Question about Sewing Machines
Adjusting cutting blade on bowe 316 forms cutter
2 Suggested Answers
SOURCE: changed cutting blade now blade will not stay stable in position to cut
did you get the cutter release knob back in the right place or position?
is the horseshaped bracket damaged in any way?
Posted on May 03, 2012
Rabbit HX 720 Vinyl cutter plotter cutting blade will not lower to cut
Since this is a sewing machine category, it is unlikely there will be a good answer.
Aug 31, 2017 | Sewing Machines
Brother lb6770 The hook comes out and usually misses thread it is supposed to cut even when does catch blade fails to cut thread.Is this adjustment that's needed or replacing?
If the felt pad is missing from your bobbin case, it won't catch the thread properly and if it's not cutting even when it has caught. The cutter blade needs to be replaced.
Aug 30, 2016 | Brother Sewing Machines
Auto thread cutter on my quantum stylist 9960 is not cutting my thread it is going through the correct motion but not actually cutting ? I have cleaned my machine with no changed results, help!?
Please have a trained service technician look at your machine. Cutter blades and mechanisms do require service from time to time, especially with heavy use. If you use your machine frequently, have it cleaned and adjusted based on your use levels.
Cheers,
Embroidery Services
San Diego, CA
Jul 03, 2016 | Sewing Machines
How to adjust trimmer on tajima tumx
WIll need more information about what you are trying to adjust?
Machine functions a mechanical cut, but the thread wasn't cut?
Cutter has timing to be set or replace the fixed blade. are two basic possibilities. I need to know what it's doing cut wise? to know what to adjust.
Cheers,
Kelly
Embroidery Services
San Diego, CA
Nov 19, 2014 | Sewing Machines
I replaced cutter blade on Elna PRO DC 5. New blade won't cut fabric. how do I adjust it?
All sergers have 2 blades. Just like scissors. Only 1 blade of scissor is sharp = not good cutting.
Feb 14, 2014 | Elna 1010
Changed cutting blade now blade will not stay stable in position to cut
Mar 07, 2012 | White Sewing Superlock 1934D Mechanical...
Cutters on Elna 744 serger won't cut
is there lint or thread caught between blades preventing them from meeting?
scott
Jul 26, 2009 | Brother 929D Mechanical Sewing Machine
Husqvarna Sapphire - thread cutter not working
Does the metal arm come out to grab the threads to cut it? Is there a blade in the metal arm that cuts the tread? I think a standard utility knife cutter blade is the same size (just like the one that cuts the bobbin thread when you put in a new bobbin). What happens when you activate the cutter is the arm comes out, grabs the threads, brings them to the blade which cuts the threads, the velcro by the cutter holds the bobbin thread in place for the next stitch. Otherwise the thread may end up on top and the top thread would not be able to pick it up for the next stitch.
Good luck.
Jun 27, 2009 | Husqvarna Viking 1
My simplicity serger SW432 wont cut
There are 2 blades, a fixed cutter and a moving cutter. The moving cutter should move approx 1/8" at it's lowest point past the fixed cutter. There should also be some pressure between the cutters
Mar 18, 2009 | Simplicity Serge Pro SW432 Mechanical...
My viking serger 905 wont cut
Sometimes the blades need to be adjusted. Lower them all the way manually to the bottom. The cutters if you look on the side should meet. If they don't' meet or if there is a small space then the upper cutter needs to be lowered.
There are screws that hold this in place. You might need a man to help since the screws on my machine are very tight!
Nov 05, 2008 | Husqvarna Viking 1
Sewing Machines Logo
32 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
