Question about Acer Tablets & eReaders
Acer iconia tablet one 8 logo flashing wont turn on or off on charge 15 hours red light on only had it 3 weeks what should I do
SOURCE: Micro Cruz Tablet Wont hold charge
Well, I think you should change the battery of your tablet PC. You must have charged the tablet for more than enough time several times. so the battery is damaged. or, the battery must be used for a long time!!!!!!
Posted on Jun 27, 2012
seductive_dr
SOURCE: my zeepad tablet won't work anymore. it won't turn on! it also won't charge! What can I do to fix it???
cant connect to google i got a gmail still wont let me connect my wifi works on it thats the only place i cant go
Posted on Dec 21, 2013
susannrosswa
SOURCE: my tesoar tablet showed charging for 3 seconds then that was it now it wont turn on it wont do anything
I have a hacker inside my Samsung galaxy 8 notebook, he controls my ph and I pad, how do I break the tracking link.
Posted on Mar 22, 2014
  • 846 Answers
SOURCE: What would be a reason for my ACER Iconia A1-810 tablet not powering on with a full charge?
If it doesn't turn on with a charged battery, you may have a broken logic board. If you're out of warranty, somebody has to open the device and replace the logic board. The part is available on ebay. On youtube you will find a guide on how to disassemble an Acer tablet. Maybe a tech savy friend can do it for you. If you want to pay to have somebody do it for you there are third party Acer Tablet Repair Services.
Posted on Nov 12, 2014
Testimonial: "Hi, thanks for the info. After many attempts of turning it on, the "Android System Recovery" screen came on; however, it won't allow me to select any of the booting options or at least it won't respond to selections. I highlight "Reboot system now" option and held the power button down to select it and it does nothing. Any suggestions. Does this sound more like the logic board being broken, as you originally suggested? I appreciate your help."
  • 44284 Answers
SOURCE: acer iconia one 7 tablet wont turn on, this is only 2 months old
I would contact seller and see if you can return / exchange it .
Posted on Feb 26, 2015
I have an acer iconia 500 tablet, it worked fine last night ,but today it wont get past the acer logo on boot.tried to do a hard reset and push button reset no joy ,any advice would be welcomed
lol I know that feeling...you need to reinstall the bios...you can find them on a flash drive on ebay. Or go free and use a flash drive to get it free online...go to acer.com...Its a known problem by Acer :) update: My Acer 500 stopped working Friday, with the very same freeze at Acer startup screen detailed here. Reset button didn't work (there's a post here that said he pressed the vol/up button while pressing the Reset button-I've only been inserting the tip of a paper clip to press button, which is the correct way?
Did the hold power button while pressing vol/up then sliding lock button back and forth. "Erasing Cache" appeared, but screen goes back to Acer startup and nothing.
Found this thread from a poster at Androidtablets.net. Downloaded one of the zip files posted here. Went to copy to an SD card, Can the file be placed on a USB drive instead? While trying the power "Bootloader vo.03.12-ICS Fastboot USB Download
Aug 13, 2016 | Acer Tablets & eReaders
Acer iconia one 7 tablet wont turn on, this is only 2 months old
Feb 26, 2015 | Acer Iconia One 7 B1-730HD-11S6 7-Inch HD...
Nov 12, 2014 | Tablets & eReaders
Acer iconia a500 tablet freezes at the boot screen and does not go any further
The following info from
http://community.acer.com/t5/Tablets/Iconia-A500-frozen-at-Acer-logo-boot-screen/td-p/7171/page/28
might be helpful:
"How do I perform a Factory Data Reset if my Acer ICONIA TAB A500 does not boot?The following steps will erase all of your personal information, all stored contacts and any programs you have installed on your tablet.
1.Power off the tablet.
2.Press and hold the Volume up button, which is located closest to the touch screen lock switch.
3.With the Volume up button held, press and hold the Power button for 3 seconds then release it. Continue holding the Volume up button.
4.Once the tablet vibrates, switch the touch screen lock switch on and off repeatedly while still holding the Volume up button.
5.Release the Volume up button and stop switching the touch screen lock switch once the "Erasing Userdata..." message appears in the upper left corner of the screen.
6.Once the factory reset has been completed your tablet will load to the Welcome screen. 7.Your Factory Data Reset has completed now follow the onscreen steps to setup your tablet."
Good Luck!
Oct 18, 2013 | Tablets & eReaders
Tablet won't charge
If it's new bring it back on the warantee, if it is out of warantee, check to see if the power supply is putting out the proper voltage at the plug in tip to the Acer. Make sure the tip is put ALL THE WAY into the hole on the acer.
Jan 02, 2013 | Acer Iconia Tab A200 Series Tablet with...
Acer tab A200
You may have to perform a reset if your tablet fails to respond when buttons are pressed or the screen is tapped. To reset your tablet use a small thin object (such as a paperclip) to press the recessed reset button.
Or do Clean Boot to restore the Acer Iconia Tab A501 factory default settings.
  • Open Settings from the application menu, then tap Privacy > Factory data reset.
  • Click Reset tablet and then Erase everything to format your tablet.
Jun 29, 2012 | Acer Iconia Tab A200-10g16u XE.H8QPN.001...
Tablets & eReaders Logo
63 people viewed this question
Top Acer Tablets & eReaders Experts
Lawrence Oravetz
Are you an Acer Tablet and eReader Expert? Answer questions, earn points and help others
