Question about Garmin GPS
Garmin express does not recognise my Forerunner XT910
    Scholar:
  • Garmin Expert
  • 186 Answers
Download and install the Garmin usb drivers from Garmin.
Posted on Apr 10, 2017
4 Suggested Answers
SOURCE: Garmin forerunner 301
oops, i meant i know its NOT the oxidation problem
Posted on Aug 01, 2008
SOURCE: Change battery on Garmin Forerunner 301
Hi - look at this solution for a forerunner 201, which has the same case design. I was just looking myself! R_nz Rank: Apprentice Rating: 96%, 8 votes I've made some progress here, I discovered that there is a small notch beneath the flat black pastic insert that holds the rubber button cover in. By gently prising this out, I can at least expose the pcb with the buttons on. I still can't figure out how to open the case though ****! Comments: Jan 29, 2008 - Well, I got there in the end! As above, I managed to prise the plastic insert cover off the rubber button cover, the peeeled this off as well. Underneath is a mylar printed circuit with the silver domeos of the buttons moulded in. This is siliconed down, but you can peel it up with a fingernail. The top left end (above the on button) is aatached inside the case, so start at the other end. Jan 29, 2008 - .ctd.. Once you have lifted the mylar strip, you can get at the case seam underneath and prise it gently open with a flat blade. The case is glued together with a light silicon or something. My problem was unresponsive buttons and by detaching and then re-attaching the small connector by the big silver block where the mylar attaches to the main board and then re-attaching it, it seemed to fix it! :-) Oct 22, 2008 - As an end-note; I glued my 201 back together with a light Silicone sealer. It seems to be at least rain proof anyway. Forerunner 201 battery replacement (Expert level): Opening the 201 was not easy and could not be done 100% clean, but thanks to R_nz (above) I got it open. My problem was dead (almost) battery, after 6 years of superb operation. I found the battery to be glued (double sided tape) to the back cover. To remove, push it up slowely and pull out. Beware of the short wires. 1. It is a flat battery, wrapped in shrinkable tube. Made by MDTechnology, P/N 043048 3.7V, 500mAh see http://www.mydbattery.com/EN/products.asp?ID=12 2. On the cover, the battery is soldered to the underside of a small PCB, hard to get to (by expert!). If you find a battery, suggest to cut the wires and solder wire-to-wire. Hope that helps
Posted on Jul 08, 2009
escapement
  • 2334 Answers
SOURCE: I just got a new garmin forerunner watch. How do
Follow this link, give all the details of your device and download it:
http://www8.garmin.com/support/userManual.jsp
If this doesn't work - give us next question.
Rate me, please.
Posted on Aug 15, 2009
I cannot get Garmin Express to open
Have you checked with Windows or Garmin to see if they are supported on Windows 10?
Oct 05, 2015 | Garmin GPS
Training sessions will not upload with Garmin Express.
I solved this by uninstalling all usb root hub drivers on my pc through device manager and rebooting to allow them to be re installed.
They were all reporting as working correctly but something must have been confused because on rebooting all was well.
Sep 22, 2014 | Garmin Forerunner 310XT GPS Sports Watch
Trying to add my device (forerunner 405cx) to Garmin Connect through Garmin Express but GE keeps saying there is a problem with their servers... HELP!
If GE is giving you this error before even opening try this:
hold the flag key and press R (run command)
type in services.msc
find the Garmin Core Update Service
right click and click on properties
go to the Log In tab
choose the second option
click on browse
type in "net" then check name
click ok when it says Network Service
delete both passwords
click ok 2 times
right click on the Garmin Core update Service
Restart it
try running Garmin Express again
hope that helps
Aug 05, 2014 | GPS
Ant will not pair with my 310
Do a master reset and start using Garmin Express
Jul 27, 2014 | Garmin Forerunner 310XT GPS Sports Watch
How to remove battery from garmin 205 ?
they are fixed in you have to take the hole thing to bits
Jul 27, 2014 | Garmin nuvi 205W GPS Receiver
Frozen screen
I do not have your specific model. However, others had luck by following these instructions. "Plugging the watch into the charger then holding down the light button for 15-20seconds did the trick." Did you try that?
Jul 20, 2017 | Garmin Forerunner 210 Gps-enabled Sport...
Garmin 310xt software
Run the Garmin WebUpdater to load or reload the latest software to the device.
You may also want to contact Garmin Tech Support for assistance.
1-800-800-1020
May 15, 2012 | Garmin Forerunner 310 Xt Gps Sport Watch...
Garmin Forerunner 305 USB Not Recognized
Cleaning the gold contacts on the watch with a pencil eraser fixed it for me.
Nov 11, 2009 | Garmin Forerunner 305 GPS Receiver
Jun 29, 2008 | Garmin Forerunner 301
GPS Logo
63 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
