Question about Miscellaneous
Need results from romford 10 12 2016 - Miscellaneous
I need a result for this 5431005160097
A result is the outcome (result) of a mathematical operation. Yet here you only give a number. That should be the result of some unknown operation.
Aug 20, 2016 | Office Equipment & Supplies
Euromillions I need results for ; 12th apr,'13.
You can get them by going to euro-millions.com and then selecting the Past results link on the left of the page - I hope you had good luck
Oct 03, 2013 | Office Equipment & Supplies
Zip code of London
The postal code for London and the surronding area are:
St. Albans: AL: AL1; AL2; AL3; AL4; AL5; AL6; AL7; AL8; AL9; AL10
London East: E: E1; E1W; E2; E3; E4; E5; E6; E7; E8; E9; E10; E11; E12; E13; E14; E15; E16; E17; E18; E77; E98
London East Central: EC: EC1; EC2; EC3; EC4; EC1A; EC1M; EC1N; EC1P; EC1R; EC1V; EC1Y; EC2A; EC2M; EC2N; EC2P; EC2R; EC2V; EC2Y; EC3A; EC3M; EC3N; EC3P; EC3R; EC3V; EC4A; EC4M; EC4N; EC4P; EC4R; EC4V; EC4Y; EC50
Enfield: EN: EN1; EN2; EN3; EN4; EN5; EN6; EN7; EN8; EN9; EN10; EN11
Harrow: HA: HA0; HA1; HA2; HA3; HA4; HA5; HA6; HA7; HA8; HA9
Ilford: IG: IG1; IG2; IG3; IG4; IG5; IG6; IG7; IG8; IG9; IG10; IG11
Kingston Upon Thames: KT: KT1; KT2; KT3; KT4; KT5; KT6; KT7; KT8; KT9; KT10; KT11; KT12; KT13; KT14; KT15; KT16; KT17; KT18; KT19; KT20; KT21; KT22; KT23; KT24
London North: N: N1; N2; N3; N4; N5; N6; N7; N8; N9; N10; N11; N12; N13; N14; N15; N16; N17; N18; N19; N20; N21; N22; N81
London North West: NW: NW1; NW1W; NW2; NW3; NW4; NW5; NW6; NW7; NW8; NW9; NW10; NW11
Romford: RM: RM1; RM2; RM3; RM4; RM5; RM6; RM7; RM8; RM9; RM10; RM11; RM12; RM13; RM14; RM15; RM16; RM17; RM18; RM19; RM20; RM50
London South East: SE: SE1; SE2; SE3; SE4; SE5; SE6; SE7; SE8; SE9; SE10; SE11; SE12; SE13; SE14; SE15; SE16; SE17; SE18; SE19; SE20; SE21; SE22; SE23; SE24; SE25; SE26; SE27; SE28
Sutton: SM: SM1; SM2; SM3; SM4; SM5; SM6; SM7
London South West: SW: SW1A; SW1E; SW1H; SW1P; SW1V; SW1W; SW1X; SW1Y; SW2; SW3; SW4; SW5; SW6; SW7; SW8; SW9; SW10; SW99; SW11; SW12; SW13; SW14; SW15; SW16; SW17; SW18; SW19; SW20;
London West: W: W1A; W1B; W1C; W1D; W1E; W1F; W1G; W1H; W1J; W1K; W1S; W1T; W1U; W1W; W2; W3; W4; W5; W6; W7; W8; W9; W10; W11; W12; W13; W14
London West Central: WC: WC1A; WC1B; WC1E; WC1H; WC1N; WC1R; WC1V; WC1X; WC2A; WC2B; WC2E; WC2H; WC2N; WC2R; WC99
Dec 19, 2010 | Computers & Internet
Customizing search results on a web site
depends on the search engine you use in goole you can change the search results and language settings into whatever language you wish, and possible the same for live search and bing etc....... ^_^
Jun 04, 2010 | Microsoft FrontPage 2003
I NEED MS EXCEL CONVERT FORMULA FOR NUMBER TO CURRENCY
Here is a very popular bit of code from Microsoft that will convert any currency amount in a cell to English words. All code and text from below here is the work of Microsoft.
Summary
This article shows you how to create a sample, user-defined function named ConvertCurrencyToEnglish() to convert a numeric value to an English word representation. For example, the function will return the following words for the number 1234.56: One Thousand Two Hundred Thirty Four Dollars And Fifty Six Cents
The Function Wizard can also be used to enter a custom function in a worksheet. To use the Function Wizard, follow these steps:
1. Click the Function Wizard button, and select User Defined under Function Category.
2. Select ConvertCurrencyToEnglish, and enter your number or cell reference.
3. Click Finish
To Create the Sample Functions
1. Insert a module sheet into a workbook. To do this in Microsoft Excel 97 or Microsoft Excel 98, point to Macro on the Tools menu, and then click Visual Basic Editor. In the Visual Basic Editor, click Module on the Insert menu. In Microsoft Excel 5.0 or 7.0, point to Macro on the Insert menu and click Module.
2. Type the following code into the module sheet.
Function ConvertCurrencyToEnglish (ByVal MyNumber)
Dim Temp
Dim Dollars, Cents
Dim DecimalPlace, Count
ReDim Place(9) As String
Place(2) = " Thousand "
Place(3) = " Million "
Place(4) = " Billion "
Place(5) = " Trillion "
' Convert MyNumber to a string, trimming extra spaces.
