying to wind a bobbin on the top, and haven't got as far as sewing yet.
To do this you usually have to put the bobbin on the top spool for it, and move that into position so that it turns.
To disengage the needle so it doesn't go up and down whilst you wind the bobbin up, on most machines you have part of the main drive wheel (on the far right) which turns against the rest of it, disengaging the part of the drive which powers the needle going up and down.
Or at least that's how it works on most machines.
Jan 28, 2013 | Sewing Machines
When i am sewing the stiches on top, but its at the bottom
change the needle --make sure it's the right one for the fabric
being sewed
rethread the machine top and bobbin
make sure the bobbin is turned the right way in the bobbin case
also check the top thread tension, if the stitches under the fabric
are loose adjust the top thread tension one number or letter higher
at a time and sew on a scrap piece of fabric till the stitches look
normal
here is a free manual
http://www.singerco.com/uploads/download/696_5417c.pdf
Jan 07, 2013 | Singer 5417 Mechanical Sewing Machine
Frister & rossman manual for model979
Feb 19, 2012 | Sewing Machines
How to thread a Frister and Rossman 35
Presser foot up, takeup lever at the top, thread on the top spool pin, take the thread to the left and over the top guide, straight down the right hand side of the tension and go round it making sure the thread goes between the discs, up the left hand side to the takeup lever, thread the takeup lever right to left, take the thread all the way down to the needle going through any guides on the way, thread the needle left to right, make sure the flat side of the needle is facing right.
Mar 22, 2010 | Sewing Machines
Needle keeps breaking on my frister+rossman cub 3 sewing machine Help please.
Sep 01, 2009 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
