Question about Vax Vacuums
Where do I find ALL FILTERS on a VAX FORCE 10 super power ?
Vax stopped mid vacuuming,as though fuse in plug has blown.checked fuse,OK.no lights lit.vax not working.
Most vacuums have thermal protection on the motor that will shut it off if it gets too hot. If you can turn it off, wait 10-15 minutes, and it works when you turn it back on, that's what is going on. Now, the motor shouldn't normally get that hot, so your next challenge is finding out why. Check for any blockages in the air flow or cooling vents, and if the motor also powers something like a beater bar, make certain that it turns relatively freely.
Feb 02, 2016 | Vax Vacuums
Vax troubleshooting
it must be missing a diverter somewhere..most have a diverter just inside the tank...
Jan 08, 2014 | Vacuums
I have a Vax turbo force 2000w hoover and it doesnt pick up theres hardly any suction and then it cuts out. Any ideas what the problem could be?
Yep,
Your filters are clogged. As a result the motor is straining and overheating, then a thermal cutout operates.
Clean the filters in the top of the vax and if you are ussing a cloth bag empty and wash ot. If a paper bag, replace it.
All should be well
Jun 29, 2011 | Hoover Vacuums
My vax hoover performance 2200 keeps overheating and cutting out after only 10 minutes
mine too.. I got local place to do a deep clean (sic) of all the filters but its made little difference. Hardly does a room before cutting out and then you have to wait an hour for it to cool down. am veryy disapointed
Jul 04, 2010 | VAX Appliances 2000 Canister Vacuum
My VAX Vacuum has lost ALL suction power. I've
vax power pet 1 filter keeps getting clogged up so dirt not going into cylinder
Jul 05, 2009 | VAX Appliances Vax X5 Bagless Upright...
Vax 2000 trips electrics
Try the reset drive belt brush button - you'll find it underneath the main power switch on the handle. Also check the brush isn't clogged, by the sole plate by tipping it over and undoing the screws on the bottom place where the beater bar is.
Apr 11, 2009 | VAX Appliances Vax X5 Bagless Upright...
Vacuums Logo
Top Vax Vacuums Experts
rugby prop
Are you a Vax Vacuum Expert? Answer questions, earn points and help others