MyNumber = Trim(Str(MyNumber))
' Find decimal place.
DecimalPlace = InStr(MyNumber, ".")
' If we find decimal place...
If DecimalPlace > 0 Then
' Convert cents
Temp = Left(Mid(MyNumber, DecimalPlace + 1) & "00", 2)
Cents = ConvertTens(Temp)
' Strip off cents from remainder to convert.
MyNumber = Trim(Left(MyNumber, DecimalPlace - 1))
End If
Count = 1
Do While MyNumber <> ""
' Convert last 3 digits of MyNumber to English dollars.
Temp = ConvertHundreds(Right(MyNumber, 3))
If Temp <> "" Then Dollars = Temp & Place(Count) & Dollars
If Len(MyNumber) > 3 Then
' Remove last 3 converted digits from MyNumber.
MyNumber = Left(MyNumber, Len(MyNumber) - 3)
Else
MyNumber = ""
End If
Count = Count + 1
Loop
' Clean up dollars.
Select Case Dollars
Case ""
Dollars = "No Dollars"
Case "One"
Dollars = "One Dollar"
Case Else
Dollars = Dollars & " Dollars"
End Select
' Clean up cents.
Select Case Cents
Case ""
Cents = " And No Cents"
Case "One"
Cents = " And One Cent"
Case Else
Cents = " And " & Cents & " Cents"
End Select
ConvertCurrencyToEnglish = Dollars & Cents
End Function
Private Function ConvertHundreds (ByVal MyNumber)
Dim Result As String
' Exit if there is nothing to convert.
If Val(MyNumber) = 0 Then Exit Function
' Append leading zeros to number.
MyNumber = Right("000" & MyNumber, 3)
' Do we have a hundreds place digit to convert?
If Left(MyNumber, 1) <> "0" Then
Result = ConvertDigit(Left(MyNumber, 1)) & " Hundred "
End If
' Do we have a tens place digit to convert?
If Mid(MyNumber, 2, 1) <> "0" Then
Result = Result & ConvertTens(Mid(MyNumber, 2))
Else
' If not, then convert the ones place digit.
Result = Result & ConvertDigit(Mid(MyNumber, 3))
End If
ConvertHundreds = Trim(Result)
End Function
Private Function ConvertTens (ByVal MyTens)
' Is value between 10 and 19?
If Val(Left(MyTens, 1)) = 1 Then
Select Case Val(MyTens)
Case 10: Result = "Ten"
Case 11: Result = "Eleven"
Case 12: Result = "Twelve"
Case 13: Result = "Thirteen"
Case 14: Result = "Fourteen"
Case 15: Result = "Fifteen"
Case 16: Result = "Sixteen"
Case 17: Result = "Seventeen"
Case 18: Result = "Eighteen"
Case 19: Result = "Nineteen"
Case Else
End Select
Else
' .. otherwise it's between 20 and 99.
Select Case Val(Left(MyTens, 1))
Case 2: Result = "Twenty "
Case 3: Result = "Thirty "
Case 4: Result = "Forty "
Case 5: Result = "Fifty "
Case 6: Result = "Sixty "
Case 7: Result = "Seventy "
Case 8: Result = "Eighty "
Case 9: Result = "Ninety "
Case Else
End Select
' Convert ones place digit.
Result = Result & ConvertDigit(Right(MyTens, 1))
End If
ConvertTens = Result
End Function
Private Function ConvertDigit (ByVal MyDigit)
Select Case Val(MyDigit)
Case 1: ConvertDigit = "One"
Case 2: ConvertDigit = "Two"
Case 3: ConvertDigit = "Three"
Case 4: ConvertDigit = "Four"
Case 5: ConvertDigit = "Five"
Case 6: ConvertDigit = "Six"
Case 7: ConvertDigit = "Seven"
Case 8: ConvertDigit = "Eight"
Case 9: ConvertDigit = "Nine"
Case Else: ConvertDigit = ""
End Select
End Function
Apr 15, 2010 | Broderbund Learn MS Windows XP and Excel...
How do you put your calculator into decimal setting where you don't have to do it every problem.
I am not quite sure I understand but here is how to configure your calculator to display decimal results all the time.
Use LineIO
To set LineIO
  1. Press [SHIFT][MODE] to access (Setup)
  2. Select [2:LineIO]
All your results will be in the decimal format.
In case you need to revert to the MthIO here is how to do it.
To set MthIO
  2. Select [1:MthIO]
Your results will be exact: Results will be fractions and radicals
If you want the advantages of MthIO but the results in decimal, you can do it as follows
  1. Press the [S<=>D] key after a result is displayed to toggle between decimals and fractions/radicals.
  2. Alternatively, pressing [SHIFT][=] will always display the results in decimals.
Jan 14, 2010 | Casio fx-300ES Calculator
I cant unlock my nokia 2323 classic keypad because i forgot my password
HI SIR
we can remove the password for u kindly bring the phone to as at shop 733 Romford road london e12 5aw .
ph 02089119485 7days a week 9.30 to 9.00pm
thanks
Aug 18, 2009 | Cell Phones
Eurovox Codes
what area are you in? anyone in essex area of romford or darford kent needing box redone contact via email.
Dec 03, 2008 | StarTech.com StarView SV211K 2-port KVM...
Miscellaneous Logo
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
Dan Grod
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
