I have a nor dyne electric furnace e1eh-017ha the heating element is staying hot while the fan is off.
    Master:
  • 946 Answers
Get it fixed by a pro......that is dangerous. Something is not doing it's job. don-ohio
Posted on Dec 31, 2016
  • 49 Answers
SOURCE: Intertherm E1EH-015HA FURNACE no heat
Sounds like a downflow electric furnace? If so it sounds like you have 15kw worth of electric heat, you might have a defective heating sequencer, witch is what they call a dual on one plate.
Posted on Nov 28, 2007
Gigatech
  • 259 Answers
SOURCE: REPLACED 10KW FAN/HEAT SEQUENCER AND LOST TRACK OF WIRING
Could not find the E1Eh-020HA but found the E2 series
http://www.nordyne.com/Literature/707716c.pdf
http://www.nordyne.com/Literature/901a.pdf
Hope this helps. :]
Posted on Dec 13, 2007
SOURCE: I have a Carrier electric
Was the thermostat replaced? if so there is a gas/electric switch on the back that should be moved if not may be a bad control board
Posted on Jan 21, 2009
pierre1811
  • 144 Answers
SOURCE: Ruud furnace won't stay lit.
Hi, welcome to Fixya. If you have spark ignition turn off the power and using sand cloth clean the rod(s) and hood of the spark ignition. If it is a Hot Surface Igniter (glow coil) look on the opposite end of the burners and you will see a rod protruding in to the flame. It's called a flame sensor. Clean it with the sanding cloth. If either of these works then you bought some time but should consider replacing the part fairly soon. Please report back to let us know your progress. Good luck.
Posted on Jan 25, 2009
  • 3 Answers
SOURCE: Ruud Electric Furnace Cannot Reach Setpoint - "Watt Restrictor"?
unfamiliar with watt restrictors.
heat strips have 2 safety devices, a thermal overload, they get to hot they shut off, cause not enough air flow increase fan speed this device is auto reset. a fusible link a fail safe to thermal over load, no reset and sometimes replaceable. if this does not help would like to ask you a few questions. one of the buildings i take care of has 200 + reem/ ruuds all electric heat. if a part is defective replace, please do not by pass. safety frist.
Posted on Mar 07, 2009
E1eh-017ha ele.furnace fan shuts down then the heating elements get4 times hotter turn off.discount breakers in furnace still hot sets off fire detector. You have got to kill main breakers
Dont really understand .Is it a furnace with electric heat ,if it is then Check to see if contactor or relay is stuck closed ,also you heating element should not get so hot there should be a limit switch to shut heater off .Maybe bad limit and bad relay .Your electric heat should shut off when fan shuts off
Feb 15, 2018 | Heating & Cooling
My electric coleman furnace will not run.
Depress the interlock switch manually as the furnace is starting up. That should give you your answer. Some furnaces (mine) rely on a friction fit of the cover panel to close the switch. Over time, the friction fit stops fitting.
Feb 25, 2017 | Heating & Cooling
I have intertherm e1eh-015h I just wired up heat
when the thermostat is set more than 2 degrees higher than room temperature the auxiliary heat will run with the heat pump.
Oct 11, 2014 | Heating & Cooling
Nordyne FEH-017HA-04 furnace fan is running full speed on ac but not on furnace
Multiple speed fans are always wired to run on "HI" for A/C and a lower speed for heat. If there are more than 3 wires on the fan motor, its probably a multiple speed.
Oct 24, 2013 | Electrical Supplies
Blower stays on after heat goes off
when the room thermostat is satisfied it stops the heat by stopping power to the sequencer or contactor which is in series with the heating element/s...the TEMPERATURE OPERATED FAN SWITCH then takes over the blower until the heaters cool
Oct 02, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Mar 02, 2009 | Ruud UBHC Air Conditioner
Blower will not come on
could be the fan relay is bad. or the run capacitor. if these check good. you may have a bad heat sequencer. hard to tell, if you thave a/c you can turn thermostat fan swith to on and if blower comes on then relay and capacitor should be ok. some units have two or three heat sequencers 1 controls fan and the others control heat strips hopefully this helps good luck
Jan 04, 2009 | Kitchen Appliances - Others
Nov 26, 2007 | Heating & Cooling
Heating & Cooling Logo
55 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
